Vacuum advance is a spark timing mechanism. It advances the timing under light load, thereby making more power and better fuel economy. It lets the timing go back to normal under heavy loads, thereby preventing Detonation (pinking).
This is a good system that adds both extra performance, better fuel economy, and smoothness to the driving experience.
The only downside is for high-RPM A-series racing engines, where the advance mechanism adds some mechanical instability to the spark timing of the Distributor.
Connection
The rubber hose on the Distributor goes straight over the 'vacuum advance port' on the Carburetor. That's it.
Emission controlled vehicles have a Tee in this line for the TCVAS system. This system cuts vacuum under some conditions, lessening performance but improving pollution (less pollution).
Degrees
For a factory stock engine, including 1.5" exhaust this a typical factory advance curve:
Vacuum Advance - part D412-80 for manual transmission
- 0
Maintainence
The only maintainence is to periodically make sure the diaphragm is not leaking.
See: Vacuum Leaks
Vacuum Retard
Some newer USA engines (e.g. A14) are fitted with a vacuum retard diaphragm. This is for emission control reason, it actually retards the spark. This is for improved emissions (less pollution) in a performance trade-off.
Vacuum Advance - To use or Not?
Yes, use it. It is good. It advances your engine. More spark = more power.
