Sidedraft Air Filters
From Datsun 1200 Club
Category: Fuel System
Many use simple screens over the carburetor, which keep large objects out of the engine. This or no screen provides the fullest "awesome sidedraft sound", but at the expense of increased engine wear. For filtering, the easiest thing is sock filters, but all sorts of regular and remote filter can be used.
Focusing on Weber DCOE carburetor, Dellorto DHLA and Mikuni PHH.
Also see: Hitachi Twin Carb (SU-type) air filter
14133.jpgAlbum 14133 15390.jpgAlbum 15390
No Filter
At the expense of increased engine wear, using no filter or air horn allows LHD Sidedrafts.
3464.jpgAlbum 3464 11838.jpgAlbum 11838 11839.jpgAlbum 11839
Air Horns
Air horns provides the fullest "awesome sidedraft sound" and also a performance boost (the length can be changed to match the desired power peak).
174_4de174af193c2.jpgUpload click to view 8494.jpgAlbum 8494
A velocity stack (air horn), is a trumpet-shaped device of differing lengths fitted to the air entry of an engine's carburetor. It is designed to:
  1. Allow smooth and even entry of air at high velocities into the intake tract with the flow stream adhering to the pipe walls known as laminar flow.[2]
  2. Modify the dynamic tuning range of the intake tract by functioning as a resonating pipe which can adjust the frequency of pressure pulses based on its length within the tract.
19060.jpgAlbum 19060 136.jpgAlbum 136
Screen
Screen is simple mesh covering over the air intake. It only prevents large objects from entering the engine.
Sock Filter
1402.jpgAlbum 1402 9578.jpgAlbum 9578 {{Album|2031]]
Air Cleaner
Traditional paper or foam-covered paper air filter.
6332.gifAlbum 6332 2656.jpgAlbum 2656 1642.jpgAlbum 1642 24885.jpgAlbum 24885 16537.jpgAlbum 16537
Uniflow
14133.jpgAlbum 14133 787.jpgAlbum 787 3503.jpgAlbum 3503
Box Filter
23971.jpgAlbum 23971
GX Air Cleaner
N13 Filter
For an overview of modifying the Pulsar air box, see Air Cleaner#N13.
7766.jpgAlbum 7766
Retrieved from "http://datsun1200.com/modules/mediawiki/index.php?title=Sidedraft_Air_Filters"
This page has been accessed 10,736 times. This page was last modified 02:16, 24 January 2018. Content is available under Datsun 1200 Club.
