Also see:
Part Numbers Index Main article for usage, photos, cross-reference Alternator
25A ALTERNATOR & REGULATOR
1 23100-U0100 ASSY-ALT.12V-35A (HITACHI LT135-13)(DE A12 2 23100-A5501 1 23100-A5501 ASSY-ALTERNATOR(HITACHI) 2 23108-A5501 ASSY-ROTOR 3 23120-14801 BEARING-BALL A12 4 23102-A5501 ASSY-STATOR 5 23127-H0300 ASSY-COVER,REAR 5 23127-61700 ASSY-COVER,REAR A12 2 23127-H0300 5 23127-61701 ASSY-COVER REAR A12 2 23127-61700 6 23236-H0300 COVER-DIODE 6 23236-H0301 COVER-DIODE A12 0872- 2 23236-H0300 7 23230-H0300 ASSY-DIODE 8 23133-H0300 ASSY-HOLDER,BRUSH 8 23133-H0301 ASSY-HOLDER,BRUSH 23133-H0300 9 23135-H0300 ASSY-BRUSH,F 10 23135-H0301 ASSY-BRUSH,E 11 23156-H0300 ASSY-TERMINAL BOLT 12 23118-H0300 ASSY-COVER,FRONT 13 23122-21000 PACKING 14 23121-21000 RETAINER-PACKING 15 23120-14800 BEARING-BALL 16 23123-21005 RETAINER-BEARING 17 23164-H0100 BOLT-SETTING 18 23131-H0300 BOLT-THROUGH,L=85 2 19 23131-H0301 BOLT-THROUGH,L=95 20 23150-21001 ASSY-PULLEY 20 23150-21002 ASSY-PULLEY A12 2 23150-21001 21 23153-H0100 ASSY-NUT 22 23200-E3400 SCREW-SET 23 23500-N3300 REGULATOR-VOLTAGE (HITACHI TLI A12 1072- 2 23500-29902 23 23500-29906 REGULATOR-VOLTAGE (HITACHI TLI A12 1072- 23500-N3300, 23500-29911 23 23500-29902 REGULATOR-VOLTAGE (HITACHI TLI -972 22 23500-29901 23 23500-29901 REGULATOR-VOLTAGE (HITACHI TL1 23 23500-29911 REGULATOR-VOLTAGE (MITSUBISHI 24 08513-61212 SCREW-TAPPING 2 25 08916-13610 WASHER-LOCK (INTERNAL TOOTH) 2
25C ALTERNATOR(HITACHI)
1 23100-U0100 ASSY-ALTERNATOR 12V-35A (LT135-13) A12 2 23108-U0100 ASSY-ROTOR A12 3 23120-14801 BEARING-BALL A12 4 23102-U0101 ASSY-STATOR A12 2 23102-U0100 4 23102-U0100 ASSY-STATOR A12 5 23127-U0100 ASSY-COVER,REAR A12 5 23127-U0101 ASSY-COVER,REAR A12 2 23127-U0100 6 23133-U0100 ASSY-HOLDER,BRUSH A12 6 23133-U0101 ASSY-BRUSH A12 0 23133-U0100 7 23135-H0300 ASSY-BRUSH(F) A12 8 23135-H0301 ASSY-BRUSH(E) A12 9 23193-P0100 TERMINAL-N A12 10 23236-U0100 COVER-BRUSH A12 11 23230-U0100 DIODE A12 12 23236-H0300 COVER-DIODE A12 12 23236-H0301 COVER-DIODE A12 0872- 2 23236-H0300 13 23156-H0300 ASSY-BOLT,TERMINAL A12 14 23247-H0300 SLEEVE A12 15 23118-H0300 ASSY-COVER,FRONT A12 16 23120-14800 BEARING-BALL A12 17 23121-21000 RETAINER-PACKING A12 18 23122-21000 PACKING A12 19 23131-H0300 BOLT-THROUGH 2 A12 20 23131-H0301 BOLT-THROUGH A12 21 23164-H0100 BOLT-SETTING A12 22 23150-21002 ASSY-PULLEY A12 23 23153-H0100 ASSY-NUT,PULLEY A12 24 23200-E3400 SET-SCREW A12
