Clutch
Revision as of 21:43, 22 December 2007; view current revision
Category: Clutch
Disc
  • SIZE ID: 13/16
  • SIZE OD: 7 1/8
  • TEETH: 18T
Service Specifications:
  • Deflection limit: 0.5 mm at 85 mm radius
  • Height Diagphragm spring end: 29-31 mm at 62 mm diameter
  • Facing depth to rivets: 0.3 mm or better
Clutch Release Bearing (release bearing, throwout bearing)
  • Bore = 1.5748
  • Outer Diameter = 2.8898
  • Width = 0.752
Throwout Bearing
Mechanical Clutch (RHD)
  1. Withdrawal lever
  2. Return spring
  3. Release bearing
IMPORTANT Grease these locations:
Hydraulic Clutch (LHD)
See Hydraulic clutch
Adjustment
  • Cable clutch: as follows
<help by writing this up!>
http://www.rockauto.com
Clutch Kit (PLATE KIT,CLU PRESS & DRVN(W/CVR))
  • BECK/ARNLEY 0619114 $78.89 {180mm Diameter;7-1/8" Diameter;18 Splines}, ACDELCO 381622 $83.79
  • BCA 01576 $21.89
{Ball Bearing}
Clutch Slave Cylinder
  • RAYBESTOS SC37495 $12.44, ACDELCO 18F19 $14.56
Compare to B210:
B210 clutch cylinder 5/8 inch. Fits:
Beck Arnley part number 072-6489
  • 620 Pickup from 1972-3/76 <li>B210 (all models) from 1974-4/75 <li>SPL-311 (1600 or 2000) from 1966-70 <li>510 from 1968-73 (with Nabco master cylinder) <li>610 from 1973-75 (with Nabco master cylinder) <li>710 from 1973-75 </ul> Beck Arnley part 072-6521
      <li>74-75 B210 <li>76 F10 <li>72-76 <li>620 pickup <li>66-70 SPL-311 1600 <li>68-70 SPL-311 2000 <li>75-78 280Z <li>69-73 510 <li>78-81 510 <li>73-76 610 <li>74-77 710 <li>77-81 810
    </blockquote>
    Pilot Bushing
    Clutch Alignment Tool (wood, plastic or metal)
    Suppliers
