Bumper
Revision as of 04:36, 15 March 2009; view current revision
Category: Body
Adorning the extreme ends of the Datsun 1200 are chrome bumpers. Although the front bumper is shared by all models, the rear bumper differs between Coupe, Sedan, and Van/Wagon(VB110). The front bumpers have bolt holes for USA and Japan license plates (two sets of holes).
Front
The front bumper of a 1200 is a fairly straight chrome bar and has two small notches on the bottom for the front turn-signal lights:
The front bumper is in three pieces:
  • Two long front sections (left and right) that curve and the end to wrap around the side just a little
  • a shallow degree binding piece (the front bumper is a slight V)
It is sold as one piece.
B140 Bakkie
The B140 Bakkie has a larger flat bumper, painted black, with lights in the face.
Rear
  • Sedan rear bumper has a small light in the center facing up to illuminate the license plate
  • Coupe bumper has a notch for the license plate:
  • Wagon is smooth with no notch and no lights:
  • B120 Ute had two small rubber pads, and two black corner bumperretes:
The regular rear bumper is in three pieces:
  • Long center section that varies between Sedan, Coupe and Wagon
  • Two end caps, left and right, that wrap around the side a little bit
It is sold as three pieces.
B140 Bakkie
The B140 Bakkie rear has the standard two rubber pads, and also black corner bumperettes, with lights in the face.
1973 USA Bumpers
For 1973, USA models got large bumper pads, although the chrome parts are the same. They also used redesigned bumper-to-body brackets.
New Zealand
Some B120 SportStar utes had black bumpers:
Custom Bumpers
Bumperettes
USA Catalog
  • 62651-H7000 ASSY-BUMPER,FRONT Sedan, Coupe from 0772 $178
  • 62651-H1000, H1001, H1900 ASSY-BUMPER,FRONT Sedan, Coupe
  • 85011-H7000 BUMPER-REAR CENTER Sedan from 0772
  • 85011-H1900 BUMPER-REAR CENTER Sedan
  • 85011-H7100 BUMPER-REAR CENTER Coupe from 0772
  • 85011-H1905 BUMPER-REAR CENTER Coupe
  • 85012-H1000 BUMPER-REAR RH Coupe, Sedan
  • 85013-H1000 BUMPER-REAR LH Coupe, Sedan
NOTE: 1973 parts fit older brackets, but older bumper doesn't fit newer brackets.
Japan Catalog
  • 62651-H1000 ASSY-BUMPER,FRONT
  • 62651-H1001 ASSY-BUMPER,FRONT from 0870 (interchanges with former)
  • 85011-H1000 BUMPER-REAR CENTER Sedan
  • 85011-H1800 BUMPER-REAR CENTER Coupe
  • 85011-H1400 BUMPER-REAR CENTER Van
NOTE: PB110 front bumper is unique, but PB110 rear bumper is same as B110.
Sunny Truck
  • 62651-H1025 ASSY-BUMPER,FRONT Truck 7510-7803 (one piece)
  • 62650-G1060 ASSY-BUMPER,FRONT Truck 7804-8910 (three-piece)
  • 62650-95W00 ASSY-BUMPER,FRONT Truck from 8910
  • 62024-G1060 BUMPER-FRONT RH from 7804
  • 62025-G1060 BUMPER-FRONT LH from 7804
  • 85010-G1001 RUBBER-REAR BUMPER, SIDE RH 7510-7611
  • 85010-G1002 RUBBER-REAR BUMPER, SIDE RH 7612-
  • 85011-G1001 RUBBER-REAR BUMPER, SIDE LH 7510-7611
  • 85011-G1002 RUBBER-REAR BUMPER, SIDE LH 7612-
