Also see:
Part Numbers Index Main article for usage, photos, cross-reference H145 Differential H165
H145 Composite
* 38300-H1000 ASSY-CARRIER WITH GEAR 39:10(3.900) B110 * 33800-H1010 ASSY-CARRIER WITH GEAR 39:10(3.900) 0374-0874 1 38310-G0400 COMP-CARRIER GEAR 2 08915-14010 WASHER-LOCK FIXING DIFF BEARING CAP 3 38315-G0400 BOLT FIXING DIFF BEARING CAP 4 38100-18000 SET-GEAR, hypoid with pinion (37 T:9 T) B10 Sedan & Coupe 4 38100-18100 SET-GEAR, hypoid with pinion (35 T:8 T) B10 Van 4 38100-H0700 SET-GEAR, hypoid with pinion (35 T:8 T) B10 Van 4 38100-15400 SET-GEAR, hypoid with pinion (37 T:8 T) B10 T 4 38100-G0400 SET-GEAR, hypoid with pinion (37 T:8 T) B10 T (from '67-Nov) 4 38100-H1000 SET-GEAR & PINION HYPOID B110 39:10T Sedan,Coupe 4 38100-H1100 SET-GEAR & PINION HYPOID B110 37:9T Van 5 38102-G0300 BOLT-DRIVE GEAR 6 38103-G0400 STRAP-LOCK BOLT 7 38421-G0500 CASE DIFFERENTIAL 8 38423-18000 GEAR-SIDE DIFF BEVEL 9 38424-18000 WASHER-THRUST SIDE GEAR T=0.76 MM 9 38424-18001 WASHER-THRUST SIDE GEAR T=0.81 MM 9 38424-18002 WASHER-THRUST SIDE GEAR T=0.86 MM 9 38424-18003 WASHER-THRUST SIDE GEAR FOR SERVICE T=0. 9 38424-18004 WASHER-THRUST SIDE GEAR FOR SERVICE T=0. 9 38424-18005 WASHER-THRUST SIDE GEAR FOR SERVICE T=1. 9 38424-18006 WASHER-THRUST SIDE GEAR FOR SERVICE T=1. 9 38424-18007 WASHER-THRUST SIDE GEAR FOR SERVICE T=1. 9 38424-18008 WASHER-THRUST SIDE GEAR FOR SERVICE T=1. 9 38424-18009 WASHER-THRUST SIDE GEAR FOR SERVICE T=1. 9 38424-18010 WASHER-THRUST SIDE GEAR FOR SERVICE T=1. 9 38424-18011 WASHER-THRUST SIDE GEAR FOR SERVICE T=1. 9 38424-18012 WASHER-THRUST SIDE GEAR FOR SERVICE T=1. 9 38424-18013 WASHER-THRUST SIDE GEAR FOR SERVICE T=1. 9 38424-18014 WASHER-THRUST SIDE GEAR FOR SERVICE T=1. 9 38424-18015 WASHER-THRUST SIDE GEAR FOR SERVICE T=1. 9 38424-18016 WASHER-THRUST SIDE GEAR FOR SERVICE T=1. 10 38425-18000 MATE-PINION DIFF BEVEL 11 38426-18000 WASHER-THRUST PINION MATE 12 38427-18000 SHAFT-PINION MATE 13 38428-G0400 PIN-LOCK DIFF PINION 14 38440-H1000 ASSY-BEARING DIFF SIDE * superseded 38440-18000 ASSY-BEARING DIFF SIDE 15 38453-H1000 SHIM-ADJUST SIDE BEARING T=0.05 15 38454-H1000 SHIM-ADJUST SIDE BEARING T=0.07 15 38455-H1000 SHIM-ADJUST SIDE BEARING T=0.10 15 38456-H1000 SHIM-ADJUST SIDE BEARING T=0.20 15 38457-H1000 SHIM-ADJUST SIDE BEARING T=0.50 16 38120-18000 ASSY-BEARING DRIVE PINION REAR 17 38140-18000 ASSY-BEARING DRIVE PINION FRONT 18 38165-H1000 SPACER-DRIVE PINION BEARING 18 38165-H1001 SPACER-DRIVE PINION BEARING 0374- 19 38154-G0400 WASHER-ADJUST DRIVE PINION T=2.74 19 38154-G0401 WASHER-ADJUST DRIVE PINION T=2.77 19 38154-G0402 WASHER-ADJUST DRIVE PINION T=2.80 19 38154-G0404 WASHER-ADJUST DRIVE PINION T=2.86 19 38154-G0406 WASHER-ADJUST DRIVE PINION T=2.92 19 38154-G0403 WASHER-ADJUST DRIVE PINION T=2.83 19 38154-G0405 WASHER-ADJUST DRIVE PINION T=2.89 19 38154-G0407 WASHER-ADJUST DRIVE PINION T=2.95 19 38154-G0408 WASHER-ADJUST DRIVE PINION T=2.98 19 38154-G0409 WASHER-ADJUST DRIVE PINION T=3.01 19 38154-G0410 WASHER-ADJUST DRIVE PINION T=3.04 19 38154-G0411 WASHER-ADJUST DRIVE PINION T=3.07 19 38154-G0412 WASHER-ADJUST DRIVE PINION T=3.10 19 38154-G0413 WASHER-ADJUST DRIVE PINION T=3.13 19 38154-G0414 WASHER-ADJUST DRIVE PINION T=3.16 19 38154-G0415 WASHER-ADJUST DRIVE PINION T=3.19 19 38154-G0416 WASHER-ADJUST DRIVE PINION T=3.22 19 38154-G0417 WASHER-ADJUST DRIVE PINION T=3.25 20 38189-18000 SEAL-OIL DRIVE PINION 21 38210-H1000 ASSY-FLANGE COMPANION WITH DAMPER 21 38210-18000 ASSY-FLANGE COMPANION 22 38215-01300 WASHER-PLAIN -0274 23 38216-H1000 NUT-DRIVE PINION 0374- 23 38216-18000 NUT-DRIVE PINION 24 38320-18010 GASKET-GEAR CARRIER 25 08915-13810 WASHER-LOCK 26 08911-20810 NUT
H165
The H165 was used all years of the 1200 Sunny Truck.
FINAL DRIVE
fits early housing:
38300-A6400 GEAR CARRIER ASS'Y (37/9) (H165A type)
38300-N5201 GEAR CARRIER ASS'Y (37/9) (H165B type) (from '73-1)
fits 2nd housing:
38300-N5200 GEAR CARRIER ASS'Y (37/9) (H165B type) (from '73-9)
1 38310-A6100 GEAR CARRIER COMP. <x> 38310-N5000
38310-N5000 GEAR CARRIER COMP. - (from '73-1)
38310-N5000 BOLT-diff bearing cap 4
08915-14010 WASHER-lock 4
2 38315-U1500 BOLT-bearing cap (from '72-5) 4 <> 38310-N5000 + 08915-14010
3 38100-28500 HYPOID GEAR & PINION SET (37/9) <x> 38100-N5200
38100-N5200 HYPOID GEAR & PINION SET (37/9) (from '73-1)
4 38102-28500 BOLT-drive gear 8
5 38103-28501 STRAP-lock bolt 4
6 38421-28500 CASE-diff
7 38423-28500 GEAR-side, diff bevel 2
8 38425-28500 PINION-mate, diff bevel 2
9 2 of thickness as required
38424-04101 WASHER-thrust, side gear (t=0.785)
38424-08000 WASHER-thrust, side gear (t=0.835)
38424-08001 WASHER-thrust, side gear (t=0.885)
38424-08002 WASHER-thrust, side gear (t=1.035)
38424-08003 WASHER-thrust, side gear (t=1.185)
10 38426-04100 WASHER-thrust, pinion mate 2
11 38427-28500 SHAFT-diff pinion
12 38428-21001 PIN-lock, pinion shaft <> 38428-U1500
38428-U1500 PIN-lock, pinion shaft (from '72-5)
13 38440-61501 BEARING ASS'Y-diff side 2
14 38453-28500 SHIM-adjust, drive gear (t=0.050) 2
38454-28500 SHIM-adjust, drive gear (t=0.750) 2
38455-28500 SHIM-adjust, drive gear (t=0.105) 3
38456-28500 SHIM-adjust, drive gear (t=0.200) 3
38457-28500 SHIM-adjust, drive gear (t=0.500) 2
15 38120-13201 BEARING ASS'Y-pinion rear
16 38140-13201 BEARING ASS'Y-pinion front
17 to '72-12, choose 1
38165-28500 SPACER-pinion bearing (l=48.40)
38166-28500 SPACER-pinion bearing (l=48.60)
38167-28500 SPACER-pinion bearing (l=48.80)
38168-28500 SPACER-pinion bearing (l=49.00)
from '73-1
38165-N5000 SPACER-pinion bearing
19 to '72-12, choose 1
38127-09400 WASHER-adjust, pinion bearing (t=2.58-2.60)
38128-09400 WASHER-adjust, pinion bearing (t=2.56-2.58)
38129-09400 WASHER-adjust, pinion bearing (t=2.54-2.56)
38130-09400 WASHER-adjust, pinion bearing (t=2.52-2.54)
38131-09400 WASHER-adjust, pinion bearing (t=2.50-2.52)
38132-09400 WASHER-adjust, pinion bearing (t=2.48-2.50)
38133-09400 WASHER-adjust, pinion bearing (t=2.46-2.48)
38134-09400 WASHER-adjust, pinion bearing (t=2.44-2.46)
38135-09400 WASHER-adjust, pinion bearing (t=2.42-2.44)
38136-09400 WASHER-adjust, pinion bearing (t=2.40-2.42)
38137-09400 WASHER-adjust, pinion bearing (t=2.38-2.40)
38138-09400 WASHER-adjust, pinion bearing (t=2.36-2.38)
38139-09400 WASHER-adjust, pinion bearing (t=2.34-2.36)
38140-09400 WASHER-adjust, pinion bearing (t=2.32-2.34)
38141-09400 WASHER-adjust, pinion bearing (t=2.30-2.32)
20 as required:
38153-28500 SHIM-adjust, side bearing (t=0.050)
38154-28500 SHIM-adjust, side bearing (t=0.075)
38155-28500 SHIM-adjust, side bearing (t=0.105)
38156-28500 SHIM-adjust, side bearing (t=0.200)
38157-28500 SHIM-adjust, side bearing (t=0.500)
21 from '71-1 as required:
38154-U1500 WASHER-adjust drive pinion (t=3.09)
38154-U1501 WASHER-adjust drive pinion (t=3.12)
38154-U1502 WASHER-adjust drive pinion (t=3.15)
38154-U1503 WASHER-adjust drive pinion (t=3.18)
38154-U1504 WASHER-adjust drive pinion (t=3.21)
38154-U1505 WASHER-adjust drive pinion (t=3.24)
38154-U1506 WASHER-adjust drive pinion (t=3.27)
38154-U1507 WASHER-adjust drive pinion (t=3.30)
38154-U1508 WASHER-adjust drive pinion (t=3.33)
38154-U1509 WASHER-adjust drive pinion (t=3.36)
38154-U1510 WASHER-adjust drive pinion (t=3.39)
38154-U1511 WASHER-adjust drive pinion (t=3.42)
38154-U1512 WASHER-adjust drive pinion (t=3.54)
38154-U1513 WASHER-adjust drive pinion (t=3.48)
38154-U1514 WASHER-adjust drive pinion (t=3.51)
38154-U1515 WASHER-adjust drive pinion (t=3.54)
38154-U1516 WASHER-adjust drive pinion (t=3.57)
38154-U1517 WASHER-adjust drive pinion (t=3.60)
38154-U1518 WASHER-adjust drive pinion (t=3.63)
38154-U1519 WASHER-adjust drive pinion (t=3.66)
22 38189-02700 SEAL-oil, drive pinion
23 38210-16500 FLANGE ASS'Y-companion <x> 38210-N1200
38210-N1200 FLANGE ASS'Y-companion (from '73-)
25 to '72-4
38215-21000 WASHER-drive pinion
38216-21000 NUT-drive pinion
from '72-5
38216-U1500 NUT-pinion
25 38216-U1500 GASKET-gear carrier
26 08120-82562 BOLT 8
27 08915-13810 WASHER-lock 8
28 08911-20810 NUT 8
1 38300-H1000 ASSY-CARRIER WITH GEAR 39:10(3.900) 2 38310-G0400 COMP-CARRIER GEAR 3 38315-G0400 BOLT FIXING DIFF BEARING CAP (4) 4 08915-14010 WASHER-LOCK FIXING DIFF BEARING CAP (4) 5 38100-H1000 SET-GEAR & PINION HYPOID 39:10 6 38102-G0300 BOLT-DRIVE GEAR (8) 7 38103-G0400 STRAP-LOCK BOLT (4) 8 38421-G0500 CASE DIFFERENTIAL 9 38423-18000 GEAR-SIDE DIFF BEVEL (2) 10 38424-18000 WASHER-THRUST SIDE GEAR (0) 10 38424-18001 WASHER-THRUST SIDE GEAR (0) 10 38424-18002 WASHER-THRUST SIDE GEAR (0) 11 38425-18000 MATE-PINION DIFF BEVEL (2) 12 38426-18000 WASHER-THRUST PINION MATE (2) 13 38427-18000 SHAFT-PINION MATE 14 38428-G0400 PIN-LOCK DIFF PINION 15 38440-H1000 ASSY-BEARING DIFF SIDE (2) 0772- 2 38440-18000 15 38440-18000 ASSY-BEARING DIFF SIDE (2) 16 38453-H1000 SHIM-ADJUST SIDE BEARING T=0.05 (0) 16 38454-H1000 SHIM-ADJUST SIDE BEARING T=0.07 (0) 16 38455-H1000 SHIM-ADJUST SIDE BEARING T=0.10 (0) 16 38456-H1000 SHIM-ADJUST SIDE BEARING T=0.20 (0) 16 38457-H1000 SHIM-ADJUST SIDE BEARING T=0.50 (0) 17 38120-18000 ASSY-BEARING DRIVE PINION REAR 18 38140-18000 ASSY-BEARING DRIVE PINION FRONT 19 38165-H1000 SPACER-DRIVE PINION BEARING 20 38154-G0406 WASHER-ADJUST DRIVE PINION T=2.92 (0) 20 38154-G0407 WASHER-ADJUST DRIVE PINION T=2.95 (0) 20 38154-G0414 WASHER-ADJUST DRIVE PINION T=3.16 (0) 20 38154-G0417 WASHER-ADJUST DRIVE PINION T=3.25 (0) 20 38154-G0404 WASHER-ADJUST DRIVE PINION T=2.86 (0) 20 38154-G0400 WASHER-ADJUST DRIVE PINION T=2.74 (0) 20 38154-G0401 WASHER-ADJUST DRIVE PINION T=2.77 (0) 20 38154-G0402 WASHER-ADJUST DRIVE PINION T=2.80 (0) 20 38154-G0415 WASHER-ADJUST DRIVE PINION T=3.19 (0) 20 38154-G0405 WASHER-ADJUST DRIVE PINION T=2.89 (0) 20 38154-G0416 WASHER-ADJUST DRIVE PINION T=3.22 (0) 20 38154-G0408 WASHER-ADJUST DRIVE PINION T=2.98 (0) 20 38154-G0409 WASHER-ADJUST DRIVE PINION T=3.01 (0) 20 38154-G0410 WASHER-ADJUST DRIVE PINION T=3.04 (0) 20 38154-G0411 WASHER-ADJUST DRIVE PINION T=3.07 (0) 20 38154-G0412 WASHER-ADJUST DRIVE PINION T=3.10 (0) 20 38154-G0413 WASHER-ADJUST DRIVE PINION T=3.13 (0) 20 38154-G0403 WASHER-ADJUST DRIVE PINION T=2.83 (0) 21 38189-18000 SEAL-OIL DRIVE PINION 22 38210-H1000 ASSY-FLANGE COMPANION WITH DAMPER FOR SERVICE 22 38210-18000 ASSY-FLANGE COMPANION 23 38215-01300 WASHER-PLASN 24 38216-18000 NUT-DRIVE PINION 25 38320-18010 GASKET-GEAR CARRIER 26 08915-13810 WASHER-LOCK (8) 27 08911-20810 NUT (8)
