Ignition Switch
Revision as of 07:15, 2 August 2009; view current revision
The Datsun 1200 ignition switch is also known as an "Ignition Starter Switch". For Japan, it is integrated into the Key lock switch. For USA, it bolts to the back of the key cylinder.
STD and DX 1200s built for Japan market have a dash-mounted switch (instead of steering column-mounted). The lock & ignition switch are integrated with only two or three spade terminals on the switch.
See Keys
GL and GX models use same/similar to USA ignition switch.
North America
For USA, the ignition switch bolts to the back of the key cylinder. A a rectangular wire connector from the dash harness attaches to it. It is not strictly part of the Key lock & barrel, but bolts to it.
Fitment
Lock Comparison - No ACC position for 1971, there is corresponding change to the igntion switch.
(the two wires at the front of the cylinder are for the Warning Buzzer system)
Replacement switches are of the 1972 type, which can mate to the 1971 4-terminal connector or the 1972 6-terminal connector.
Also see Key Lock Cylinder
1972-1973
  • ACDelco E1406
1971-1973
4973.jpg Ignition Switch Comparison
  • B110 Small size ~28mm diameter
  • B310 Large size ~34mm diameter. Also used by newer B110
  • The long-wired switch may be B210? It looks like it would plug into the Small B110 harness, but is wired differently. Beware!
The larger-diameter switch has two mounting lugs and is used with Keylocks that have an ACC position. 1972 and 1973 1200s use this.
The small-diameter switch has one bolting lug. It was used on 1971 B110 (and any without ACC position).
ACDelco E1406 ignition switch also fits:
  • 1970-1973 Datsun 240Z
  • 1971 Datsun 510
  • 1971-1972 Datsun 1200
Beck/Arnley 2011174 Fits:
  • Subaru
    • 1982-1987 Brat
    • 1986-1987 GL
    • 1980-1984 DL
    • 1980 GLF
    • 1980 GL
    • 1980-1987 Standard
  • Datsun
    • 1968-1973 510
    • 1970-1978 240Z, 260Z, 280Z
    • 1979-1983 280ZX
    • 1971-1973 1200 (B110)
    • 1979-1982 210 (B310)
    • 1978-1981 510 (A10)
    • 1977-1981 810 (Bluebird)
    • 1982-1983 Maxima (910 Bluebird)
    • 1979-1982 310 (N10)
    • 1977-1983 200SX (S10)
The 1971 switch has four spade terminals. The 1972 and newer adds the "Accessory" position and so has five spade terminals.
TIP: On the back of the switch, each contact is marked ('S', 'IG', etc.). Double-check before replacing to ensure they are the same.
North American Wiring
WB (Battery)
BW or IG (ignition/Run)
BW (LW for B210)ACC (Accessory)
1971 switches didn't have ACC position
BY (YB for B210)S (start)
BRR (resistor)
The switch in the picture with the wires has differently colored wires (WR, L, BL, BW, BY). From these colors and position, I think it is the same wiring as the B310 switch, just different colors.
Switch
Switch internal connections
Offno connections
AccessoryBattery (hot) to ACC
RunBattery (hot) to ACC + IG
StartBattery (hot) to IG + Resistor + Start\*
\*Starting with 1974 automatic models and all newer, ACC is also hot while in the Start position.
Where do the wires go on a stock B110?
switch terminalConnects to ...
IG (ignition/run)This connects to two things:
  • Directly to Ballast Resistor (non-coil side). This is spelled "Resister" in some Nissan publications. If equipped with optional factory tachometer, this circuit goes through tachometer
  • To IG circuit of fuse box
S (start)
  • the solenoid on the starter
On automatic cars*, this goes through the "Nuetral Switch".
B (battery/hot)
  • battery + terminal, through the fusible link
  • Fuse box "B" side
  • Alternator "A" large output wire
  • Voltage regulator "A" terminal
R (resistor)
  • Coil + terminal
  • Ballast resistor (coil side)
ACC (accessory)
  • Radio (through inline fuse)
Since 1971 didn't get ACC position, 1971 radios connect to fuse box L wire (always hot)
  • Optional heated rear window glass
  • Note that this circuit does NOT go to the fuse box, as does Bat and IG
\*Automatics became available in 1973 in North America.
Common Problems
Ever had the "sometime it doesn't start until I turn the key back and forth a few times" problem?
This occurs because the relatively high current loads of the starter solenoid tend to burn the ignition switch Start contacts after some years. This only gets worse. You might think you could prevent this problem by using a relay. The S wire could go to to a relay, and the relay could go from the Main Fuse to the starter. The problem is if the relay sticks, you won't be able to turn it off with the key. To prevent this, you could use two relays, with the main power fed through a relay connected to the IG terminal of the switch. Then if the starter relay sticks, you could turn key to ACC or OFF to stop it.
It is easiest just to replace the switch.
