Engine Control Part Numbers
Revision as of 06:56, 29 October 2012; view current revision
Categories: Engine Mechanical | Catalog
Also see:
Part Numbers Index
Main article for usage, photos, cross-reference
Throttle Cable
Choke Cable
Accelerator Pedal
RHD (including Truck)
ACCELERATOR
 1 18010-H1000 ARM COMP.-accelerator pedal MT
   18010-H1010 COMP. ARM-accelerator pedal AT
 2 18100-H1000 ARM ASS'Y-accelerator pedal MT
   18100-H1010 ASS'Y ARM-accelerator pedal AT
 3 18021-H1000 BRACKET-accelerator pedal
 4 18137-10600 RING-snap, E type
 5 08310-51014 SCREW (fixing pedal bracket to body) 2
 6 08360-63512 SCREW (fixing pedal stopper)
 7 08911-30610 NUT (fixing pedal stopper)
 8 18110-H1000 PEDAL-accelerator, foot rest
 9 08510-51214 SCREW (fixing foot rest) 2
   85-13512-12 SCREW (fixing foot rest) 2 1970
   08310-51214 SCREW 2 7510-
10 18215-27700 SPRING-return, accelerator
11 18135-14800 BUMPER
12 18036-18000 SPRING-clamp, accelerator wire
13 18200-H1000 WIRE ASS'Y-accelerator
   18200-G1601 WIRE ASSY-ACCELERATOR 7510-8910
   18201-95W00 WIRE ASSY-ACCELERATOR 8910-
14 18211-18001 RING-wire clamp
24222-89901 CLIP-WIRE, ACCELERATOR 8910- [zip tie?]
CHOKE CONTROL (non-GX)
15 18410-H1600 WIRE COMP.-choke control
   18410-H1001 WIRE COMP.-choke control ^ 18410-H1600
16 25163-H1000 ESCUTCHEON-switch
17 18415-H1000 KNOB ASS'Y-choke control
   18415-H1001 KNOB ASS'Y-choke control ^ 18415-H1000
18 25199-H1000 SPRING
19 00951-10400 GROMMET
GX (twin carb)
CHOKE CONTROL (GX)
18 18410-H2300 COMP.-WIRE, choke control (for twin carb.)
   18410-H2301 WIRE COMP.-choke control [1972]
   18410-H2302 WIRE COMP.-choke control (from '72-12) ^ 18410-H2301
19 18415-H1000 KNOB-choke control
   18415-H2300 KNOB ASS'Y-choke control [1972]
   18415-H1000 KNOB ASS'Y-choke control (from '72-12) ^ 18415-H2300
20 25169-89903  SCREW-with washer
21 24250-89929 GROMMET-choke wire
1 18010-H1902 COMP-ARM ACCELERATOR PEDAL AUTOMATIC
1 18010-H1602 COMP-ARM ACCELERATOR PEDAL MANUAL
2 18100-H1602 ASSY-ARM ACCELERATOR PEDAL MANUAL
2 18100-H1902 ASSY-ARM ACCELERATOR PEDAL AUTOMATIC
3 18017-H1600 PAD-ACCELERATOR PEDAL
4 18021-H1600 BRACKET-ACCELERATOR PEDAL
5 18215-H1600 SPRING-RETURN ACCELERATOR
5 18215-H1601 SPRING-RETURN ACCELERATOR 1070- 2 18215-H1600
6 18137-10600 RING-SNAP E TYPE
7 08310-S1614 SCREW-MACHINE M5 FOR BRACKET TO BODY FIX (3)
8 18056-H1600 BOLT-PEDAL STOPPER
9 08911-30610 NUT-HEX M6 FOR PEDAL STOPPER
10 18135-14800 BUMPER-ACCELERATOR PEDAL STOPPER
11 18036-18000 SPRING-CLAMP ACCELERATOR WIRE
 A8200-G1300 ASSY-WIRE ACCELERATOR 18200-H1600
12 18200-H1600 ASSY-WIRE ACCELERATOR
13 18410-H1601 COMP-WIRE CHOKE CONTROL
13 18410-H1602 COMP-WIRE CHOKE CONTROL 2 18410-H1601
14 18415-H1000 ASSY-KNOB CHOKE CONTROL
14 18415-H1001 ASSY-KNOB CHOKE CONTROL SEDAN & COUPE 0171- 2 18415-H1000
15 00951-10400 GROMMET
