Also see:
Part Numbers Index Main article for usage, photos, cross-reference Front Suspension
1 54401-H3900 ASSY-MEMBER FRONT SUSPENSION 1171- 2 54401-H1000 1 54401-H1000 ASSY-MEMBER FRONT SUSPENSION 2 08194-06510 BOLT-HEX M10X1.25 (4) 4 3 32886-22000 WASHER-BODY BOLT (8) 8 4 08915-14010 WASHER-SPRING LOCK M10 (4) 4 5 08911-54010 NUT-HEX M10X1.25 (4) 4 6 54100-H1050 ASSY-LINK TRANSVERSE RH 2 54110-H1000 6 54100-H1060 ASSY-LINK TRANSVERSE RH 2 54100-H1050 6 54110-H1000 ASSY-LINK TRANSVERSE RH 7 54101-H1050 ASSY-LINK TRANSVERSE LH 2 54111-H1000 7 54101-H1060 ASSY-LINK TRANSVERSE LH 2 54101-H1050 7 54111-H1000 ASSY-LINK TRANSVERSE LH 8 54131-H1000 ASSY-BUSH TRANSVERSE LINK (2) 2 9 54132-H1001 PIN-TRANSVERSE LINK (2) 2 10 08915-54010 WASHER-PLAIN M10 (2) 2 11 08915-24010 WASHER-SPRING LOCK M10 (2) 2 12 08911-64010 NUT-HEX M10X1.25 (2) 2 13 54470-H1000 ROD-TENSION FRONT SUSPENSION RH 14 54471-H1000 ROD-TENSION FRONT SUSPENSION LH 15 54472-18000 WASHER-SPECIAL TENSION ROD (4) 4 16 54630-H1001 COLLAR-BUSH TENSION ROD (2) 2 17 54476-H1001 BUSH-TENSION ROD (4) 4 s 17 54476-W5000 BUSH-TENSION ROD (4) 4 54476-H1001 18 08915-44210 WASHER-PLAIN M12 (2) 2 19 08912-34210 NUT-HEX SELF LOCK M12 (2) 2 20 54302-H5025 KIT-STRUT FRONT SUSPENSION FOR DRUM (AT (2) 2 2 54302-H1025 20 54302-H1026 KIT-STRUT FRONT SUSPENSION FOR DRUM (TO (2) 2 20 54302-H5026 KIT-STRUT FRONT SUSPENSION FOR DRUM (TO (2) 2 2 54302-H1026 20 54302-H1025 KIT-STRUT FRONT SUSPENSION FOR DRUM (AT (2) 2 21 54302-H1125 KIT-STRUT FRONT SUSPENSION RH FOR DISC OP 21 54302-H5125 KIT-STRUT FRONT SUSPENSION RH FOR DISC OP 2 54302-H1125 21 54302-H1126 KIT-STRUT FRONT SUSPENSION RH FOR DISC OP 21 54302-H5126 KIT-STRUT FRONT SUSPENSION RH FOR DISC OP 2 54302-H1126 22 54303-H5125 KIT-STRUT FRONT SUSPENSION LH FOR DISC OP 2 54303-H1125 22 54303-H1126 KIT-STRUT FRONT SUSPENSION LH FOR DISC OP 22 54303-H1125 KIT-STRUT FRONT SUSPENSION LH FOR DISC OP 22 54303-H5126 KIT-STRUT FRONT SUSPENSION LH FOR DISC OP 2 54303-H1126 23 40262-18000 NUT-SPINDLE (2) 2 24 54324-21000 NUT (2) 2 24 54324-N0100 NUT (2) 2 2 54324-21000 25 40018-18000 COLLAR-FONT SPINDLE (2) 2 26 56110-H1025 KIT-ABSORBER SHOCK FRONT (ATSUGI) (2) 2 26 56105-H5025 KIT-ABSORBER SHOCK FRONT (ATSUGI) (2) 2 56110-H1025 26 56110-H1026 KIT-ABSORBER SHOCK FRONT (TOKICO) (2) 2 26 56105-H5025 KIT-ABSORBER SHOCK FRONT (TOKICO) (2) 2 56110-H1026 27 54308-H1025 KIT-PACKING GLAND(ATUGI) (2) 2 27 54308-H1026 KIT-PACKING GLAND(TOKICO) (2) 2 28 54313-28525 OIL-SUSPENSION STRUT (TOKICO 360C 28 54313-89925 OIL-SUSPENSION STRUT (TOKICO 360C 54313-28525 28 54313-22127 OIL-SUSPENSION STRUT (ATSUGI 360C 28 54313-22128 OIL-SUSPENSION STRUT (ATSUGI 1000 2 54313-22127 28 54313-22129 OIL-SUSPENSION STRUT (ATSUGI 360C 2 54313-22128 29 54010-H1600 SPRING-FRONT SUSPENSION L=213 (2) 2 29 54010-H1601 SPRING-FRONT SUSPENSION L=213 (2) 2 2 54010-H1600 30 54050-H1000 BUMPER-BOUND FRONT SUSPENSION (2) 2 31 54040-H1000 SET-FRONT SPRING UPPER (2) 2 32 54059-H1000 SEAT-FRONT SPRING STRUT (2) 2 33 54325-H1000 BEARING-STRUT MOUNTING (2) 2 34 54320-H1000 INSULATOR-STRUT MOUNTING (2) 2 35 54055-H1000 COVER-DUST FRONT SUSP STRUT (2) 2 36 08912-34210 NUT-HEX SELF LOCK M12 (2) 2 37 08915-44210 WASHER-PLAIN M12 (2) 2 38 08915-53810 WASHER-PLAIN M8 (6) 6 39 08915-13810 WASHER-SPRING M8 (6) 6 40 08911-10810 NUT-HEX M8X1.25 (6) 6 41 54611-H1002 BAR-TORSION FRONT STABILIZER 42 56125-18100 BUSH-RUBBER SHOCK ABSORBER (8) 8 43 56126-18000 WASHER-A SHOCK ABSORBER (4) 4 44 56127-18000 WASHER-B SHOCK ABSORBER (4) 4 45 54618-H1000 ASSY-ROD CONNECTING FRONT STABILIZER (2) 2 45 54618-H2300 ASSY-ROD CONNECTING FRONT STABILIZER (2) 2 0570- 2 54618-H1000 46 08912-30810 NUT-SELF LOCK S M8 (4) 4 47 54616-H1000 BRACKET-STABILIZER (2) 2 47 54616-H1001 BRACKET-STABILIZER (2) 2 0570- 2 54616-H1000 48 54617-H1001 BUSH-STABILIZER (2) 2 49 08110-81610 BOLT-HEX M8X1.25 (4) 4 50 08915-13810 WASHER-SPRING LOCK M8 (4) 4
