The Rear Engine Crossmember is more commonly called the gearbox crossmember. This transmission crossmember holds the rear engine insulator (rubber transmission mount). The crossmember matches the car, while the insulator matches the transmission type.
Crossmember
Manual Transmission
B110
- 11322-H1002 MEMBER-engine mounting, rear 3-speed, 4-speed
- 11322-H7200 MEMBER-engine mounting, rear 5-speed
- 11322-H5000 MEMBER-engine mounting, rear 3-speed, 4-speed (56-series)
- 11322-H7400 MEMBER-engine mounting, rear from 7510 Van (also replaces 11322-H5000)
- 11322-H7500 MEMBER-engine mounting, rear A14 B210 60-series 4-speed
- 11322-H5700 MEMBER-engine mounting, rear A12 5-speed F5C56
- 11341-H7500 MEMBER-engine mounting, rear A14 B210 5-speed 63-series
B310
NOTE: 11340-H8500 superceded 11340-H8600, which superceded 11340-H8610
Automatic Transmission
- 11322-H1020 MEMBER-engine mounting, rear Automatic B110
- 11322-H5200 MEMBER-engine mounting, rear Automatic early B210
- 11340-H7500 MEMBER-engine mounting, rear Automatic late B210
- 11341-H8700 MEMBER-engine mounting, rear Automatic B310
Rubber Insulator
There are different types of rear insulators.
The 56-Series Transmission type of mount bolts to the crossmember from the sides of the mount, just like these stock 1200 mounts:
This type, used with 60-Series Transmission, straddles the crossmember and bolts from the bottom:
Automatic is yet again different.
56-series
- PN 11321-H1000 INSULATOR ASS'Y-engine mounting, rear manual trans $35.83 USD
- 11321-H1000, 11321-H5000, 11320-H5000 the same?
B10
B10 MT mount looks identical to the newer B110/B210/B310 version.
60-series
- 11321-H7500 INSULATOR ASS'Y-engine mounting, rear manual trans: A14 B210 4-speed (60-Series)
- 11320-H9100 INSULATOR-ENGINE MOUNTING REAR B310 5-speed (60-series) from 7911 $120.48 USD
- superceded 11320-W5000 INSULATOR-ENGINE MOUNTING REAR B310 KB310HF,B310HF (A12) 5-speed, A14 4-speed
63-Series
- 11323-H7510 INSULATOR ASS'Y-engine mounting, rear manual trans: A14 B210 5-speed (63-Series)
- 11323-H7400 INSULATOR ASS'Y-engine mounting, rear manual trans: late A12 B210 Sedan, Coupe
- Anchor 2489
- 11321-20300 ASS'Y INSULATOR-rear Coupe Automatic B10
- 11321-H1020 INSULATOR ASS'Y-engine mounting, rear auto trans B110 $54.18 USD
- Anchor 8115
- 11321-H2521 INSULATOR ASS'Y-engine mounting, rear auto trans early B210
- 11320-H6900 Insul Mount $120.37 USD
- 11321-H7321 INSULATOR ASS'Y-engine mounting, rear auto trans late B210
- 11320-W5800 INSULATOR-ENGINE MOUNTING REAR B310 auto trans $79.77 USD
- C120, S110, S12?
- Anchor 2488
- S12 CA20E MT
- S12 CA18ET
- B210 A14 AT
- B310 some
- B210 1978
- 11320-W5000 910, B310, C120, F30
Also See
For swap details and other information, see:
