Jellybeans
Revision as of 09:44, 19 October 2015; view current revision
Category: Wheel And Tire
Whether you call them jellies or dish mags or slotted mags, they are the quintessental 1970s alloy wheel. Datsun 1200 uses 4-lug on 4-1/2" pitch circle (PCD), metric equivalent is 4.113mm PCD.
[hide]
Slotted Mag ID Guide
Jellybean Rim ID Guide
Cast IDs
Many rims have the brand, the size, or other information cast into the wheel, most often on the back side.
Center Caps
  • 3-screw
  • 4-screw
  • 5-screw
  • Captive (slips into the center hole before wheel is fitted)
  • (Pushes into the center hole)
Slot Types
  • Rounded
  • Squared off
  • Trapezoidal
  • 4-slot (often called "dish mags")
  • 5-slot (most common)
  • 6-slot
4-slot
Rare 4-slot design
5-slot
Datsun 1200 SSS 12x4 Ward Wheels
5-slot 12x4
5-slot
6-slot
Trapezoidal slot
Triangular-like slots
Valve Stem
  • Valve stem in the slot
  • Valve stem in the disc
( Valve stem in the barrel
Shoulder
Common is squared-off shoulders.
Rare is rounded shoulders.
Hub Area
  • Flat
  • Recessed
  • Raised
Brands
Triden
Also see Rims#Triden
Modified 5-slot jellies. Sometimes called "tridents", the come with silver or black centers:
