Datsun 1200 used a simple on/off switch for an Oil Pressure Sender, to operate a so-called "idiot light" on the dash.
Thread Size - NPT: 1/8" x 28 British Std. Pipe (BSPT Tapered) Terminal Type: Bullet, Male Operating Pressure - PSI: 3 - 9 psi
1200 uses an "idiot light" (pilot lamp on the dash) to warn if oil pressure has dropped.
See: Oil Light Wiring
Nissan part number 25240-89910 SWITCH ASSY-OIL PRESSURE $17 USD See Switch Part Numbers
Aftermarket Beck/Arnley 201-0262 * Geo 1985-1991 * Honda 1986-2009 * Isuzu 1985-2004 * Mazda RX2 1971-1973 * Datsun B110/B210/B310 * Datsun F10/N10 * Datsun 411/510/610/810/910 * Datsun 710 * Datsun pickup 520/521/620/720 * Nissan Micra 1984-1999 * Nissan Pulsar 1982-1984 * Nissan B11 1983-1985 * Nissan Stanza T11 1983-1986
The stock Datsun 1200 oil pressure switch fits A-series and some L-series, Z-series, E-series, Diesel and CA-series engines. Also fits certain GM, IHC and Isuzu engines.
Datsun 1200 sender uses bullet connector.
Buy at RockAuto.com
NOTE: Some other Datsun senders use a spade connector or a screw connector
Nissan 25240-89902, 25240-89910 GM 94118755, 94312940 IHC 478097-C1 Isuzu 8-94118-755-0, 8-94312-940-0
For Pressure Gauge
Other Datsuns came with a pressure gauge, and used this switch:
Buy at RockAuto.com
Datsun 720 Pickup
Thread Size 1/8-28 ISO Tapered Thread Switch to close at 3-10 PSI 0-2 PSI - 75 Ohms min 5.5 PSI - 44-60 Ohms 30 PSI - 27-41 Ohms 80 PSI - 7-20 Ohms
Mechanical Oil Pressure Gauge
When fitting a Gauge to the A-series, you should know that the oil pressure switch threads are 1/8 BSPT (british standard pipe tapered). It screws directly into the oil pump housing.
CAUTION: Many gauge kits use Standard threads. Use an adapter fitting.
If you instead use a Tee connector, you can fit both the sensor and a separate gauage. Tees are avaialable in the usual auto supply stores such as Repco or Oreilly's.
Tee fitted to oil pump [Old Method, no longer recommended]
Right: this engine has the Tee (and an oil cooler)
A word of caution with this: they tend to break, perhaps due the weight of the sender at the end of the tee piece and the vibration of the engine. The solution is to use a braided hose from the oil sender hole out to the bodywork, and then mounted the tee with senders in place.
Datsun Nationals 2005 .. I think 3 different cars had their brass t-piece fail resulting in oil all over wakefield track. Definitely mount the brass fitting on the bodywork, not the engine. dattodude
