The Dash Side Trimming covers the side of the foot well, just forward of the front doors. These are popularly called "Kick Panels". The factory right and left speakers are mounted on the kick panel. The flare may be attached to the passenger-side panel.
- The panels have a cut-out area for the (optional) speaker, which can easily be removed and discarded in order to fit the speaker.
- There is also a kidney-shaped/triangular plug in each panel, which gives access to the lower Door Hinge bolts. The plug differs RH to LH.
- panels and plugs came in Black (early 1200), Brown (1978-1988) and Gray (1989-up)
- panels are the same RHD and LHD
- panels are the same for sedan, coupe, van and truck
Shape
Right-side panel. With speaker cut-out intact. Unless the optional stereo is installed, no speaker is mounted on this side.
Left-side panel. The extra two holes are used to mount the flare bracket]] for the Japan market.
Flare
For the Japan market, the Emergency Signal flare was mounted to the kick panel:
Nissan 26890-89900 Red Fuse Effective date 1981 January End date 1982 February 5![]()
Holder 26885-89900 HOLDER-lamp -7301 26895-89900 HOLDER-EMERGENCY SIGNAL 7302- [26885N]![]()
ハツエントウ Warning Flare
Custom
Carbon Fibre kick panels have been made.
Kick panels with designed speaker enclosure:
NOTE: the kick panel is called 'Dash Trim' later 'Dash Side Finisher'
- 66900-H1101 TRIM-DASH SIDE RH -7803 Black
- 66901-H1601 TRIM-DASH SIDE LH -7803 Black
- 66901-G1060 FINISHER-DASH SIDE, RH 7804-8910 BROWN
- 66900-G1060 FINISHER-DASH SIDE, LH 7804-8910 BROWN
- 66901-95W00 FINISHER-DASH SIDE, RH 8910- GRAY
- 66900-95W00 FINISHER-DASH SIDE, LH 8910- GRAY
- 08540-41012 SCREW-TAPPING (4)
- 08915-43420 WASHER-PLAIN (4)
- 08410-61212 SCREW-MACHINE
- 08410-61220 SCREW-MACHINE
- 36528-22500 WASHER-PLAIN
- 66904-H1001 PLUG-DASH SIDE RH -7803 [black]
- 66905-H1001 PLUG-DASH SIDE LH -7803 [black]
- 64891-W5000 PLUG 7804- D=30
- 66919-H1001 CLIP-trimming -7804 (6) BLACK
- 66919-G1060 CLIP-trimming 7804-8910 (6) BROWN
- 66919-95W00 CLIP-trimming 8910- (6) GRAY
Dash side plugs — right (plain-shaped) and left (kidney-shaped)
キッキングボードのフタ カバー 左右セット
サイド トリム スピーカー 保安炎筒ホルダー
サイド パネル
