Transmission Control Part Numbers
Revision as of 03:55, 9 January 2012; view current revision
Categories: Engine Mechanical | Catalog
Also see:
Part Numbers Index
Main article for usage, photos, cross-reference
Shifter
F4W56L
4-speed Light-Duty to March 1973
1 32801-24901 ROD-FORK 1ST & 2ND 4 SPEED
2 32805-18000 FORK-SHIFT (2) 4 SPEED
3 32293-73200 PIN-RETAINING (2) 4 SPEED
4 32809-24900 ROD-FORK 3RD & 4TH 4 SPEED
4 32809-H3900 ROD-FORK 3RD & 4TH 4 SPEED 0671-
5 32813-24901 BRACKET-FORK ROD 4 SPEED
6 32293-73200 PIN-RETAINING (2) 4 SPEED
7 32803-18000 RING-STOPPER 4 SPEED
8 32816-24901 ROD-FORK REVERSE 4 SPEED
9 32819-24901 FORK-SHIFTING REVERSE 4 SPEED
10 32829-26760 BALL-CHECKING (3) 4 SPEED
11 32832-18000 PLUNGER-INTER LOCK (2) 4 SPEED
12 32830-18000 SPRING-CHECKING BALL (3) 4 SPEED
13 32834-18000 PLUG-CHECKING BALL (3) 4 SPEED
14 32892-24901 ROD-STRIKING 4 SPEED
14 32892-H3900 ROD-STRIKING 4 SPEED 0172-
15 32896-24901 LEVER-STRIKING 4 SPEED
16 32897-24901 SCREW-SET STRIKING LEVER 4 SPEED
17 32804-24900 WIRE-LOCK 4 SPEED
18 32850-24901 ASSY-GUIDE STRIKING ROD 4 SPEED
19 32858-14600 RING-O 4 SPEED
20 32857-14600 CAP-RING O 4 SPEED
21 32846-24900 RING-"E" TYPE 4 SPEED
22 32847-24901 PIN-STOPPER CONTROL ARM 4 SPEED
23 32848-24900 RING-"O"CONTROL ARM 4 SPEED
24 32851-24900 PLUNGER-RETURN SPRING 4 SPEED
24 32851-N9000 PLUNGER-RETURN SPRING 4 SPEED 2 32851-24900
25 32852-24901 SPRING-RETURN 4 SPEED
26 32853-24900 PLUG-RETURN SPRING 4 SPEED
27 32856-24901 SPRING-REVERSE CHECK 4 SPEED
28 00933-32810 PLUG-EXPANSION 4 SPEED
29 32841-H1011 ASSY-LEVER CONTROL 4 SPEED
30 32854-24900 RING-"E"9S 4 SPEED
31 32849-24900 PIN-CONTROL ARM 4 SPEED
31 32849-H1010 PIN-CONTROL ARM 4 SPEED 2 32849-24900
32 32855-24900 BUSH-CONTROL LEVER (2) 4 SPEED
32 32855-H1010 BUSH-CONTROL LEVER (2) 4 SPEED 2 32855-24900
33 32861-24900 BUSH-CONTROL LEVER HEAD 4 SPEED
33 32861-N4200 BUSH-CONTROL LEVER HEAD 4 SPEED 32861-24900
34 32862-24900 BOOT-RUBBER CONTROL LEVER 4 SPEED
34 32862-G1200 BOOT-RUBBER CONTROL LEVER 4 SPEED 32862-24900
35 32865-27700 KNOB-CONTROL LEVER 4 SPEED
35 32865-H1000 KNOB-CONTROL LEVER 4 SPEED 2 32865-27700
35 32865-V2400 KNOB-CONTROL LEVER 4 SPEED 32865-H1000
36 74963-20900 BOOT-CONTROL LEVER 4 SPEED
F4W56A
4-speed Heavy-Duty from April 1973
1 32801-G1100 ROD-FORK 1ST & 2ND 4 SPEED 0473-
2 32805-18000 FORK-SHIFT 4 SPEED 0473-
3 32293-73200 PIN-RETAINING (2) 4 SPEED 0473-
4 32809-H6200 ROD-FORK 3RD & 4TH 4 SPEED 0473-
5 32813-24901 BRACKET-ROD 4-SPEED 0473-
6 32293-73200 PIN-RETAINING (2) 4 SPEED 0473-
7 32803-18000 RING-STOPPER 4 SPEED 0473-
8 32816-G1100 ROD-FORK REVERSE 4 SPEED 0473-
9 32819-G1100 FORK-SHIFT REVERSE 4 SPEED 0473-
10 32829-26760 BALL-CHECKING (3) 4 SPEED 0473-
11 32832-18000 PLUNGER-INTER LOCK (2) 4 SPEED 0473-
12 32830-18000 SPRING-CHECKING BALL (3) 4 SPEED 0473-
13 32834-18000 PLUG-CHECKING BALL (3) 4 SPEED 0473-
14 32892-H6200 ROD-STRIKING 4 SPEED 0473-
15 32896-24901 LEVER-STRIKING 4 SPEED 0473-
16 32897-24901 SCREW-SET STRIKING LEVER 4 SPEED 0473-
17 32804-24900 WIRE-LOCK 4 SPEED 0473-
18 32850-24901 ASSY-GUIDE STRIKING ROD 4 SPEED 0473-
19 32858-14600 RING-'O' STRIKING ROD 4 SPEED 0473-
20 32857-14600 CAP-RING 'O' 4 SPEED 0473-
21 32846-24900 RING-'E' TYPE 4 SPEED 0473-
23 32848-24900 RING-'O' CONTROL ARM 4 SPEED 0473-
24 32851-N9000 PLUNGER-RETURN SPRING 4 SPEED 0473- 2 32851-24900
24 32851-24900 PLUNGER-RETURN SPRING 4 SPEED 0473-
25 32852-24901 SPRING-RETURN 4 SPEED 0473-
26 32853-24900 PLUG-RETURN SPRING 4 SPEED 0473-
27 32856-24901 SPRING-REVERSE CHECK 4 SPEED 0473-
28 00933-32810 PLUG-EXPANSION 4 SPEED 0473-
29 32841-H1011 ASSY-LEVER CONTROL 4 SPEED 0473-
30 32854-24900 RING-'E' 9S 4 SPEED 0473-
31 32849-H1010 PIN-CONTROL ARM 4 SPEED 0473-
32 32855-H1010 BUSH-CONTROL LEVER (2) 4 SPEED 0473-
33 32861-24900 BUSH-CONTROL LEVER HEAD 4 SPEED 0473-
34 32862-24900 BOOT-LEVER CONTROL LEVER 4 SPEED 0473-
35 32865-H1000 KNOB-CONTROL LEVER 4 SPEED 0473-
36 74963-20900 BOOT-CONTROL LEVER 4 SPEED 0473-
