Also see:
Part Numbers Index Main article for usage, photos, cross-reference Dash Firewall Kick Panel Package Tray
Sedan,Coupe,Van,Truck
HOOD LEDGE FITTING 1 68310-H1001 SEALER-cowl top (l=250mm) from '70-June 2 68310-H1000 SEALER-cowl top (l=200mm) to '70-May 2 2 63811-H1000 SEALER-front fender 2 3 65806-H1000 BUMPER-hood 2 4 66822-H1000 BUMPER-sealing, hood rear 5 66810-H1001 PLATE-baffle, cowl top (R.H.) 6 66811-H1001 PLATE-baffle, cowl top (L.H.) DASH FITTING 7 67812-H1004 GROMMET-steering post VS,VP,VD.3-speed 67812-H1005 GROMMET-steering post GL,GX 67812-H1006 GROMMET-steering post 3-speed 67812-H1007 GROMMET-steering post 4-speed, Automatic -8910 7 67812-G1500 GROMMET-steering post 8910- 8 67813-H1000 PLATE-steering post grommet, upper -8910 8 67813-G1500 PLATE-steering post grommet, upper 8910- 9 67814-H1000 PLATE-steering post grommet, lower 10 08510-51612 SCREW (fixing grommet) 6 <> 08510-52012 85-10512-12 SCREW (fixing grommet) 6 Coupe 11 27363-18001 GROMMET-heater hole 2 STD,VS,VP 27363-18200 GROMMET-heater hole 2 DX TRUCK (op.) STD TRUCK 12 00951-11040 GROMMET (9-51104) 13 46575-H1001 BRACKET-clutch cable 14 46582-H1000 PACKING-clutch bracket 15 08310-61462 SCREW-pan head 3 16 08915-43610 WASHER-plain 3 08310-61614 SCREW with lock washer 3 1972 17 68463-00800 PLUG (for heater hose) STD 18 26199-A5500 CAP-screw TRUCK
