Also see:
Part Numbers Index Main article for usage, photos, cross-reference Brake master cylinder
[edit]
[edit]
To September 1971
TBD
[edit]
From October 1971
1 46063-M0800 ASSY-PISTON,SECONDARY FOR DRUM 1 46073-H3300 ASSY-PISTON,SECONDARY FOR DISC 2 46078-M0800 CUP-PISTON 3 46064-M0800 CUP-PISTON (2) 4 46066-B5000 SPACER-CUP 5 46062-M0800 SEAT-SPRING 6 46061-M0800 SPRING-RETURN 7 46063-H3300 ASSY-PISTON,PRIMARY,FOR DISC 7 46063-H3100 ASSY-PISTON,PRIMARY,FOR DRUM 8 46032-M0800 SCREW-STOPPER 9 46079-27260 GASKET-PISTON STOPPER 10 46080-M0201 ASSY-ROD,PUSH 11 46070-27260 RING-STOPPER 12 46100-27260 COVER-DUST 13 46050-M0800 VALVE-RESIDUAL,FOR DRUM (2) 13 46050-M0801 VALVE-RESIDUAL,FOR DISC 14 46050-M0800 VALVE-RESIDUAL,FOR DISC 15 46027-U0201 SPRING-VALVE (2) 16 46029-U0201 SEAT-SPRING (2) 17 46038-A1100 CAP-VALVE (2) 18 41128-U0201 SCREW-BLEEDER (2) 19 41129-U0201 CAP-BLEEDER SCREW (2) 20 46090-U0201 RESERVOIR-OIL,FOR DISC 20 46090-U0201 RESERVOIR-OIL,FOR DRUM (2) 21 46091-U0502 RESERVOIR-OIL,FOR DISC 22 46092-N0400 FILTER-OIL,FOR DISC (2) 22 46093-N0400 FILTER-OIL,FOR DRUM (2) 23 46016-12200 ASSY-BAND,OIL RESERVOIR (2) 23 46016-14600 ASSY-BAND,OIL RESERVOIR (2) 2 46016-12200 24 46020-U0201 ASSY-CAP,OIL RESERVOIR (2) 24 46020-K2401 ASSY-CAP,OIL RESERVOIR (2) 46020-U0201 25 46010-H3625 KIT-REPAIR,BRAKE MASTER CYL. 26 46010-H3126 KIT-REPAIR,BRAKE MASTER CYL. 27 46010-H3326 KIT-REPAIR,BRAKE MASTER CYL.
