A12A
Revision as of 07:15, 26 February 2011; view current revision
Category: Engine Mechanical
A12A engine (1237cc) was used 1978-1982. It has a 75mm bore, larger than an A12 (1171cc) engine with 73mm bore. The A13 Engine has a 76mm bore. The block is virtually identical to the original 1974 A12. The A12A is a 1237cc engine. It used a casting similar to the A12 and same stroke, but machined with a larger bore for an increase of 66 cc capacity. The A12A shared a common block and crankshaft with the redesigned A12 and A13 engines.
6713.jpg A12A ID Mark
12223.jpg Chassis Plate
Applications
  • 1980-1982 'Datsun 210' B310 USA and Canada
  • 1980-1982 Datsun Sunny B310 Japan and Asian markets
  • 58 HP
  • 1237 cc (original A12 was 1171 cc)
  • 75 mm bore (2mm larger than A12)
  • same stroke as A12
CYLINDER BLOCK ASSY
  • 11010-H9960 A12 USA 0879-
  • 11010-H8500 A12 CAN 1278-0779
  • 11010-H8502 A12 CAN ^11010-H8500
  • 11010-H9001 A12 CAN 0879- °11010-H8502
229.jpg 1977.jpg 4444.jpg 4711.jpg 4712.jpg 5522.jpg 5793.jpg 6554.jpg 6713.jpg 8122.jpg 12223.jpg 15171.jpg 15779.jpg 17147.jpg 17148.jpg
