Suzuki G Engine Swap
Revision as of 07:08, 25 June 2012; view current revision
Categories: Engine Modifications | Engine Swaps
Suzuki G-series B (16-valve) engine is a lightweight, high-output, twin-cam four cylinder. For example, the G13B from GTI Swift is lighter than A15, but 109 HP compare to 80HP for an A15.
  • 10kg lighter than A10
  • 20kg lighter than A15 when all considered
The beauty of this engine is the power, torque and weight capability. 125HP with carb and exhaust changes.
See wikipedia:Suzuki G engine
GB13 in Datsun 1000. See Build Project discussion: G13B into my KB10
G13B
G13BA SOHC
G13BB (MPFI)
G16B
Ignition
Distributor: because it is on the back of the head, you will need a right-angle distributor, Or crank trigger ignition like EDIS
Transmission
Gearbox: use Suzuki Sierra or Samurai gearbox or Geo Tracker
The box will fit easily in a 1200 tunnel if as above -- the 4x2 version.
Shifter
Gearlever moved forward on Suzuki gearbox
This is the lever moved forward with flat alloy cover plate then use sierra or other shifter housing
935.JPG 936.JPG 937.JPG 14126.jpg 18317.jpg 18318.jpg 18319.jpg 18320.jpg 18511.jpg 18512.jpg 18513.jpg 18514.jpg 18825.jpg 18826.jpg 18827.jpg 18828.jpg 18860.jpg 18861.jpg 18862.jpg 18863.jpg 19372.jpg 19373.jpg 19722.jpg 20616.jpg 20770.jpg 20774.jpg 20775.jpg 20776.jpg 21192.jpg 21194.jpg 22493.jpg 22494.jpg 24371.jpg 24372.jpg
