Heated rear glass (electric rear defroster/defogger/demister) was an option for Sedan & Coupe. Canada 1200s included it as standard equipment.
1972 facelift dash
Operation
1972 USA Owners manual (Page 13 ... ):
Instrument and Controls
HEAT GLASS SWITCH (Optional)
The rear heat glass incorporates a printed heating element to prevent frosting or icing. To heat the rear glass pull out on the glass heat switch with the ignition switch placed in the "ON" position. A pilot lamp glows when the switch is pulled out.
Switch
The switch is bolted to the bottom edge of the dash, to the side of the steering wheel. A pilot lamp glows when the switch is pulled out.
25230-H2200 SWITCH-HEAT GLASS OP. 1270- 08510-51212 SCREW 2 OP. 1270-
Extra wires added. Purpose of the small lights is unknown
ACC on the Ignition Switch feeds the rear defroster.
Parts
OPTIONAL COUPE, 4-door SEDAN including PB110 #25230-H2200 SWITCH-HEAT GLASS 1270- 79713-H2200 GLASS-rear window Coupe 79713-H2900 GLASS-rear window Sedan 24161-H2200 CABLE ASS'Y-rear heat glass A 24162-H2200 CABLE ASS'Y-rear heat glass B (l=400mm) Sedan 24163-H2200 CABLE ASS'Y-rear heat glass C (l=350mm) Coupe
