Front Door Part Numbers
Revision as of 21:55, 18 May 2012; view current revision
Categories: Body | Catalog
Also see:
Part Numbers Index
Main article for usage, photos, cross-reference
Door
Door Glass
Weatherstripping
Coupe
Sedan, 4-Door
Sedan, 2-Door
Van
Truck
DOOR
1 80102-H1000 PANEL ASS'Y-front door (R.H.)
1 80103-H1000 PANEL ASS'Y-front door (L.H.)
2 80210-H1001 SASH ASS'Y-front door (R.H.)
2 80211-H1001 SASH ASS'Y-front door (L.H.)
3 80270-H1001 FRAME ASS'Y-door ventilator (R.H.)
3 80271-H1001 FRAME ASS'Y-door ventilator (L.H.)
4 80244-H1001 GLASS-door ventilator (R.H.)
4 80245-H1001 GLASS-door ventilator (L.H.)
5 80250-H1001 CHANNEL ASS'Y-door ventilator (R.H.)
5 80251-H1001 CHANNEL ASS'Y-door ventilator (L.H.)
6 80246-H1000 RUBBER-glazing, door ventilator 2
7 80260-H1000 CATCH ASS'Y-handle (R.H.)
7 80261-H1000 CATCH ASS'Y-handle (L.H.)
8 80247-H1000 WASHER-stop 2
9 80248-H1000 SPRING-door ventilator 2
10 08915-43810 WASHER-plain 2
11 08911-10610 NUT 2
12 08911-10610 NUT 2
13 80238-H1001 BRACKER-pivot top lower 2
14 80234-H1000 WASHER-bracket 2
15 80248-H1000 WASHER-rubber "A" 2
16 80825-H1000 WASHER-rubber "B" 2
17 08330-41020 SCREW 2
18 80282-H1001 WEATHERSTRIP-door ventilator (R.H.)
18 80283-H1001 WEATHERSTRIP-door ventilator (L.H.)
19 80336-H1001 RUBBER-glass run "B" 2
19 80336-G1001 RUBBER-glass run "B" 2 < 80336-H1001
20 08420-41012 SCREW (fixing ventilator to sash) 6
21 08915-53610 WASHER-plain (fixing ventilator to inner panel) 2
22 08310-61414 SCREW-with (fixing ventilator to inner panel) washer 2
DOOR HINGE
23 80400-H1001 HINGE ASS'Y-front door, upper (R.H.)
23 80400-H7000 HINGE ASS'Y-front door, upper (R.H.) < 80400-H1001
23 80401-H1001 HINGE ASS'Y-front door, upper (L.H.)
23 80401-H7000 HINGE ASS'Y-front door, upper (L.H.) < 80401-H1001
24 80402-H1001 HINGE ASS'Y-door, lower 2
   H0400-73002 BUSHING-door hinge 8
25 08120-82062 BOLT-with plain & lock washer 20
26 01121-00031 BOLT-with plain & lock washer 22
X  see Door Trim
Sedan
1 80102-H1200 ASSY-PANEL FRONT DOOR WITH SASH RH SEDAN 2 DOOR
1 80102-H7000 ASSY-PANEL FRONT DOOR WITH SASH RH SEDAN 2 DOOR 0772-
2 80103-H1200 ASSY-PANEL FRONT DOOR WITH SASH LH SEDAN 2 DOOR
2 80103-H7000 ASSY-PANEL FRONT DOOR WITH SASH LH SEDAN 2 DOOR 0772-
3 80152-H1200 PANEL-FRONT DOOR OUT SIDE RH SEDAN 2 DOOR
4 80153-H1200 PANEL-FRONT DOOR OUT SIDE LH SEDAN 2 DOOR
5 80210-H1201 ASSY-SASH FRONT DOOR RH SEDAN 2 DOOR
6 80211-H1201 ASSY-SASH FRONT DOOR LH SEDAN 2 DOOR
7 80270-H1001 ASSY-FRAME DOOR VENTILATOR RH SEDAN 2 DOOR
8 80271-H1001 ASSY-FRAME DOOR VENTILATOR LH SEDAN 2 DOOR
9 80244-H1001 GLASS-DOOR VENTILATOR RH TEMR T=4.0MM SEDAN 2 DOOR
9 80244-H1101 GLASS-DOOR VENTILATOR RH TINTED & TEM SEDAN 2 DOOR (OP)
10 80245-H1101 GLASS-DOOR VENTILATOR LH TINTED & TEM SEDAN 2 DOOR (OP)
11 80250-H1001 ASSY-CHANNEL VENTILATOR GLASS RH SEDAN 2 DOOR
12 80251-H1001 ASSY-CHANNEL VENTILATOR GLASS LH SEDAN 2 DOOR
13 80247-H1000 WASHER-STOP (2) SEDAN 2 DOOR
14 80248-H1000 SPRING (2) SEDAN 2 DOOR
15 H0285-H1000 RUBBER-GLAZING DOOR VENTILATOR (2) SEDAN 2 DOOR
15 80246-H1000 PUBBER GLAZING DOOR VENTILATOR (2) SEDAN 2 DOOR
16 80260-H1000 ASSY-CATCH HADLE RH SEDAN 2 DOOR
17 80261-H1000 ASSY-CATCH HANDLE LH SEDAN 2 DOOR
18 80238-H1001 BRACKET-PIVOT TOP LOW (2) SEDAN 2 DOOR
19 80234-H1000 WASHER-BRACKET PIVOT (2) SEDAN 2 DOOR
20 80284-H1000 WASHER-RUBBER A (2) SEDAN 2 DOOR
21 80285-H1000 WASHER-RUBBER B (2) SEDAN 2 DOOR
22 08330-41020 SCREW-MACHINE M4 3 (32) SEDAN 2 DOOR
23 80292-73000 RIVET-SPECIAL (2) SEDAN 2 DOOR
24 80282-H1001 WEATHERSTRIP-DOOR VENTILATORRH SEDAN 2 DOOR
25 80283-H1001 WEATHERSTRIP-DOOR VENTILATORLH SEDAN 2 DOOR
26 80336-H1000 RUBBER-GLASS RUN B SEDAN 2 DOOR
26 80336-H1001 RUBBER-GLASS RUN B SEDAN 2 DOOR 1070-
26 80336-H1800 RUBBER-GLASS RUN SEDAN 2 DOOR
26 80336-H1801 RUBBER-GLASS RUN SEDAN 2 DOOR
27 08420-41012 SCREW-MACHINE M4 FIXING VENTTO SASH (6) SEDAN 2 DOOR
28 08915-53610 WASHER-PLAIN 6 FIXING VENT TO INNER PAN (2) SEDAN 2 DOOR
29 08915-13610 WASHER-SPRING 6 FIXING VENT TO INNER PAN (2) SEDAN 2 DOOR
30 08410-61012 SCREW-MACHINE M6 FIXING VENTTO INNER PAN (2) SEDAN 2 DOOR
31 80310-H1200 GLASS-DOOR WINDOW TEMP T=4.0MM RH SEDAN 2 DOOR
31 80310-H1300 GLASS-DOOR WINDOW TEMP TINTED T=4.0 SEDAN 2 DOOR (OP)
32 80311-H1200 GLASS-DOOR WINDOW TEMP T=4.0MM LH SEDAN 2 DOOR
32 80311-H1300 GLASS-DOOR WINDOW TEMP TINTED T=4.0 SEDAN 2 DOOR (OP)
33 80302-H1200 ASSY-BOTTOM CHANNEL FRONT RH SEDAN 2 DOOR
33 80302-H1201 ASSY-BOTTOM CHANNEL FRONT RH SEDAN 2 DOOR 1070-
34 80303-H1200 ASSY-BOTTOM CHANNEL FRONT LH SEDAN 2 DOOR
34 80303-H1201 ASSY-BOTTOM CHANNEL FRONT LH SEDAN 2 DOOR 1070-
35 80316-H1200 RUBBER-GLEZING (2) SEDAN 2 DOOR
36 80335-H1200 RUBBER-GLASS RUN 'A' (2) SEDAN 2 DOOR
36 80335-H1201 RUBBER-GLASS RUN 'A' (2) SEDAN 2 DOOR
36 80335-H1202 RUBBER-GLASS RUN"A" (2) SEDAN 2 DOOR 1070-
37 80400-H1000 ASSY-HINGE FRONT DOOR UPPER RH SEDAN 2 DOOR
37 80400-H1001 ASSY-HINGE FRONT DOOR UPPER RH SEDAN 2 DOOR
37 80400-H7000 ASSY-HINGE FRONT DOOR UPPER RH SEDAN 2 DOOR 0772- $36.33 USD
38 80401-H1001 ASSY-HINGE FRONT DOOR UPPER LH SEDAN 2 DOOR
38 80401-H7000 ASSY-HINGE FRONT DOOR UPPER LH SEDAN 2 DOOR 0772- $36.33 USD
38 80401-H1000 ASSY-HINGE FRONT DOOR UPPER LH SEDAN 2 DOOR
39 H0400-73002 BUSH-DOOR HINGE UPPER (4) SEDAN 2 DOOR $2.53 USD
40 80402-H1000 ASSY-HINGE FRONT DOOR LOWER (2) SEDAN 2 DOOR
40 80402-H1001 ASSY-HINGE FRONT DOOR LOWER (2) SEDAN 2 DOOR $55.83 USD
41 H0402-H1001 BUSH-DOOR HINGE LOWER (4) SEDAN 2 DOOR
42 77720-89913 BOLT-SPECIAL M8 FILLER FIX 1 (12) SEDAN 2 DOOR
42 08120-82062 BOLT-SPECIAL M8 FILLER FIX 1 (12) SEDAN 2 DOOR 0570-
43 77740-89912 WASHER-PLAIN M8 FILLER FIX 1 (12) SEDAN 2 DOOR
44 08120-82062 BOLT WITH SPRING LOCK WASHERDOOR FIX 1 (12) SEDAN 2 DOOR
45 80212-H1200 ASSY-SASH LOWER FRONT RH SEDAN 2 DOOR
46 80213-H1200 ASSY-SASH LOWER FRONT LH SEDAN 2 DOOR
Coupe
1 80100-H7100 ASSY-PANEL FRONT DOOR WITH SASH RH COUPE 0772- 0 80100-H1800
1 80100-H1800 ASSY-PANEL FRONT DOOR WITH SASH RH COUPE
2 80101-H1800 ASSY-PANEL FRONT DOOR WITH SASH LH COUPE
2 80101-H7100 ASSY-PANEL FRONT DOOR WITH SASH LH COUPE 0772- 0 80101-H1800
3 80152-H1200 PANEL-FRONT DOOR OUT SIDE RH COUPE
3 80153-H1200 PANEL-FRONT DOOR OUT SIDE LH COUPE
4 80210-H1800 ASSY-SASH FRONT DOOR RH COUPE
5 80211-H1800 ASSY-SASH FRONT DOOR LH COUPE
6 80280-H1801 SET-COVER DOOR SASH RH COUPE
7 80281-H1801 SET-COVER DOOR SASH LH COUPE
8 80270-H1800 ASSY-FRAME DOOR VENTILATOR RH COUPE
9 80271-H1800 ASSY-FRAME DOOR VENTILATOR LH COUPE
10 80244-H1800 GLASS-DOOR VENTILATOR RH (ANTI-SUN T= COUPE
11 80245-H1800 GLASS-DOOR VENTILATOR LH (ANTI-SUN T= COUPE
12 80250-H1800 ASSY-CHANNEL VENTILATOR GLASS RH COUPE
13 80251-H1800 ASSY-CHANNEL VENTILATOR GLASS LH COUPE
14 80247-H1000 WASHER-STOP (2) COUPE
15 80248-H1000 SPRING (2) COUPE
16 H0285-H1000 RUBBER-GLAZING DOOR VENTILATOR (2) COUPE
16 80246-H1000 RUBBER-GLAZING DOOR VENTILATOR (2) COUPE 2 H0285-H1000
17 80260-H1800 ASSY-CATCH HANDLE RH COUPE
18 80261-H1800 ASSY-CATCH HANDLE LH COUPE
19 80238-H1800 BRACKET-PIVOT TOP LOW (2) COUPE
20 80234-H1000 WASHER-BRACKET PIVOT (2) COUPE
21 80284-H1000 WASHER-RUBBER A (2) COUPE
22 80285-H1000 WASHER-RUBBER B (2) COUPE
23 08330-51020 SCREW-MACHINE M5 (2) COUPE
24 80292-73000 RIVET-SPECIAL (2) COUPE
25 80282-H1800 WEATHERSTRIP-DOOR VENTILATORRH COUPE
26 80283-H1800 WEATHERSTRIP-DOOR VENTILATORLH COUPE
27 80336-H1801 RUBBER-GLASS RUN B (2) COUPE 7010- 2 80336-H1800
27 80336-H1800 RUBBER-GLASS RUN B (2) COUPE
28 80311-H1800 GLASS-DOOR WINDOW TEMP TINTED T=4.0 COUPE
29 80312-H1800 GLASS-DOOR WINDOW TEMP TINTED T=4.0 COUPE
30 80302-H1800 ASSY-BOTTOM CHANNEL FRONT RH COUPE
31 80303-H1800 ASSY-BOTTOM CHANNEL FRONT LH COUPE
32 80317-H1800 RUBBER-GLAZING (2) COUPE
33 80335-H1800 RUBBER-GLASS RUN 'A' (2) COUPE
33 80335-H1801 RUBBER-GLASS RUN 'A' (2) COUPE 7010- 2 80335-H1800
34 80400-H7000 ASSY-HINGE FRONT DOOR UPPER RH COUPE 0772- 2 80400-H1001
34 80400-H1000 ASSY-HINGE FRONT DOOR UPPER RH COUPE
34 80400-H1001 ASSY-HINGE FRONT DOOR UPPER RH COUPE 2 80400-H1000
35 80401-H7000 ASSY-HINGE FRONT DOOR UPPER LH COUPE 0772- 2 80401-H1001
35 80401-H1000 ASSY-HINGE FRONT DOOR UPPER LH COUPE
35 80401-H1001 ASSY-HINGE FRONT DOOR UPPER LH COUPE 2 80401-H1000
36 H0400-73002 BUSH-DOOR HINGE UPPER (4) COUPE
37 80402-H1000 ASSY-HINGE FRONT DOOR LOWER (2) COUPE
37 80402-H1001 ASSY-HINGE FRONT DOOR LOWER (2) COUPE 2 80402-H1000
38 H0402-H1001 BUSH-DOOR HINGE LOWER (4) COUPE
39 77720-89913 BOLT-SPECIAL M8 FILLER FIX 1 (12) COUPE
40 77740-89912 WASHER-PLAIN M8 FILLER FIX 1 (12) COUPE
41 08120-82062 BOLT-WITH SPRING LOCK WASHERDOOR FIX 1 (10) COUPE
