The Rear Engine Crossmember is more commonly called the gearbox crossmember. This transmission crossmember hold the rear engine insulator(transmission mount). The B210 and B310 crossmembers are wider than the B110 crossmember.
Manual Transmission
B110
- 11322-H1002 MEMBER-engine mounting, rear 3-speed, 4-speed
- 11322-H7200 MEMBER-engine mounting, rear 5-speed
Others
- 11322-H5000 MEMBER-engine mounting, rear 3-speed, 4-speed (56-series)
- 11322-H7400 MEMBER-engine mounting, rear from 7510 Van (also replaces 11322-H5000)
- 11322-H7500 MEMBER-engine mounting, rear A14 B210 60-series 4-speed
- 11322-H5700 MEMBER-engine mounting, rear A12 5-speed F5C56
- 11341-H7500 MEMBER-engine mounting, rear A14 B210 5-speed 63-series
NOTE: 11340-H8500 superceded 11340-H8600, which superceded 11340-H8610
Automatic Transmission
- 11322-H1020 MEMBER-engine mounting, rear Automatic B110
- 11322-H5200 MEMBER-engine mounting, rear Automatic early B210
- 11340-H7500 MEMBER-engine mounting, rear Automatic late B210
- 11341-H8700 MEMBER-engine mounting, rear Automatic B310
Rubber Insulator
There are different types of rear insulators.
The 56-Series Transmission type of mount bolts to the crossmember from the sides of the mount, just like these stock 1200 mounts:
This type, used with 60-Series Transmission, straddles the crossmember and bolts from the bottom:
Automatic is yet again different.
56-series
- PN 11321-H1000 INSULATOR ASS'Y-engine mounting, rear manual trans $35.83 USD
- 11321-H1000, 11321-H5000, 11320-H5000 the same?
B10
60-series
- 11321-H7500 INSULATOR ASS'Y-engine mounting, rear manual trans: A14 B210 4-speed (60-Series)
- 11320-H9100 INSULATOR-ENGINE MOUNTING REAR B310 5-speed (60-series) from 7911 $120.48 USD
- superceded 11320-W5000 INSULATOR-ENGINE MOUNTING REAR B310 KB310HF,B310HF (A12) 5-speed, A14 4-speed
63-Series
- 11323-H7510 INSULATOR ASS'Y-engine mounting, rear manual trans: A14 B210 5-speed (63-Series)
- 11323-H7400 INSULATOR ASS'Y-engine mounting, rear manual trans: late A12 B210 Sedan, Coupe
- Anchor 2489
- 11321-20300 ASS'Y INSULATOR-rear Coupe Automatic B10
- 11321-H1020 INSULATOR ASS'Y-engine mounting, rear auto trans B110 11321-H1020 $54.18 USD
- Anchor 8115 $8.13 RockAuto.com
- 11321-H2521 INSULATOR ASS'Y-engine mounting, rear auto trans early B210
- 11321-H7321 INSULATOR ASS'Y-engine mounting, rear auto trans late B210
- 11320-W5800 INSULATOR-ENGINE MOUNTING REAR B310 auto trans $79.77 USD
- C120, S110, S12?
- Anchor 2488
- 11320-W5000 910, B310, C120, F30
Also See
For swap details and other information, see:
