Wiring Part Numbers
Revision as of 05:00, 10 April 2013; view current revision
Categories: Catalog | Body Electrical System
Also see:
Part Numbers Index
Main articles for usage, photos, cross-reference:
Wiring Harness
Battery
1971
WIRING
Truck
HARNESS ASSY-INSTRUMENT 24013
 24013-H1002 CABLE-COMP.-instrument harness (up to '73-3)
 24013-H1022 CABLE-COMP.-instrument harness (up to '71-3) (op.)
 24013-H1206 CABLE-COMP.-instrument harness (up to '71-4)
 24013-G1000 CABLE-COMP.-instrument harness
 24013-G1602 -7803
 24013-G1661 7804-8109
 24013-G1900 8110-8608
 24013-G1901 8608-8910
 24013-95W00 8910-
1 24012-H7000 HARNESS-ENGINE ROOM MANUAL 0772- 0 24012-H2102
1 24012-H7005 HARNESS-ENGINE ROOM AUTOMATIC 0772- 0 24012-H2112
1 24012-H2112 HARNESS-ENGINE ROOM AUTOMATIC 0172- 0 24012-H2111
1 24012-H2111 HARNESS-ENGINE ROOM AUTOMATIC 0671- 0 24012-H2118
1 24012-H7001 HARNESS-ENGINE ROOM MANUAL 0372- 0 24012-H7000
1 24012-H2102 HARNESS-ENGINE ROOM MANUAL 0172- 0 24012-H2101
1 24012-H2101 HARNESS-ENGINE ROOM MANUAL 0671- 0 24012-H2108
1 24012-H2108 HARNESS-ENGINE ROOM MANUAL 0471-0571 10 24012-H1900
1 24012-H1900 HARNESS-ENGINE ROOM MANUAL
1 24012-H2118 HARNESS-ENGINE ROOM AUTOMATIC
2 24013-H1905 HARNESS-INSTRUMENT MANUAL
2 24013-H2118 HARNESS-INSTRUMENT 0471-
2 24013-H2112 HARNESS-INSTRUMENT AUTOMATIC 0771- 0 24013-H2118
2 24013-H7000 HARNESS-INSTRUMENT AUTOMATIC 0772- 0 24013-H2112
3 24014-H1011 HARNESS-BODY SEDAN
3 24014-H1811 HARNESS-BODY COUPE
4 24015-H1900 HARNESS-TAIL SEDAN
4 24015-H7000 HARNESS-TAIL SEDAN 1272- 0 24015-H1900
4 24015-H1910 HARNESS-TAIL COUPE
5 24272-H1000 PROTECTOR-WIRING SEDAN
6 24039-H1900 ASSY-CABLE HAND BRAKE SWITCH
7 24150-H1020 ASSY-CABLE INDICATOR LAMP AUTOMATIC -671 1
8 24250-89927 GROMMET SEDAN
9 24029-H1400 CABLE-TANK UNIT COUPE
10 24220-89937 CLIP FIXING TO BODY SIDE INNER COUPE
11 24220-89953 CLIP FIXING TO REAR COMB LAMP COUPE
12 25442-H1100 LINK-FUSIBLE,TYPE C
12 25442-H2500 LINK-FUSIBLE,TYPE C 0471- 0 25442-H1100
13 24110-H1600 CABLE-BATTERY(+)
13 24110-H1605 CABLE-BATTERY (+) 0 24110-H1600
13 24110-H1900 CABLE-BATTERY(+) COUPE 2 24110-H1605
14 24080-H1900 CABLE-BATTERY(-)
15 24160-H1100 CABLE-ROOM LAMP DX
16 24100-H1600 CABLE-FOG LAMP
17 24163-H1900 CABLE-HEAT GLASS D OP 1270-
18 24220-89931 CLIP-CABLE OP 1270-
19 24161-H2200 CABLE-HEAT GLASS A OP.COUPE 1270-
19 24161-H1900 CABLE-HEAT GLASS,A OP.SEDAN
20 24162-H2200 CABLE-HEAT GLASS B OP 1270-
21 24163-H2200 CABLE-HEAT GLASS C OP.COUPE
22 24163-H2000 CABLE-HEAT GLASS OP.SEDAN
23 24338-H4600 CABLE-SEAT BELT WARNING MANUAL 0772- 2 24110-H1600
23 24338-H7005 CABLE-SEAT BELT WARNING AUTOMATIC 0772-
23 24338-H4600 CABLE-SEAT BELT WARNING 0172-
