Steering Linkage Part Numbers
Revision as of 02:27, 9 January 2012; view current revision
Categories: Engine Mechanical | Catalog
Also see:
Part Numbers Index
Main article for usage, photos, cross-reference
Steering Linkage
1 48510-H1025 KIT-ROD SIDE RH 1072- 2 48510-H1002
1 48510-H1001 ASSY-ROD SIDE RH
1 48510-H1002 ASSY-ROD SIDE RH 1072- 6 48510-H1001
2 48520-H1001 ASSY-SOCKET SIDE ROD RH OUTER
3 48521-H1001 ASSY-SOCKET SIDE ROD RH INNER
4 48522-H1001 COVER-DUST SIDE ROD (2)
5 48526-18000 CLAMP-DUST COVER (2)
6 40189-73000 PLUG-FILLER (2)
7 01227-00011 NUT-HEX SLOTTED (3)
8 08921-32010 PIN-COTTER 3.2X20 (2)
9 48512-H1001 BAR-SIDE ROD
10 01211-00011 NUT-LOCK SIDE ROD RH
11 01211-00021 NUT-LOCK SIDE ROD LH
12 48630-H1002 ASSY-ROD SIDE LH 1072- 6 48630-H1001
12 48630-H1025 KIT-ROD SIDE LH 1072- 2 48630-H1002
12 48630-H1001 ASSY-ROD SIDE LH
13 48640-H1001 ASSY-SOCKET SIDE ROD LH OUTER
14 48641-H1001 ASSY-SOCKET SIDE ROD LH INNER
15 01211-00021 NUT-LOCK SIDE LH
16 48526-18000 CLAMP-DUST COVER (2)
17 40189-73000 PLUG-FILLER (2)
18 01227-00011 NUT-HEX SLOTTED (2)
19 08921-32010 PIN-COTTER 3.2X20 (2)
20 48512-H1001 BAR-SIDE ROD
21 01211-00011 NUT-LOCK SIDE RH
22 48530-H1600 ASSY-IDLER STEERING
23 48551-H1000 ARM-IDLER STEERING
24 48544-H1000 BUSH-IDLER (2)
25 48541-H1000 WASHER-IDLER UPPER
26 54324-21000 NUT-HEX SELF LOCK
26 54324-N0100 NUT-HEX SELF LOCK 2 54324-21000
27 48362-H1000 BOLT IDLER FIX TO FRAME (2)
28 08915-53810 WASHER-PLAIN M8 IDLER FIX TO FRAME (2)
29 48366-H1000 NUT IDLER FIX TO FRAME (2)
30 48560-H1600 ASSY-CROSS ROD STEERING
31 48522-H1001 COVER-DUST CROSS ROD
32 48526-18000 CLAMP-DUST COVER
33 40189-73000 PLUG-FILLER (2)
34 48577-H1001 SEAL-DUST IDLER ARM
35 01227-00011 NUT-HEX SLOTTED (2)
36 08921-32010 PIN-COTTER 3.2X20 (2)
