Also see:
Part Numbers Index Main article for usage, photos, cross-reference Steering Linkage
1 48510-H1025 KIT-ROD SIDE RH 1072- 2 48510-H1002 1 48510-H1001 ASSY-ROD SIDE RH 1 48510-H1002 ASSY-ROD SIDE RH 1072- 6 48510-H1001 2 48520-H1001 ASSY-SOCKET SIDE ROD RH OUTER 3 48521-H1001 ASSY-SOCKET SIDE ROD RH INNER 4 48522-H1001 COVER-DUST SIDE ROD (2) 5 48526-18000 CLAMP-DUST COVER (2) 6 40189-73000 PLUG-FILLER (2) 7 01227-00011 NUT-HEX SLOTTED (3) 8 08921-32010 PIN-COTTER 3.2X20 (2) 9 48512-H1001 BAR-SIDE ROD 10 01211-00011 NUT-LOCK SIDE ROD RH 11 01211-00021 NUT-LOCK SIDE ROD LH 12 48630-H1002 ASSY-ROD SIDE LH 1072- 6 48630-H1001 12 48630-H1025 KIT-ROD SIDE LH 1072- 2 48630-H1002 12 48630-H1001 ASSY-ROD SIDE LH 13 48640-H1001 ASSY-SOCKET SIDE ROD LH OUTER 14 48641-H1001 ASSY-SOCKET SIDE ROD LH INNER 15 01211-00021 NUT-LOCK SIDE LH 16 48526-18000 CLAMP-DUST COVER (2) 17 40189-73000 PLUG-FILLER (2) 18 01227-00011 NUT-HEX SLOTTED (2) 19 08921-32010 PIN-COTTER 3.2X20 (2) 20 48512-H1001 BAR-SIDE ROD 21 01211-00011 NUT-LOCK SIDE RH 22 48530-H1600 ASSY-IDLER STEERING 23 48551-H1000 ARM-IDLER STEERING 24 48544-H1000 BUSH-IDLER (2) 25 48541-H1000 WASHER-IDLER UPPER 26 54324-21000 NUT-HEX SELF LOCK 26 54324-N0100 NUT-HEX SELF LOCK 2 54324-21000 27 48362-H1000 BOLT IDLER FIX TO FRAME (2) 28 08915-53810 WASHER-PLAIN M8 IDLER FIX TO FRAME (2) 29 48366-H1000 NUT IDLER FIX TO FRAME (2) 30 48560-H1600 ASSY-CROSS ROD STEERING 31 48522-H1001 COVER-DUST CROSS ROD 32 48526-18000 CLAMP-DUST COVER 33 40189-73000 PLUG-FILLER (2) 34 48577-H1001 SEAL-DUST IDLER ARM 35 01227-00011 NUT-HEX SLOTTED (2) 36 08921-32010 PIN-COTTER 3.2X20 (2)
