The wiper motor bolts to the engine compartment firewall. LHD cars sweep to the left, RHD sweeps to the right. For the windscreen washer, see Kangaroo Bag.
Wiper Motor
As with the rest of the wiper system, RHD and LHD are reversed. RHD models have the wiper motor on left side, just below the left bonnet hinge.
LHD 1200s have the wiper motor just below the right hood hinge.
Nissan 28810-H1601,28810-H1602,B8810-H1900,28810-H1600 ASSY-MOTOR (ISO THREAD)
- Hollander 160 (1971-1972)
- Hollander 1061 (1973)
- Crown remanufactured No. 431205 - $80.99 USD
Wiper motor fits Datsun 1200 only. B210 wiper *may* fit but the electrical connectors are different (round vs. rectangular)
Intermittent Wipers
Some B310s had intermittent wipers. Apparently the motor is the same, but there is an "amplifier" box. Perhaps it can be adapted to the 1200.
Later Sunny Truck came with intermittent wipers. This may be a direct bolt in. You would need the amplifier and wipe switch.
Wiper Arms
The arms are the part outside the windshield, minus the blade.
RHD
- 26380-H1000 ARM ASS'Y-wiper ALL (except GX)
- 26380-H2300 ARM ASS'Y-wiper GX
LHD
- 26380-H1600 ASSY-ARM WIPER
ID marks:
* upper: '56L' underneath by spring
* lower: 'AE' mark on top, visible when installed
Wiper Arm Comparo: B110 vs B210 (Left-hand drive)
Wiper Blades
The blade is the part that holds the rubber inserts (refills).
To separate arm from blade, insert knife as shown to lift up tab. Then pull the blade off the arm.
Datsun 1200 uses 16" (405mm) wiper blades. The original blade was a stainless steel design marked "56L" on the bottom and "AE" on top. This blade takes 5/16" wide refills (9mm).
GX-5 option: For high-speed stability, it has a built-in wind spoiler
Refills
For stock wiper arms, the refills are 16" long x 5/16" "Universal" style.
NOTE: over the years many 1200 blades have been replaced quick-replacment types, so your 1200 may have something else.
- NAPA 762-3164
- Package say "Standard" type
- TRICO 44160
- 44 Series Universal wiper refills are designed to fit most long frame TRICO, Tridon, Roberk, Anco, Pylon and Original Equipment plastic blades. Designed with metal end clips for ease of installation.
RHD
- 26360-H1000 BLADE ASS'Y-wiper ALL (except GX)
- 26360-H2300 BLADE ASS'Y-wiper GX
- 26370-A4600/A4601 BLADE ASS'Y-wiper GX-5, Optional ALL (same as Datsun 510 SSS/CSS blades)
- B6370-89901 OLD Type L=400 Black
LHD
- 26375-U5200 ASSY-BLADE WIPER [Option, High Speed]
- replaces 26375-A4601 ASSY-BLADE WIPER OP
- replaces 26375-A4600
- 26360-B5200 ASSY-BLADE WIPER [non-High Speed] B210
- 26375-H7700 ASSY-BLADE WIPER [Matte Black, 1978) B210
Linkage
See main article: Wiper Wiring
Raw Parts List
- 034 001 B8800-H1900 ASSY-DRIVE WINDSHIELD WIPER 1 0570-
- 034 001 28800-H1602 ASSY-DRIVE WINDSHIELD WIPER 1 1072- 2 B8800-H1900
- 034 001 28800-H1600 ASSY-DRIVE WINDSHIELD WIPER 1 -
- 034 002 28810-H1600 ASSY-MOTOR(ISO THREAD) 1 -
- 034 002 B8810-H1900 ASSY-MOTOR(ISO THREAD) 1 0570-
- 034 002 28810-H1602 ASSY-MOTOR (ISO THREAD) 1 1072- 2 B8810-H1900
- 034 003 26389-H1600 ARM-WIPER MOTOR 1 -
- 034 004 28835-H1600 ASSY-BRACKET WIPER MOTOR (ISO THREAD) 1 -
- 034 005 26389-73000 RING-STOP 1 -
- 034 006 28860-H1600 ASSY-CONNECTING ROD NO.1 1 -
- 034 007 28865-H1000 ASSY-CONNECTING ROD NO.2 1 -
- 034 008 28870-H1600 ASSY-PIVOT NO.1 1 -
- 034 009 28875-H1000 ASSY-PIVOT NO.2 1 -
- 034 010 08360-61614 SCREW MOTOR FIX 3 -
- 034 011 08915-43610 WASHER MOTOR FIX 3 -
- 034 012 08320-51419 SCREW MOTOR FIX 6 -
- 034 013 28876-H1000 SEAL-PIVOT WINDSHIELD WIPER 2 -
- 034 014 26380-H1600 ASSY-ARM WIPER 2 -
- 034 015 26375-A4600 ASSY-BLADE WIPER 2 OP -
- 034 015 26375-A4601 ASSY-BLADE WIPER 2 OP - 2 26375-A4600
- 034 016 26381-H1000 NUT-WIPER ARM 2 -
