Template:Sidedraft
Revision as of 21:37, 4 September 2017; view current revision
Intake Manifold
Weber DCOE, Dellorto DHLA and Mikuni/Solex PHH use the same manifolds. Single or Twin manifolds are available, for round-port or oval-port A-series engines.
See main article: Intake Manifold
Air Filter
Many use simple screens over the carburetor, which keep large objects out of the engine. This or no screen provides the fullest "awesome sidedraft sound", but at the expense of increased engine wear.
For filtering, the easiest thing is sock filters, but all sorts of regular and remote filter can be used.
See main article: Sidedraft Air Filters
LHD Fitment
Space for twin sidedrafts on LHD 1200s is limited because the brake master cylinder is on the carburetor side of the engine.
 See main article: LHD Sidedrafts
Heat Shield
Carb heat plate
25550.jpgAlbum 25550
キャブ ヒート プレート
Adjustment
Idle Speed and Mixture Adjustment
  1. Warm engine fully
  2. Adjust curb idle speed to 900 rpm
  3. Slowly turn mixture screw out until the engine speeds up, then keep turning out until engine starts to slow down slightly (overly rich)
  4. Screw in (clockwise) until engine slows down (lean). Turn back out til it runs fastest (Best Lean)
  5. Repeat for second barrel of the carburetor
  6. If a twin-carb setup, repeat for the second carburetor
To get a 'feel' for this adjustment, turn the screw by half turns clockwise and anticlockwise till you hear the engine speed up and slow down. Then fine turn with 1/4 turns. Do this repeatedly until you are confident of the results.
Linkage
5212.jpgAlbum 5212
Linkage depends in part on the manifold you use. Does it have bolt-bosses for linkage? Or does it have built-in linkage bar?
Side Pull
Tomei manifold Side Pull. Nismo/Tomei manifold have built-in bar towers and use a large diameter cross bar
8988.jpgAlbum 8988
Center Pull
Center Pull - Need the floating lever for the carburetors. In essence, a single throttle lever, with its own balance screw
Center Pull needs only one carb-pull, eliminating the separate throttle adjustments. The center floating linka has its own balance screw
15692.jpgAlbum 15692 15691.jpgAlbum 15691
Single Carb Linkage
For bolt-style manifolds
20641.jpgAlbum 20641
Quadrant
Fan lever - Harada Shosho company
27290.jpgAlbum 27290
Nissan cable quadrant
11496.jpgAlbum 11496 11497.jpgAlbum 11497 11368.jpgAlbum 11368
Generic cable bracket
11506.jpgAlbum 11506
Throttle Lever
Universal carby throttle lever
556.gifAlbum 556
