Also see:
Part Numbers Index Main article for usage, photos, cross-reference Throttle Cable Choke Cable Accelerator Pedal
RHD
ACCELERATOR (including Truck) 1 18010-H1000 ARM COMP.-accelerator pedal MT 18010-H1010 COMP. ARM-accelerator pedal AT 2 18100-H1000 ARM ASS'Y-accelerator pedal MT 18100-H1010 ASS'Y ARM-accelerator pedal AT 3 18021-H1000 BRACKET-accelerator pedal 4 18137-10600 RING-snap, E type 5 08310-51014 SCREW (fixing pedal bracket to body) 2 6 08360-63512 SCREW (fixing pedal stopper) 7 08911-30610 NUT (fixing pedal stopper) 8 18110-H1000 PEDAL-accelerator, foot rest 9 08510-51214 SCREW (fixing foot rest) 2 85-13512-12 SCREW (fixing foot rest) 2 1970 10 18215-27700 SPRING-return, accelerator 11 18135-14800 BUMPER 12 18036-18000 SPRING-clamp, accelerator wire 13 18200-H1000 WIRE ASS'Y-accelerator 14 18211-18001 RING-wire clamp
CHOKE CONTROL (non-GX) 15 18410-H1600 WIRE COMP.-choke control 18410-H1001 WIRE COMP.-choke control ^ 18410-H1600 16 25163-H1000 ESCUTCHEON-switch 17 18415-H1000 KNOB ASS'Y-choke control 18415-H1001 KNOB ASS'Y-choke control ^ 18415-H1000 18 25199-H1000 SPRING 19 00951-10400 GROMMET
GX (twin carb)
CHOKE CONTROL (GX) 18 18410-H2300 COMP.-WIRE, choke control (for twin carb.) 19 18415-H1000 KNOB-choke control 20 25169-89903 SCREW-with washer 21 24250-89929 GROMMET-choke wire
1 18010-H1902 COMP-ARM ACCELERATOR PEDAL AUTOMATIC 1 18010-H1602 COMP-ARM ACCELERATOR PEDAL MANUAL 2 18100-H1602 ASSY-ARM ACCELERATOR PEDAL MANUAL 2 18100-H1902 ASSY-ARM ACCELERATOR PEDAL AUTOMATIC 3 18017-H1600 PAD-ACCELERATOR PEDAL 4 18021-H1600 BRACKET-ACCELERATOR PEDAL 5 18215-H1600 SPRING-RETURN ACCELERATOR 5 18215-H1601 SPRING-RETURN ACCELERATOR 1070- 2 18215-H1600 6 18137-10600 RING-SNAP E TYPE 7 08310-S1614 SCREW-MACHINE M5 FOR BRACKET TO BODY FIX (3) 8 18056-H1600 BOLT-PEDAL STOPPER 9 08911-30610 NUT-HEX M6 FOR PEDAL STOPPER 10 18135-14800 BUMPER-ACCELERATOR PEDAL STOPPER 11 18036-18000 SPRING-CLAMP ACCELERATOR WIRE A8200-G1300 ASSY-WIRE ACCELERATOR 18200-H1600 12 18200-H1600 ASSY-WIRE ACCELERATOR 13 18410-H1601 COMP-WIRE CHOKE CONTROL 13 18410-H1602 COMP-WIRE CHOKE CONTROL 2 18410-H1601 14 18415-H1000 ASSY-KNOB CHOKE CONTROL 14 18415-H1001 ASSY-KNOB CHOKE CONTROL SEDAN & COUPE 0171- 2 18415-H1000 15 00951-10400 GROMMET
