Space for twin sidedrafts on LHD 1200s is limited because the brake master cylinder is on the carburetor side of the engine.
Some LHD 1200 owners choose a single sidedraft to "make it easy", but that is a performance loss. Twin carbs can easily be fitted.
* Weber DCOE carburetor * Dellorto DHLA * Mikuni PHH (Solex)
NOTE: Dual sidedrafts of the Weber/Mikuni-Solex/Dellorto type hit the brake master cylinder. So use special techniques:
* Move engine over * Angled manifold * Move the Brake Master Cylinder
Engine Moved Slightly
tens_and_twenties: In my old B110 with side drafts we just moved the whole engine over 1". Worked a treat and no one ever seemed to notice.
had a 77 [B210] 210 with an a15. moved the motor one inch to the right so i could mount dual mikunis. no problems up to 125 mph. Ratsun
Angle Manifolds
angled manifolds, good for fitting in LHD cars
Move the Master Cylinder
* Moved Over * Moved Forward * Moved under dash
