120Y Front Suspension
Revision as of 03:41, 4 July 2012; view current revision
120Y was the marketing name for A12-powered B210 in many countries. The suspension differs from A14-powered B210.
Early 120Y used the exact same front strut assembly as the B110 -- except for the strut top. Spring rate varied.
Part number Applied Model Codes (original appplication)
180 - Datsun B10 (1000)
210 - Datsun 510 (1600)
H10 - Datsun B110 (1200)
H16 - Datsun B110 Coupe
H25 - Datsun B110 Coupe
H50 - Datsun B210
H62 - Datsun B210 1974
H74 - Datsun B210 A12 late
H75 - Datsun B210 A14 late
U01 - Datsun 610 1972
Japan Market
In Japan the A12-powerd B210 was marketed as the Datsun Sunny 1200 B210.
1973-1975 (Early Sedan/Coupe/Van) SAME AS B110
DRUM STD, DX
54302-H5025 STRUT KIT-front suspension (Atsugi) 73-75
DISC GL, GX
54302-H5125 STRUT KIT-front suspension (R.H.) (Atsugi)
54303-H5125 STRUT KIT-front suspension (L.H.) (Atsugi)
1976-1978
54302-H7425 STRUT KIT-front suspension (Atsugi) 76-78, Van from 1075
54302-H7426 STRUT KIT-front suspension (Tokico) 76-78, Van from 1075
54302-H7427 STRUT KIT-front suspension (Atsugi) 76-78 VH=PT
Spring
EARLY
54010-H5000 SPRING-front suspension 2 ALL <> 54010-H5000
54010-H5001 SPRING-front suspension (R.H.) (from '74-1) ALL
54010-H5000 SPRING-front suspension (L.H.) (from '74-1) ALL
54010-H6200*SPRING-front suspension (R.H.) (from '75-10) VAN
54010-H1601*SPRING-front suspension (L.H.) (from '75-10) VAN
* Same as USA B110 (disc brake) L=213
Shock Absorber
56110-H1025 SHOCK ABSORBER KIT-front (厚木) 2 ALL
* Same as USA B110
56110-H7425*SHOCK ABSORBER KIT-front (厚木) (from '75-10) 2 VAN
56110-H7426*SHOCK ABSORBER KIT-front (トキコ) (from '75-10) 2 VAN
KIT includes the following (Same as USA B110):
54308-H1025 PACKING KIT-gland (厚木) 2
54308-H1026*PACKING KIT-gland (トキコ) (from '75-10) 2 VAN
54324-21000 NUT 2 [M12]
08915-44210 WASHER-plain 2 [M12]
54313-22129 OIL-suspension strut (360 cc) (厚木) 2 ALL
54313-28525 OIL-suspension strut (360 cc) (トキコ) (from '75-10) 2 VAN
Spindle Nut
40262-18000 NUT-lock, front wheel bearing 2 ALL
40262-U0100*NUT-lock, front wheel bearing (from '75-10) 2 VAN
08921-32510 PIN [cotter] 2 ALL
00921-43000*PIN [cotter] (from '75-10) 2 VAN
Strut Top
Strut Mounting Insulator differs from B110.
54320-H5000 INSULATOR-strut mounting 2 ALL
08915-14010 WASHER-lock, insulator to body 6 ALL
08911-64010 NUT, insulator to body 6 ALL
H10 parts are sourced from B110
54050-H1000 BUMPER-bound, front suspension 2 ALL
54040-H1000 SEAT-front suspension upper 2 ALL [spring seat]
54059-H1000 SEAL-dust, font suspension strut 2 ALL
54325-H1000 BEARING-strut mounting 2 ALL
54055-H1000 COVER-dust, front suspension strut 2 ALL
USA Market
A12-powered B210 was not sold in USA or Canada. All were HB210 (used A13/A14 engines) and were fitted with the PB110 (L14-powered B210) suspension from the Datsun 610.
