The wiper motor bolts to the engine compartment firewall. LHD cars sweep to the left, RHD sweeps to the right. For the windscreen washer, see Kangaroo Bag.
The windscreen wipers are about both the outside parts, and the linkage inside the passenger compartment.
Outside Parts: * Wiper Motor * Arms * Blades * "Refills" (Rubber inserts)
Inside Parts: * Linkage * Switch * Fuse
Wiper Motor
As with the rest of the wiper system, the wiper motor for RHD and LHD are reversed. RHD models have the wiper motor on left side, just below the left bonnet hinge.
Wiper Switch
Wiper Arms
The arms are the part outside the windshield, minus the blade.
RHD
26380-H1000 ARM ASS'Y-wiper ALL (except GX) 26380-H2300 ARM ASS'Y-wiper GX
LHD
26380-H1600 ASSY-ARM WIPER
Wiper Blades
Datsun 1200 uses 16" (405mm) wiper blades. The original blade was a stainless steel design marked "56L" on the bottom and "AE" on top. This blade takes 5/16" wide refills (9mm).
The blade is the part that holds the rubber inserts (refills)
To separate arm from blade, insert knife as shown to lift up tab. Then pull the blade off the arm.
GX-5 option: For high-speed stability, it has a built-in wind spoiler
Refills
For stock wiper arms, the refills are 16" long x 5/16" "Universal" style.
NOTE: over the years many 1200 blades have been replaced with quick-replacment blades. If so, the original style refills won't fit.
* NAPA 762-3164 Package say "Standard" type * TRICO 44160
Trico 44 Series Universal wiper refills are designed to fit most long frame TRICO, Tridon, Roberk, Anco, Pylon and Original Equipment plastic blades. Designed with metal end clips for ease of installation.
RHD
* 26360-H1000 BLADE ASS'Y-wiper ALL (except GX) * 26360-H2300 BLADE ASS'Y-wiper GX * 26370-A4600/A4601 BLADE ASS'Y-wiper GX-5, Optional ALL (same as Datsun 510 SSS/CSS blades) * B6370-89901 OLD Type L=400 Black
LHD
26375-U5200 ASSY-BLADE WIPER [Option, High Speed] * replaces 26375-A4601 ASSY-BLADE WIPER OP > 26375-A4600 26360-B5200 ASSY-BLADE WIPER [non-High Speed] B210 26375-H7700 ASSY-BLADE WIPER [Matte Black, 1978) B210
Linkage
RHD
Template:PhotoThumbAlbum Template:PhotoThumbAlbum Template:PhotoThumbAlbum Template:PhotoThumb Template:PhotoThumb Template:PhotoThumb Template:PhotoThumb Template:PhotoThumb
Pivots
B110 wiper pivots 28870-H1000 & 28875-H1000 (RHD) [28870-H1600 LHD]
B210 wiper pivots 28870-H5000 & 28875-H5000
ピボット リンケージ
Wiper wiring includes the fuse in the Fuse Box and the wires and connectors.
Seals
28876-H1000 SEAL-PIVOT WINDSHIELD WIPER 2 $2.43 USD
Customizing
See: * Wiper Relocation * Wiper Motor Upgrades * Intermittent Wipers
ワイパー
