Nabco Brake Master Cylinder Part Numbers
Revision as of 02:09, 9 January 2012; view current revision
Categories: Engine Mechanical | Catalog
Also see:
Part Numbers Index
Main article for usage, photos, cross-reference
Brake master cylinder
To September 1971
TBD
From October 1971
1 46063-M0800 ASSY-PISTON,SECONDARY FOR DRUM
1 46073-H3300 ASSY-PISTON,SECONDARY FOR DISC
2 46078-M0800 CUP-PISTON
3 46064-M0800 CUP-PISTON (2)
4 46066-B5000 SPACER-CUP
5 46062-M0800 SEAT-SPRING
6 46061-M0800 SPRING-RETURN
7 46063-H3300 ASSY-PISTON,PRIMARY,FOR DISC
7 46063-H3100 ASSY-PISTON,PRIMARY,FOR DRUM
8 46032-M0800 SCREW-STOPPER
9 46079-27260 GASKET-PISTON STOPPER
10 46080-M0201 ASSY-ROD,PUSH
11 46070-27260 RING-STOPPER
12 46100-27260 COVER-DUST
13 46050-M0800 VALVE-RESIDUAL,FOR DRUM (2)
13 46050-M0801 VALVE-RESIDUAL,FOR DISC
14 46050-M0800 VALVE-RESIDUAL,FOR DISC
15 46027-U0201 SPRING-VALVE (2)
16 46029-U0201 SEAT-SPRING (2)
17 46038-A1100 CAP-VALVE (2)
18 41128-U0201 SCREW-BLEEDER (2)
19 41129-U0201 CAP-BLEEDER SCREW (2)
20 46090-U0201 RESERVOIR-OIL,FOR DISC
20 46090-U0201 RESERVOIR-OIL,FOR DRUM (2)
21 46091-U0502 RESERVOIR-OIL,FOR DISC
22 46092-N0400 FILTER-OIL,FOR DISC (2)
22 46093-N0400 FILTER-OIL,FOR DRUM (2)
23 46016-12200 ASSY-BAND,OIL RESERVOIR (2)
23 46016-14600 ASSY-BAND,OIL RESERVOIR (2) 2 46016-12200
24 46020-U0201 ASSY-CAP,OIL RESERVOIR (2)
24 46020-K2401 ASSY-CAP,OIL RESERVOIR (2) 46020-U0201
25 46010-H3625 KIT-REPAIR,BRAKE MASTER CYL.
26 46010-H3126 KIT-REPAIR,BRAKE MASTER CYL.
27 46010-H3326 KIT-REPAIR,BRAKE MASTER CYL.
