<-- back to B210 Japan Brochures
Title: DATSUN Sunny Excellent 1400 [brown 1400 GL sedan in front of the sea and sailboat]
1975 Sunny Excellent 1400 GL/GL-L sedan & coupe PB210
Format:8 pages Size:unknown Publication Number:unspecified 30cm x 25.5cm
Comments? Questions? More photos or info? Reply to main forum: POST Brochures wanted
01 Cover
1975 October - DATSUN Sunny Excellent 1400
話題のNAPSを搭載。50年排出ガス規制適合車。
Equipped with the topic NAPS. Vehicles that meet the 1975 emission regulations.
02-03 Coupe & Sedan
04-05 Features
Coupe GL-L dash Coupe GL-L interior EXH TEMP lamp Voltmeter ELR Seat Belts AM-FM radio Trunk Opener (GL-L) Heated rear glass ? Cigarette Lighter 100 Yen coin holder console
06-07 Trim Grades
SEDAN GL-L GL
COUPE GL-L GL
08 Back Cover
サニーエクセレント1400-NAPS車 主要諸元
Sunny Excellent 1400-NAPS car main specifications
| DATSUN A-PB210 | Sedan | Coupe | ||
| grade | GL-L | GL | GL-L | GL |
| 4-speed floor shift | 1PB210GTH | 1PB210GT | 1KPB210GH | 1KPB210G |
| NissanMatic floor type | 1PB210GAH | 1PB210GA | 1KPB210AH | 1KPB210GA |
| DIMENSIONS | ||||
| total length mm | 4045 | 4045 | ||
| width mm | 1545 | 1545 | ||
| height mm | 1370 | 1350 | ||
| wheelbase mm | 2340 | 2340 | ||
| tread front/rear mm | 1275/1265 | 1275/1265 | ||
| ground clearance mm | 165 | 165 | ||
| Weight | ||||
| curb weight kg | 915(930) | 915(930) | ||
| Occupants | 5 | 5 | ||
| Gross weight kg | 1190(1205) | 1190(1205) | ||
| Performance | ||||
| top speed km/h | 155(145) | 155(145) | ||
| tan angle | 0.49(0.47) | 0.49(0.47) | ||
| turning circle m | 4.7 | 4.7 | ||
| fuel economy | 19.0(17.5) | 19.0(17.5) | ||
| Engine | ||||
| engine family | L14 type | |||
| type | overhead cam (OHC) 4 cylinder | |||
| displacment cc | 1428 | |||
| compression ratio | 9.0 | |||
| horsepower PS/rpm | 85/6000 | |||
| torque kgm/rpm | 11.8/3600 | |||
| carburetor | single | |||
| Mechanism | ||||
| suspension front | mcpherson strut | |||
| suspension rear | leaf spring | |||
| shock absorber | ? | |||
| transmission | 4-speed full synchro | |||
| (6 position Nissan Matic) | ||||
| ratio 1st | 3.657(2.458) | |||
| ratio 2nd | 2.177(1.458) | |||
| ratio 3rd | 1.419(1.000) | |||
| ratio 4th | 1.000(----) | |||
| ratio REV | 3.638(2.182) | |||
| brakes front | master-back with disc | |||
| brakes rear | leading/trailing type | |||
| tires | 6.15-13-4PR | |||
| fuel tank l | regular gasoline 44 | regular gasoline 43 |
Colors
BODY COLOR & SEAT TRIM 211 olive green (metallic) 212 blue 216 white 214 SEDAN brown (metallic) 213 COUPE wine purple (metallic)
EQUIPMENT LIST
wood grain type steering steering lock tachometer OPTION meter Coupe only meter Coupe only meter radio GL AM-FM radio GL-L, GL.OPTION fiberscope knobs GL-L, GL.OPTION cigarette lighter ? brake ? passing light package tray inside mirror
ELR 3-point seat belts 2-point seat belts cross seat (low back) GL-L front seatback pocket GL-L sunvisor heater control panel GL-L side ventilator rear window large console box trash box GL-L, GL.OPTION anti-sun glass large door armrest GL-L 2? check type door key store lock trunk opener SEDAN.GL-L, GL.OPTION fastener tonneau cover COUPE GL-L, GL.OPTION
? wiper fender mirror accent stripe OPTION sill moulding GL-L, GL.OPTION fog lamp OPTION
MECHANISM tandem master cylinder collapsible steering disc brake masterback
