Clutch Cylinder Part Numbers
Revision as of 05:26, 17 June 2012; view current revision
Categories: Powertrain | Catalog
Also see:
Part Numbers Index
Main article for usage, photos, cross-reference
Hydraulic clutch
Clutch Master Cylinder
1 30610-24900 ASSY-CYLINDER CLUTCH MASTER (5/8" NABCO/ MANUAL
1 30610-24910 ASSY-CYLINDER CLUTCH MASTER (5/8" NABCO/ MANUAL 30610-24900
2 46090-10600 RESERVOIR-BRAKE OIL(NABCO) MANUAL
2 46090-10610 RESERVOIR-BRAKE OIL(TOKICO) MANUAL
3 46016-12200 ASSY-BAND OIL RESERVOIR (NABCO) MANUAL
3 46016-14600 ASSY-BAND OIL RESERVOIR (NABCO) MANUAL 2 46016-12200
3 46016-10610 ASSY-BAND OIL RESERVOIR (TOKICO) MANUAL
4 46020-10611 SET-CAP OIL RESERVOIR (TOKICO) MANUAL
4 46020-28600 SET-CAP OIL RESERVOIR(NABCO) MANUAL
4 46020-E0300 SET-CAP OIL RESERVOIR(NABCO) MANUAL 2 46020-28600
5 46061-30000 SPRING-PISTON(NABCO/TOKICO) MANUAL
6 46077-08710 ASSY-PISTON CLUTCH MASTER (TOKICO) MANUAL
6 46076-08700 ASSY-PISTON CLUTCH MASTER (NABCO) MANUAL
7 46064-30002 CUP-PISTON "P" (NABCO) MANUAL
7 46064-10610 CUP-PISTON(TOKICO) MANUAL
8 46065-15800 CUP-PISTON"S"(NABCO) MANUAL
8 46065-10610 CUP-PISTON"S"(TOKICO) MANUAL
9 46073-30800 ASSY-VALVE INLET(NABCO) MANUAL
9 46073-10610 ASSY-VALVE INLET(TOKICO) MANUAL
10 46056-27260 SPRING-VALVE INLET (NABCO/TOKIC MANUAL
11 46076-30800 RETAINER-SPRING (NABCO/TOKIC MANUAL
12 46032-27260 PIN-RELEASE INLET VALVE (NABCO) MANUAL
12 46032-10610 PIN-RELEASE INLET VALVE (TOKICO) MANUAL
13 46043-27260 PACKING(NABCO) MANUAL
14 46079-27260 RING-"O"(NABCO) MANUAL
14 46079-10610 RING"O"(TOKICO) MANUAL
15 30631-24900 ASSY-ROD BUSH(NABCO) MANUAL
15 30631-24910 ASSY-ROD BUSH(TOKICO) MANUAL
16 46070-27260 RING-SNAP(NABCO/TOKICO) MANUAL
17 46100-27260 COVER-DUST(NABCO/TOKICO) MANUAL
18 30610-10627 KIT-REPAIR"A"(TOKICO) MANUAL
18 30610-10625 KIT-REPAIR"A"(NABCO) MANUAL
19 30610-08726 KIT-REPAIR"B"(NABCO) MANUAL
19 30610-10628 KIT-REPAIR"B"(TOKICO) MANUAL
20 08110-84510 BOLT-HEX M8 (2) MANUAL
21 08915-23810 WASHER-LOCK M8 (2) MANUAL
22 30613-27260 SHIM T=0.5MM (0) MANUAL
22 30611-27260 SHIM T=1.6MM (0) MANUAL
22 30612-27260 SHIM T=0.8MM (0) MANUAL
Clutch Operating Cylinder
Slave cylinder
1 30620-H1600 ASSY-CYLINDER CLUTCH OPERATING MANUAL
1 30620-H1601 ASSY-CYLINDER CLUTCH OPERATING MANUAL 30620-H1600
2 30625-27260 PISTON MANUAL
3 30624-21000 CUP-PISTON MANUAL
4 30628-H1600 ROD-PUSH MANUAL
5 30627-25500 COVER-DUST MANUAL
6 41128-18000 SCREW-BLEEDER MANUAL
7 41129-A2410 CAP-BLEEDER MANUAL
7 41129-40F00 CAP-BLEEDER MANUAL 41129-A2410
8 30547-78001 NUT-PUSH MANUAL
9 08121-02565 BOLT MANUAL
10 08911-30810 NUT-LOCK MANUAL
11 46201-89914 ASSY-HOSE CLUTCH MANUAL
11 46211-01A14 ASSY-HOSE CLUTCH MANUAL 46201-89914
12 46237-18000 GASKET-CLUTCH HOSE TO CYLINDER T=0 MANUAL
12 46237-A4600 GASKET-CLUTCH HOSE TO CYLINDER T=1 MANUAL 2 46237-18000
13 46205-61000 PLATE-LOCK CLUTCH HOSE MANUAL
14 46206-18000 SPRING-LOCK CLUTCH HOSE MANUAL
15 46410-H1600 ASSY-TUBE CLUTCH MANUAL
