Also see:
Part Numbers Index Main article for usage, photos, cross-reference Carburetor
Crank
1 16010-H1601 ASSY-CARBURETOR (HITACHI DCG A12 CRANK 1070- 2 16010-H1600 1 16010-H1602 ASSY-CARBURETOR (HITACHI DCG A12 CRANK 0771- 2 16010-H1601 1 16010-H1600 ASSY-CARBURETOR (HITACHI) A12 CRANK 2 16118-H1000 ASSY-CHAMBER THROTTLE A12 CRANK 3 16145-91460 SPRING IDLER ADJUST SCREW A12 CRANK 4 16145-50000 SPRING THROTTLE ADJUST SCREW A12 CRANK 5 16129-14811 SCREW-THROTTLE ADJUST A12 CRANK 2 16129-25715 5 16129-25715 SCREW THROTTLE ADJUST A12 CRANK 6 16144-B0815 SCREW IDLE ADJUST A12 CRANK 7 16082-18010 PLATE-ADJUST A12 CRANK 8 16065-10620 SCREW 6D A12 CRANK 8 16065-H1010 SCREW 6D A12 CRANK 2 16065-H1010 9 16029-18010 WASHER 6D A12 CRANK 10 16061-18010 FLOAT A12 CRANK 11 16066-18010 SHAFT FLOAT A12 CRANK 12 16101-H1000 VALVE NEEDLE A12 CRANK 13 16094-10400 WASHER 10D (2) A12 CRANK 14 16098-25710 FILTER A12 CRANK 15 16025-H1000 TUBE EMULSION (P) A12 CRANK 16 16026-25710 TUBE EMULSION (S) A12 CRANK 16 16026-B0810 TUBE EMULSION (S) A12 CRANK 2 16026-25710 17 16171-25710 WEIGHT INJECTOR A12 CRANK 18 16033-18017 JET-MAIN #92(2000M) OP A12 18 16034-18016 JET-MAIN #86(4000M) OP A12 18 16034-19915 JET MAIN #98 A12 CRANK 19 16135-33815 JET MAIN #135 A12 CRANK 20 16050-18010 BLEED MAIN AIR #80 (2) A12 CRANK 21 16204-08000 BLEED MAIN AIR #100 A12 CRANK 22 16213-08000 BLEED MAIN AIR #220 A12 CRANK 22 16052-85060 BLEED MAIN AIR #200 A12 CRANK 2 16213-08000 23 16055-14811 JET SLOW #43 A12 CRANK -1173 3 24 16054-B0810 JET SLOW #50 A12 CRANK 25 16059-14810 VALVE POWER #60 A12 CRANK 26 16455-H1000 KIT-GASKET A12 CRANK 26 16455-H6200 KIT-GASKET A12 CRANK 2 16455-H1000 27 16465-H1000 SCREW & WASHER ETE KIT (A) A12 CRANK 28 16475-H1000 SCREW & WASHER ETE KIT (B) A12 CRANK 29 16134-18010 LEVER THROTTLE A12 CRANK 30 16116-18010 SLEEVE A12 CRANK 31 16133-H1000 LEVER STARTING A12 CRANK 32 16084-58000 WASHER A12 CRANK 32 16084-22010 WASHER A12 CRANK 2 16084-58000 33 16160-H1001 SPRING-THROTTLE RETURN (FOR 16010-H A12 CRANK 2 16160-H1000 33 16160-H1000 SPRING THROTTLE RETURN A12 CRANK 34 16141-18010 ROD CONNECTING A12 CRANK 35 16272-36710 PLATE DRAIN (2) A12 CRANK 36 16151-H1000 PISTON A12 CRANK 37 16148-H1000 SPRING PISTON RETURN A12 CRANK 38 16307-04000 COVER PUMP A12 CRANK 39 16302-18010 LEVER PUMP A12 CRANK 40 16305-19915 SHAFT PUMP LEVER A12 CRANK 41 16143-18010 ROD PUMP A12 CRANK 42 16011-H1600 ASSY-CHOKE CHAMBER A12 CRANK 42 16011-H1601 ASSY-CHOKE CHAMBER A12 CRANK 2 16011-H1600 43 16248-H1000 ROD CHOKE CONNECTING A12 CRANK 44 16161-H1000 HANGER SPRING A12 CRANK 44 16161-H1001 HANGER-SPRING A12 CRANK 0970- 2 16161-H1000 45 16155-B0815 ARM THROTTLE WIRE A12 CRANK 46 16165-H1600 ARM CHOKE WIRE A12 CRANK
47 XX010-H1925 KIT-REPAIR A A12 CRANK 2 X6010-H1925 47 16009-H1910 KIT-REPAIR A CARBURETOR A12 CRANK 2 XX010-H1925 47 16009-H7000 KIT-REPAIR A CARBURETOR A12 CRANK 2 16009-H1910 47 16009-H6200 KIT-REPAIR A CARBURETOR A12 CRANK 2 16009-H7000 47 X6010-H1925 KIT-REPAIR A A12 CRANK 48 16009-H1911 KIT-REPAIR B CARBURETOR A12 CRANK 2 XX010-H1926 48 X6010-H1926 KIT-REPAIR B A12 CRANK 48 XX010-H1926 KIT-REPAIR B A12 CRANK 2 X6010-H1926
Exhaust
To May 1971 with Manual Choke. From June 1971 see DCH Carburetor
1 16010-H1901 ASSY-CARBURETOR A12 EXHAUST & EVAPO 2 16010-H1900 1 16010-H1902 ASSY-CARBURETOR HITACHI DCG306-3A A12 EXHAUST & EVAPO 1070- 2 16010-H1901, 16010-H1602 1 16010-H1900 ASSY-CARBURETOR A12 EXHAUST & EVAPO 2 16118-H1910 ASSY-CHAMBER FLOAT A12 EXHAUST & EVAPO 3 16145-91460 SPRING-IDLE ADJUST SCREW A12 EXHAUST & EVAPO 4 16145-50000 SPRING-THROTTLE ADJUST SCREW A12 EXHAUST & EVAPO 5 16129-14811 SCREW-THROTTLE ADJUST A12 EXHAUST & EVAPO 2 16129-25715 5 16129-25715 SCREW-THROTTLE ADJUST SCREW A12 EXHAUST & EVAPO 5 16455-H6200 SET-GASKET A12 EXHAUST & EVAPO 2 16455-H1000 6 16144-B0815 SCREW-IDLE ADJUST SCREW A12 EXHAUST & EVAPO 7 16082-18010 PLATE-ADJUST THROTTLE A12 EXHAUST & EVAPO 8 16133-H1000 LEVER-STARTING A12 EXHAUST & EVAPO 9 16116-18010 SLEEVE A12 EXHAUST & EVAPO 10 16134-H1910 LEVER-THROTTLE A12 EXHAUST & EVAPO 11 16236-H1910 LEVER (A) A12 EXHAUST & EVAPO 12 16116-H1910 SLEEVE (A) A12 EXHAUST & EVAPO 13 16249-H1910 LEVER A12 EXHAUST & EVAPO 14 16034-19915 JET-MAIN #98 A12 EXHAUST & EVAPO 15 16135-33815 JET-MAIN #135 A12 EXHAUST & EVAPO 16 16272-36710 PLUG-DRAIN (2) A12 EXHAUST & EVAPO 17 16059-14810 VALVE-POWER #60 A12 EXHAUST & EVAPO 18 16148-H1000 SPRING-PISTON RETURN A12 EXHAUST & EVAPO 19 16151-H1000 PISTON A12 EXHAUST & EVAPO 20 16025-H1000 TUBE-EMULSION P A12 EXHAUST & EVAPO 21 16026-25710 TUBE-EMULSION S A12 EXHAUST & EVAPO 21 16026-B0810 TUBE-EMULSION S A12 EXHAUST & EVAPO 2 16026-25710 22 16050-18010 BLEED-MAIN AIR #80 (2) A12 EXHAUST & EVAPO 23 16171-25710 WEIGHT-INJECTOR A12 EXHAUST & EVAPO 24 16055-14811 JET-SLOW #43 A12 EXHAUST & EVAPO 25 16054-B0810 JET-SLOW #50 A12 EXHAUST & EVAPO 26 16011-H1600 ASSY-CHOKE CHAMBER A12 EXHAUST & EVAPO 26 16011-H1601 ASSY-CHOKE CHAMBER A12 EXHAUST & EVAPO 2 16011-H1600 27 16204-08000 BLEED-SLOW AIR #100 A12 EXHAUST & EVAPO 28 16213-08000 BLEED-SLOW AIR #220 A12 EXHAUST & EVAPO 28 16052-85060 BLEED-SLOW AIR #200 A12 EXHAUST & EVAPO 1 16213-08000 29 16098-25710 FILTER A12 EXHAUST & EVAPO 30 16101-H1000 VALVE-NEEDLE A12 EXHAUST & EVAPO 31 16066-18010 SHAFT-FLOAT A12 EXHAUST & EVAPO 32 16061-18010 FLOAT A12 EXHAUST & EVAPO 33 16307-04000 COVER-PUMP A12 EXHAUST & EVAPO 34 16302-H1910 LEVER-PUMP A12 EXHAUST & EVAPO 35 16305-19915 SHAFT-PUMP LEVER A12 EXHAUST & EVAPO 36 16452-H1000 SPRING-PUMP LEVER A12 EXHAUST & EVAPO 37 16453-H1000 WASHER (T=2MM) A12 EXHAUST & EVAPO 38 16155-H1910 ARM-THROTTLE A12 EXHAUST & EVAPO 39 16161-H1911 HANGER-SPRING A12 EXHAUST & EVAPO 1170- 2 16161-H1910 39 16161-H1910 HANGER-SPRING A12 EXHAUST & EVAPO 40 16165-H1600 ARM-CHOKE WIRE A12 EXHAUST & EVAPO 41 16160-H1001 SPRING-THROTTLE RETURN (FOR 16010-H A12 EXHAUST & EVAPO 1070- 2 16160-H1000 41 16160-H1000 SPRING-THROTTLE RETURN A12 EXHAUST & EVAPO 42 16248-H1000 ROD-CHOKE CONNECTOR A12 EXHAUST & EVAPO 43 16143-H1910 ROD-PUMP A12 EXHAUST & EVAPO 44 16141-18010 ROD-CONNECTOR A12 EXHAUST & EVAPO 45 16262-H1910 DIAPHRAGM-SURVO A12 EXHAUST & EVAPO 46 16455-H1000 SET-GASKET A12 EXHAUST & EVAPO 46 16455-H6200 SET-GASKET A12 EXHAUST & EVAPO 2 16455-H1000 47 16475-H1910 SCREW & WASHER SET B A12 EXHAUST & EVAPO 48 16465-H1000 SCREW & WASHER SET A A12 EXHAUST & EVAPO
49 16009-H1910 KIT-REPAIR A CARBURETOR A12 EXHAUST & EVAPO 49 16009-H7000 KIT-REPAIR A CARBURETOR A12 EXHAUST & EVAPO 2 16009-H1910 49 16009-H6200 KIT-REPAIR A CARBURETOR A12 EXHAUST & EVAPO 2 16009-H7000 50 16455-H1000 SET-GASKET A12 EXHAUST & EVAPO 51 16307-04000 PUMP-COVER A12 EXHAUST & EVAPO 52 16009-H1911 KIT-REPAIR B CARBURETOR A12 EXHAUST & EVAPO 53 16009-H7000 KIT-REPAIR A CARBURETOR A12 EXHAUST & EVAPO 2 16009-H1910 53 16009-H6200 KIT-REPAIR A CARBURETOR A12 EXHAUST & EVAPO 2 16009-H7000 53 16009-H1910 KIT-REPAIR A CARBURETOR A12 EXHAUST & EVAPO 54 16475-H1910 SCREW & WASHER SET B A12 EXHAUST & EVAPO 55 16151-H1000 PISTON A12 EXHAUST & EVAPO 56 16129-25715 THROTTLE ADJUST SCREW A12 EXHAUST & EVAPO 56 16129-14811 THROTTLE ADJUST SCREW A12 EXHAUST & EVAPO 2 16129-25715 57 16144-B0815 IDLE ADJUST SCREW A12 EXHAUST & EVAPO 58 16098-25710 FILTER A12 EXHAUST & EVAPO 59 16101-H1000 NEEDLE VALVE A12 EXHAUST & EVAPO 60 16066-18010 FLOAT SHAFT A12 EXHAUST & EVAPO 61 16453-H1000 WASHER A12 EXHAUST & EVAPO
