Gearbox Mount
Revision as of 03:08, 28 June 2012; view current revision
Categories: Transmission | Drivetrain Modifications
The Rear Engine Crossmember is more commonly called the gearbox crossmember. This transmission crossmember holds the rear engine insulator (rubber transmission mount). The crossmember matches the car, while the insulator matches the transmission type.
Crossmember
Manual Transmission
B110
  • 11322-H1002 MEMBER-engine mounting, rear 3-speed, 4-speed
  • 11322-H7200 MEMBER-engine mounting, rear 5-speed
    superceded by 11322-H7201 from 7210
  • 11322-H5000 MEMBER-engine mounting, rear 3-speed, 4-speed (56-series)
  • 11322-H7400 MEMBER-engine mounting, rear from 7510 Van (also replaces 11322-H5000)
  • 11322-H7500 MEMBER-engine mounting, rear A14 B210 60-series 4-speed
  • 11322-H5700 MEMBER-engine mounting, rear A12 5-speed F5C56
  • 11341-H7500 MEMBER-engine mounting, rear A14 B210 5-speed 63-series
B310
  • 11340-H8500 B310 56-series [2-bolt]
  • 11341-H8600 B310 60-series 5-speed [4-bolt]
NOTE: 11340-H8500 superceded 11340-H8600, which superceded 11340-H8610
B310 has several holes in the body for the 3 crossmember types.
  • Auto and 60-series look similar and both are 4-bolt
  • 56-series looks different and is 2-bolt
  • 3 holes on left side are 39.6 and 43.2 mm apart (front to back)
  • 3 holes on right side are 43.6 and 40 mm apart
60-Series
B210 vs B310 comparisons
56-series 4-speed
11341-H9110 A12.(CAN.1278- , USA.0879-)
* INSULATOR 11321-H6201
60-series F4W60/FS5W60L
11341-H8600 <> 11341-H9100
 11341-H8600 MT    intr-0779
 11341-H9100 MT    intr-0779.(FED+CAN)
 11341-H9100 MT.F4 0879-1079.(FED+CAN)
 11341-H8600 MT.F4 0879-exit.(CAL)
INSULATOR 11320-H9100
60-series 5-speed FS5W60A
11340-H8610 MT.FS5W60A 0879- CAL
11340-H9700 MT.FS5W60A 0879- FED+CAN
* both use INSULATOR 11320-H9100
AUTOMATIC
11341-H9300 AT.FED+CAL
11341-H8700 AT.CAL
* both use INSULATOR 11320-W5800
Automatic Transmission
  • 11322-H1020 MEMBER-engine mounting, rear Automatic B110
  • 11322-H5200 MEMBER-engine mounting, rear Automatic early B210
  • 11340-H7500 MEMBER-engine mounting, rear Automatic late B210
  • 11341-H8700 MEMBER-engine mounting, rear Automatic B310
71-series
Z-series transmission into B210
Rubber Insulator
There are different types of rear insulators.
The 56-Series Transmission type of mount bolts to the crossmember from the sides of the mount, just like these stock 1200 mounts:
This type, used with 60-Series Transmission, straddles the crossmember and bolts from the bottom:
Automatic is yet again different.
56-series
  • PN 11321-H1000 INSULATOR ASS'Y-engine mounting, rear manual trans $35.83 USD
    B110, B210, B310
    56-series transmission (3-speed, 4-speed and 5-speed)
    • 11321-H1000, 11321-H5000, 11320-H5000 the same?
B10
B10 MT mount looks identical to the newer B110/B210/B310 version.
  • 11321-18000, 11321-20300 ASS'Y INSULATOR-rear
60-series
  • 11321-H7500 INSULATOR ASS'Y-engine mounting, rear manual trans: A14 B210 4-speed (60-Series)
  • 11320-H9100 INSULATOR-ENGINE MOUNTING REAR B310 5-speed (60-series) from 7911 $120.48 USD
    • superceded 11320-W5000 INSULATOR-ENGINE MOUNTING REAR B310 KB310HF,B310HF (A12) 5-speed, A14 4-speed
  • Anchor Industries 2489
  • 1972-1982 Nissan Vehicles
63-Series
  • 11323-H7510 INSULATOR ASS'Y-engine mounting, rear manual trans: A14 B210 5-speed (63-Series)
  • 11323-H7400 INSULATOR ASS'Y-engine mounting, rear manual trans: late A12 B210 Sedan, Coupe
  • Anchor 2489
  • 11321-20300 ASS'Y INSULATOR-rear Coupe Automatic B10
  • 11321-H1020 INSULATOR ASS'Y-engine mounting, rear auto trans B110 $54.18 USD
    • Anchor 8115
$8.13 RockAuto.com
  • 11321-H2521 INSULATOR ASS'Y-engine mounting, rear auto trans early B210
  • 11320-H6900 Insul Mount $120.37 USD
  • 11321-H7321 INSULATOR ASS'Y-engine mounting, rear auto trans late B210
  • 11320-W5800 INSULATOR-ENGINE MOUNTING REAR B310 auto trans $79.77 USD
    • C120, S110, S12?
    • Anchor 2488
      • S12 CA20E MT
      • S12 CA18ET
      • B210 A14 AT
      • B310 some
      • B210 1978
  • 11320-W5000 910, B310, C120, F30
Also See
For swap details and other information, see:
