E15ET
Revision as of 23:34, 26 February 2022; view current revision
Category: Nissan Engines
The famous <E15ET> Nissan Turbo engine was the pinnacle of the Nissan E Engine design. It produced 115 hp (86 kW).
Also see E-series Engine Swap
Power
Turbo Power! Right from the factory. Some question whether a regular E15 has any real advantage over an A15, but there is no question that the E15ET (the turbo version) is a superior design. The cylinder head flows more than other E-series engines.
E15ET Stock
* 115PS (85 kW; 113 hp) JAPAN
* 106PS (78 kw; 105 bhp) AUS N12 Exa
* Torque 116 lb-ft (157Nm) AUS
* 7.8:1 Compression Ratio
* 7.3 - 7.4 psi boost (7psi nominal)
* T02-style turbo with internal wastegate
Modified
112.6 kw @ 5650 rpm
200 Nm @ 4322 rpm
6952.jpgAlbum 6952
The connecting rods are 3mm shorter than E15 rods, resulting in lower compression ratio of 7.3:1. This along with the low boost level results in suitable use with Regular octane fuel.
For 1986, the ET model also saw its 1.5-liter turbocharged engine updated for unleaded fuel, boost increased but power decreased.
Sources
See also: Pulsar N12
400px-1985_Nissan_Pulsar_(N12)_EXA_Turbo_coupe_(2015-07-25)_01.jpgWIKI go to Wikipedia
18115.jpgAlbum 18115 18116.jpgAlbum 18116 12901.jpgAlbum 12901 12900.jpgAlbum 12900
Turbo
Nissan N12 Pulsar NX Turbo (USA) 0283-0784
Nissan Cherry Turbo (EUR)
* 14411-17M00 TURBOCHARGER
** M26 AR .47
AiResearch M10/ Garrett TB020
AiResearch M10 turbocharger from Nissan Sunny B11 (JDM)
* 14411-56A00
tmatpit103-img600x450-1269504871u7k0hb23547.jpg tmatpit103-img600x450-12695048719lgz2e23547.jpg tmatpit103-img600x450-1269504871zmvjt823547.jpg 1cc4.jpg aba2.jpg
Distributor
See Main Article: Hitachi D4P Distributor
