Also see:
Part Numbers Index Main article for usage, photos, cross-reference Driveshaft
1 37000-H5100 COMP-SHAFT PROPELLER WITH JOINT SHELL AUTOMATIC 0373- 2 37000-H5100 1 37000-H1001 COMP-SHAFT PROPELLER WITH JOINT MANUAL 2 37000-H1000 1 37000-H1010 COMP-SHAFT PROPELLER WITH JOINT MANUAL 2 37000-H1001 1 37000-H1011 COMP-SHAFT PROPELLER WITH JOINT MANUAL 0972- 0 37000-H1010 1 37000-H3100 COMP-SHAFT PROPELLER WITH JOINT MANUAL 2 37000-H1011 1 37000-H3100 COMP-SHAFT PROPELLER WITH JOINT SHELL MANUAL 0373- 2 37000-H1011 1 37000-H1101 COMP-SHAFT PROPELLER WITH JOINT AUTOMATIC 1 37000-H1110 COMP-SHAFT PROPELLER WITH JOINT AUTOMATIC 0671- 2 37000-H1101 1 37000-H1000 COMP-SHAFT PROPELLER WITH JOINT MANUAL 2 37111-20300 ASSY-YOKE SLEEVE AUTOMATIC 2 37111-18001 ASSY-YOKE SLEEVE MANUAL 3 37117-18000 YOKE-FLANGE 4 37125-18025 ASSY-JOURNAL WITH BEARING (2) 4 37125-H1025 KIT-JOURNAL WITH BEARING (2) 2 37125-18025 5 37130-18000 ASSY-RACE BEARING WITH OIL SEAL (8) 5 37125-H1025 ASSY-RACE BEARING WITH OIL SEAL (8) AUTOMATIC 2 37130-18000 6 37147-18000 RING-SNAP BEARING RACE T=1.48 (8) 6 37148-18000 RING-SNAP BEARING RACE T=1.50 (8) 6 37149-18000 RING-SNAP BEARING RACE T=1.52 (8) 6 37146-18000 RING-SNAP BEARING RACE T=1.46 (8) 7 08120-82210 BOLT-HEX M8X1.25 (4) 7 01111-00061 BOLT-FIX PROPELLER SHAFT (4) AUTOMATIC 2 08120-82210 7 01111-00151 BOLT-FIX PROPELLER SHAFT (4) 3N71B 0371- 2 01111-00061 8 08911-20810 NUT-HEX M8X1.25 (4) 9 08915-13810 WASHER-LOCK M8 (4)
