Truck Rear Combination Lamp Part Numbers
Revision as of 22:30, 15 August 2015; view current revision
Categories: Catalog | Body Electrical System
Also see:
Part Numbers Index
Main articles for usage, photos, cross-reference:
Pickup Tail Lights
REAR COMBINATION LAMP リア コンビネーション ランプ
 1 26650-G1000 LAMP ASSY-rear combination RH     -7308 (小糸) * 26550-G1001
  ^26650-G1001 LAMP ASSY-rear combination RH 7309-7803 (小糸) SILVER
   26550-G1060 LAMP ASSY-rear combination RH 7804-8608 RIM BLACK (PARKING LAMP VENEER)
   26550-G1900 LAMP ASSY-rear combination RH 8608-     RIM BLACK (PARKING LAMP NONE)
   26655-G1000 LAMP ASSY-rear combination LH     -7308 (小糸) * 26555-G1001
  ^26655-G1001 LAMP ASSY-rear combination LH 7309-7803 (小糸) SILVER
   26555-G1060 LAMP ASSY-rear combination LH 7804-8608 RIM BLACK (PARKING LAMP VENEER)
   26555-G1900 LAMP ASSY-rear combination LH 8608-     RIM BLACK (PARKING LAMP NONE)
 2 26541-G1000   LENS-back lamp (R.H.)
   26546-G1000   LENS-back lamp (L.H.)
 3 26521-G1000   LENS-turn signal lamp (R.H.)
   26526-G1000   LENS-turn signal lamp (L.H.)
 4 26531-G1000   LENS-tail & stop lamp (R.H.) (up to '73-8) <x> 26531-G1001
  ^26531-G1001   LENS-tail & stop lamp (R.H.) (from '73-9)
   26536-G1000   LENS-tail & stop lamp (L.H.) (up to '73-8) <x> 26536-G1001
  ^26536-G1001   LENS-tail & stop lamp (L.H.) (from '73-9)
 5 26552-G1000   RIM RH -7803
   26552-G1060   RIM RH 7804- BLACK
   26557-G1000   RIM LH -7803
   26557-G1060   RIM RH 7804- BLACK
 6 25553-G1000   PACKING-LAMP (R.H.)
   25558-G1000   PACKING-LAMP (L.H.)
 7*25563-G1000   HARNESS 2     -7803
   26563-G1060   HARNESS 2 7804-8608 PIN CONNECTOR
   26563-G1900   HARNESS 2 8608-
 8 26717-89900   BULB (12V-23W) 4
   26714-89928   BULB (12V-23W SET) 7804-
 9 26717-89920   BULB (12V-23/8W) 2
   26717-89927   BULB (12V-23/8W SET) 7804-
10 26261-89900   BULB (12V-3.4W) 2 -8608
11 08310-41620   SCREW (fixing lens) 8
12 01221-00023 NUT-with washer 4 [early]
   or [after 7510]
   08911-10537 NUT
   26564-G1000 SPACER 4 [for studs]
   26565-G1200 FINISHER-LAMP PLUG 2 8910- [for back of housing]
reference:
 1974 B120 Parts Catalog C-288 page 63-2
 1997 B120 Parts Catalog C-415 page 168
