Jack
Revision as of 06:30, 1 August 2011; view current revision
Categories: Wheel And Tire | Daily Care
Datsun 1200s were equipped with an easy-to-use scissor-type jack. It shipped in the boot, as shown in the Owners' manual.
Also see: Changing tire
USA 1972 Owners manual (see page 27 for details):
There are four jack-up points at the floor panel
You can jack-up the 1200 at these points:
Using OEM jack (see Owners Manual above):
  • under rocker panel front
  • under rocker panel rear
Be sure to use a Nissan or Toyota jack with a "slot" to fit over the rocker panel seam.
Using other jacks:
  • Under lower A-arm (Transverse link), near tire
  • Middle of engine crossmember (lift entire front end)
  • center of Differential (lift entire rear of car)
  • Outboard ends of rear axle housing
CAUTION: Before sliding underneath the car, be sure to place jackstands under the suspension. In a pinch a tree stump or beefy timber can work. Make certain it is secure, and lower the weight of the car on the jackstands.
Standard Equipment
  • Scissor Jack
  • S-shaped Jack Handle
  • Wheel Wrench in black 'Nissan' bag
  • Tire retaining clamp
1976 Aussie Pick-up
1976 tool kit
Jack Location
The Jack and its equipment is stored in the Trunk (Boot).
Coupe
Sedan
Upgrades
Nissan jack handle with built-in rollers (no more pinched hands!). Source one from a more luxurious Datsun or Nissan. I got mine from a 1985 S12.
Part Codes: 99610, 99611
  • 99550-H1000 SET-JACK B110 $74.14
  • 99553-H1400 HANDLE-JACK CRANK VB110P, B120 [right-angle]
  • 99551-G1400 JACK-PANTOGRAPH TYPE B120
  • 99595-18000 BAG-TOOL $3.89
Others
  • 99504-50Y00 bag-tool $4.14
  • 99501-01A00 tool kit-complete with jack $118.12
  • 99552-01G00 rod-jack D22 [straight] $17.25
  • 99553-01W00 Handle Jack 280ZX [crank] $9.33
  • 02996-01100 handle-jack 310/810 [with plastic roll surfaces] $19.33
  • 99595-H7400 tire stopper 810 [non-folding]
  • 99595-U1400 tire stopper 280ZX [folding type] $24.30 [99595-F2700]
  • 99545-8B400 Wrench-wheel Nut & jack handle Frontier $32.88
Datsun 910
99545 wrench
02995-45200 WRENCH-WHEEL NUT
99610 jack
02996-10421 JACK-PANTOGRAPH TYPE sedan [groove type a la B110]
02996-01631 JACK-PANTOGRAPH TYPE wagon [finger type]
99595 wheel stop
99595-H7400 sedan [fixed type] (2)
99595-U1400 wagon [folding type] (1)
* 99595-F2700
99596 Tool bag
02995-95300 BAG-TOOL
99614 jack handle
02996-01100 HANDLE-JACK LEVER 910 sedan
99613 jack handle, 2-piece
02996-03200 ROD-JACK HANDLE wagon
99612 jack crank
02996-02100 HANDLE-JACK HANDle wagon
99501-89903 TOOL SET-STANDARD
Includes:
* 99545 wrench
* 99596 tool bag
