Starting August 1979 -- factory aircon installation with new compressor type. It is a very nicely designed unit, however the interior cooler protrudes into the passenger legroom and precludes using a package tray.
From August 1979 a uniform kit was offered with DKKC (Diesel Kiki) radial-type compressor.
B110 1970-1976 All custom, various types B120 1978-1979 Factory high-idler mount B120 1979- Factory low-idler pulley mount
This kit is beautiful and easy to install. Unfortunately the interior cooler unit is bulky and protrudes farther into the passenger legroom than other types.
Set Parts
- Ass'y indoor "#cooler unit" (with integrated air volume switch, evaporator, and blower fan)
- air conditioner compressor
- V-belt: 814 mm
- #Compressor Bracket
- G16 Crankshaft Pulley (double-groove V-belt type)
- Twin Condensors (before radiator, radiator horizontal)
- One has an electric fan
- Pipe connecting twin condensors
- High-pressure flexible pipe (from compressor to condensor)
- Low-pressure hose (from evaporator to compressor)
- Tube-Liquid Tank to Evaporator
- Receiver/dryer (Liquid Tank)
- Bracket to mount Tank on core support
- Relay (for compressor)
- Wiring harness
- Capacitor for electric fan
Vents may be opened or closed:
Twin Condensors and Liquid Tank with connecting pipes.
Condensor-to-Liquid Tank hose is routed along the top of core support.
Compressor is mounted low on left side of engine.
Cooler Unit lines: Evaporator Inlet & Outlet and drain hose
Compressor Bracket
Bracket is identified with 1) low-mount idler pulley 2) two large oval opening in bracket
- Bracket 593017 6100 w/low-mount tensioner
Low-mount Pulley (1979-up) for radial type compressor
Interior Unit
The inside unit is a one-box solution comprising evaporator core, vents, switches and fan, and fits underneath the passenger side of the dash.
Fast Idle Control
From 1978-1989, no special idle control device was used. From Oct 1989 they added FICD.
See Main Article: FICD#Sunny_Truck
COOLER KIT 27600 B7600-G1660 -7907 B7600-G1661 7908-8110 B7600-G1662 8110-
COOLING UNIT 27610 27610-H7900 COOLING UNIT ASSY 7804- DKKC 27616 BRACKET-COOLING UNIT NO 2 DKKC 27616-G1660 7804-8109 27616-G1900 8110- 27618 BRACKET-COOLING UNIT NO 4 DKKC 27618-G1660 7804-8109 27618-G1900 8110- 27619 HOSE-DRAIN DKKC 27611-G1660 7804-8109 27611-G1900 8110- 27619E 27363-18200 GROMMET-DRAIN HOSE DKKC 7804-8503 27620 27612-T3020 EVAPORATOR ASSY-COOLER 7804- 27624 27613-B8520 VALVE-EXPANSION DKKC 7804- 27626 TUBE-EVAPORATOR INLET DKKC 27785-G1660 7804-8109 27785-G1900 8110- 27626E GROMMET-EVAPORATOR TUBE 01651-00015 7804- INLET TUBE インレツト チューブ ヨウ 27363-18200 7804- 2 OUTLET TUBE アウトレツト チューブ ヨウ DKKC 27628 TUBE-EVAPORATOR OUTLET DKKC 27787-G1660 7804-8109 27787-G1900 8110-
COMPRESSOR & HOSES 27630 COMPRESSOR-COOLER DKKC 27630-G1660 7804-7907 [YORK TYPE] 27630-W7001 7908-8109 [SWASH TYPE, ANGLED OUTLET] 27630-W7002 8110-8910 <> 27630-W7001 92610-G1900 9810- [NON-ANGLED OUTLET] 27681 HOSE-FLEXIBLE, HIGH [to condensor] 27776-G1660 7804-7904 DKKC 27776-G1661 7908-8910 DKKC 92490-95W00 8910- 27781M HOSE-FLEXIBLE, HIGH [2ND PIECE] 92447-95W00 9810- 27682 HOSE-FLEXIBLE, LOW DKKC 27775-G1660 7804-7907 27775-G1661 7908- 27688 01651-00025 GROMMET-DASH DKKC 7804-8910
CONDENSORS, LIQUID TANK & PIPING 27640 27640-G1660 TANK ASSY-LIQUID DKKC 7804- 27640E BRACKET-LIQUID TANK 27642-G1660 7804-8910 DKKC 92135-95W00 8910- 08360-81426 SCREW 27650 CONDENSOR ASSY 27651-G1660 7804-8910 DKKC 92110-95W00 8910- 27650M CONDENSOR ASSY-SUB 27653-G1660 7804-8910 92111-95W00 8910- 08360-61626 SCREW 08911-10637 NUT 27653F 27655-G1660 FAN-CONDENSOR 7804- DKKC 27678 TUBE-CONDENSOR TO LIQUID TANK, 1 27780-G1660 7804-8109 DKKC 27780-G1661 8110-8910 92446-95W00 8910- 27681M TUBE-FLARE 27660-G1660 7804-8910 DKKC 92448-95W00 8910- 27683 TUBE-LIQUID TANK TO EVAPORATOR 27783-G1660 7804-8910 DKKC 92441-95W00 8910- 27683E 27691-G1660 CLAMP-TUBE 7804- DKKC 08543-51012 SCREW
27706 27706-65000 REFRIGERANT-COOLER 7804-
