The Hitachi LR series of internally-regulated Alternator was first fitted to North American B210 for the 1978 Model year. It weighs about 2-1/2 pounds more than a stock Datsun 1200 35A model and about 1 pound more than an externally regulated 50A Hitachi. The LR160 60 amp model is physically identical, and was first used around 1983.
- LR160 - 60A, second from left
- Engine-mounting side is 80 mm (~3-3/16") in between ears, same as stock Datsun 1200
- 10.5mm diameter mount holes
- front flange (bolt ears) 13mm thick
- Adjuster ear 175mm (~6-7/8") across. The stock 1200 unit is smaller at 156mm (~6-1/8") from the mount ear.
- So you may need a late A12 adjuster and fan belt
- threaded for M8x1.25 bolt
- About 129mm diameter.
- Fan belt center: 29mm from front bolt face
- Pulley diameter: 69mm
Parts
B210 1978, B310 50 amp Hitachi LR150
- 23100-H7703 B310 0381-
- replaces 23100-H7702 B310 0580-0281
- replaces 23100-H7701 B310 0978-0480
- replaces 23100-H7700 B210 0877-, B310 -0878
- BOSCH AL238X, AL241X $71.99 at RockAuto.com
- BBB PRECISON 14255
- REMY 14185
- BECK/ARNLEY 1860266
- ACDELCO 321-1265 {#10463708}
LR160 60 Amp
- 23100-W5807 Hitachi LR160, replaces 23100-W5805, 23100-W5806
- BOSCH AL241X
- BBB PRECISON 14587
- ACDELCO 3341661 {60 AMP #19134654}
- REMY 14301
Sources
LR150
- Datsun 200SX (1978 - 1979)
- Datsun B210 1978
- Datsun 210 (1979 - 1982)
- Datsun 310 (1979 - 1982)
- Datsun 510 (1978 - 1981)
- Datsun 720 PICKUP (1981 - 1985)
LR160
- Datsun 200SX (1978 - 1983)
- Datsun 310 (1979 - 1981)
- Datsun 310 DELUXE 1982
- Datsun 310 GX (1980 - 1982)
- NISSAN PULSAR 1983
- NISSAN PULSAR NX (1983 - 1986)
- NISSAN PULSAR NX TURBO 1983
Brushes
Brush Assembly LR150 (B210 from 0877)
- 23135-P2500 BRUSH ASSY LR150
- 23133-P2501 BRUSH REGULATOR ASSY LR150 replaces 23133-P2500
- Includes IC regulator
- STANDARD MOTOR PRODUCTS Part # VR592
Regulator
B210 1978 Internal IC Regulator (requires soldering)
Others
Round I-L-S connector
- may fit stock adjuster bracket (156mm mounting)
- Use with 4mm spacer (extra washers) on engine rear mount bolt
Hitachi LR160-723
- 1990-1993 Nissan Pickup
Hitachi LR150-704
- 1989-1992 Isuzu Amigo
- 1988-1992 Isuzu Pickup
- 1991-1992 Isuzu Rodeo
- 1987-1991 Isuzu Trooper 2.3
Hitachi LR150-718
- NOTE: 175mm mounting
Squared-Round S-L connector
Hitachi LR170-734B/739B/745 (about 1/2 kilo heaver that LR160)
- NOTE: 8.5 mm (smaller) mounting holes
- NOTE: Large 77m pulley
- 1990-1995 Nissan Pathfinder
- 1990-1995 Nissan Pickup
