Brakes
Revision as of 04:55, 30 August 2007; view current revision
Category: Brake System
Datsun 1200s came with two brake systems:
The 1200 front-disc/rear-drum system was good for 1971. In fact, stopping power was better than most 'muscle cars' of the era. However, if you have a drum/drum system, you'll want to upgrade to disc/drum. The drum system stops well enough, but the disc system has less fading going down mountain roads. See Brake Swaps.
Caliper bolt spacing:
  • ~84 mm: B110, and all 12" wheel B210 and B310
  • 88.9 mm: B310 large struts for 13" wheels
Rotor Sizes
</td></tr>
Dia. (mm)Part NumberSource
212.540206-H1006B110, B210 with A12 1974, 1975
220 (AN18)40206-H7500B210 A12 1976-1978,B310 with 12" wheels
23240206-A1155B210 A13, PB110?, PB210 early?
245 (AN20)40206-U6700A10, B210 A14, B310 A14/A15, PB210 late?
brake cylindersB110 (disc)1977 US B2101980 US B310 (Disc-AN20)1980 Canada A12A (Disc-AN18)
Proportioning valvenot usedyes1,961 kPa x 0.4 psi1,961 kPa x 0.4 psi
Booster (Master-Vac)not used?M60 6-in diameter 135mm rod length (flange-to-pedal)M60 6-in diameter
Master diameter11/16 inch3/4 inch13/1613/16
Front cylinder diameter1.894 inch (drum brakes: 11/16)2.012 inch2.012 inch1.894 inch
Rotor diameter212.5 mm245mm245mm220mm
Pad (width x length)42.5 x 53.1 mm41.2 x 63.4 mm41.2 x 61.4 mm42.0 x 56.8 mm
Pad thickness10.310.010.010.3
Total front braking area (discs)14.0 sq in16.2 sq in~14.6~13.8
Total front braking area (drums)42.3 sq inn/an/an/a
Rear cylinder diameterdisc brake models: 11/16 inch (all-drum models: 13/16)13/16 inch13/1613/16
Drum diameter8.0 inch8.0 inch8.08.0
Drum width1.378 inch1.378 inch1.3781.378
Total rear braking area42.3 sq in42.3 sq in42.342.3
http://www.rockauto.com
Small Pad (58 mm for 212mm rotor) Fits:
  • 1971-1973 B110
  • 1973-1974 Civic USA
  • 1976-1978 F10 USA
  • 1979-1982 N10 (Datsun 310) USA
Raybestos PGD104, Wearever D41, Bendix D104, Beck/Arnley 0880100D?, ACDELCO 17D104 (18028686)
Medium Pad (for 220mm rotor) fits:
  • B310 A12A Canada (220mm AN18 rotor)
Beck/Arnley 0820100 Premium Organic $9.18
Large Pad (63.5 mm for 245 mm rotor) RockAuto for AN20 rotor PartsAmerica fits:
  • 1974-1978 Datsun B-210
  • 1975-1979 Civic USA
  • 1977-1979 Datsun 200SX (S10)
  • 1979-1982 Datsun 210 (B310) USA
  • 1975-1976 Datsun 610
  • 1975-1977 Datsun 710
Raybestos SGD117, PGD117 or RPD117, Beck/Arnley 0870944, 0820944 or 0880944D, Wearever D103, Bendix D103, ACDELCO 17D117 (18028692)
Rear Brake Shoe set (8 x 1-3/8, fits B110, B210 and B310)
  • RAYBESTOS 371PG $15.36
  • WAGNER PAB371 $16.52
  • ACDELCO 17371B $19.02
  • WAGNER BD60368 $39.89
Disc brake Hose
  • RAYBESTOS BH36892 Front Left $8.51
  • RAYBESTOS BH36892 Front Right $8.51
  • WAGNER F96544 $9.50
  • WAGNER F96862 $9.73,
Rear hose
  • RAYBESTOS BH36866 $9.51
  • BECK/ARNLEY 0730879 $11.34
Rotor
  • Front disc inner wheel bearing {Taper Bearing Assembly / Cone Length=0.5906 Bore=0.9843 Outer Diameter=2.0472 Width=0.6398 Cup Length=0.5118 Cone Radius=0.06 Cup Radius=0.06}
    • BECK/ARNLEY 0513809 $13.61
    • BCA 30205 $14.73
  • Front disc outer wheel bearing {Taper Bearing Assembly / Cone Length=0.5118 Bore=0.5906 Outer Diameter=1.6535 Width=0.561 Cup Length=0.4331 Cone Radius=0.06 Cup Radius=0.06}
    • BCA 30302
    • Wheel bearings (PN 43215-18000)
Brake Upgrades
see Brake Upgrades
