Strut Inserts (shock absorbers) for the front suspension: Datsun 1200 (B110) uses 45 mm diameter strut tubes. Most other Datsuns, including B210, use a larger 2.0 inch (50.8 mm) size. This article will help you choose parts for rebuild or replacement.
| Contents |
The 1200 front shock absorbers can be rebuilt. Or you can fit strut insert cartridges, such as NOS KYB gas-a-just or the commonly available VW inserts.
Shock Absorber Cartridges for Datsun 1200 struts
Direct Interchange
Original Nissan Part Numbers
- Datsun 1200s did not come with strut insert cartridges, instead the struts contained had rebuildable shock absorbers (wet shocks).
- Nissan later offered strut inserts specifically for the 1200, they are still available in USA as of May 2008.
Using a factory-quality Strut rebuild kit (rather than removing the factory strut parts and replacing with a new strut 'cartridge' insert) is the way to retain a smooth front-end ride. However, these kits are no longer manufactured. Using the genuined Nissan cartridge (same as early A12-powered B210s) is just as good.
Insert Cartridge Shock
-  56105-H5025 CARTRIDGE-ABSORBER,SHOCK, FRONT
- about $50 each from Nissan
Wet Shocks. You can add new oil and new strut glands, such as a NOS Koni rebuild kit.
The original struts had built-in shock absorbers:
- 56110-H1025 KIT-ABSORBER SHOCK FRONT (ATSUGI)
- 56110-H1026 KIT-ABSORBER SHOCK FRONT (TOKICO)
These kits included oil and a rubber thing with valves:
- 54308-H1025 KIT-PACKING GLAND(ATUGI)
- 54308-H1026 KIT-PACKING GLAND(TOKICO)
- 54313-22127 OIL-SUSPENSION STRUT (ATSUGI 360C
- 54313-22128 OIL-SUSPENSION STRUT (ATSUGI 1000
- 54313-28525 OIL-SUSPENSION STRUT (TOKICO 360C
- 54313-22129 OIL-SUSPENSION STRUT (ATSUGI 360C
45mm OD Strut Inserts
Discussion: strut inserts
Stock
See the genuine Nissan part numbers listed above.
418 body length / 631 Extended / 462 Collapsed
- Stroke: 169mm (6.7 in)
Nissan Gas-Filled for Datsun 1200
Nissan Pulsar
1981 Pulsar inserts are the same external size as Datsun 1200 but shorter by 82 mm (3-1/4 in) so if you are after lowering with out banging on the spring mounts this is a easy way to go only 10mm (3/8) shorter in the stroke.
Monroe 25-3436 replaces WGC-3436 touring gas cartridge
Tokico
- TOKICO S1041 (oil), Z1041 (gas)
Kayaba
- KYB (Kayaba) 662002/KC1001 (oil)
-  KYB 362001 (gas)
-  Replaces B110, B120 Jan 1970-May 1973
-  Replaces B210 with A12 Mar 1973-Oct 1977
-  Replaces VB310 with A12 12" wheel models
KONI
-  Koni 86-1714 (previously 82N-1714, S1003)
- replaces 56110-H1026
-  99996-1714N 1200/FRONT KONI SHOCK ABSORBER
- From the 1984 Nissan Competition Catalog
VW Jetta
Jetta inserts -- information on inserts and adapting Koni inserts for VW Jetta so that they fit a 1200.
416 body length/ 599 Extended/ 431 Collapsed,
1200 (B110), 120y (B210)
Gabriel - G44217
Vera - 62-01015
VW Golf/Rabbit
- Get Bilstein (1.507 in) or KYB brand at about 1.5 inch outside diameter. Tokico and KONI are too big around to fit 45mm strut housings.
- Golf Mk I insert is nearly 4 inches shorter than stock and will need a simple spacer made to make up the difference in length in the bottom of the tube.
- Strut piston diameter is larger than B110, so drill out the strut-nut and the strut top hole.
discussion: VW Rabbit inserts
318 body length / 511 Extended / 352 Collapsed
324 / 511 / 359'
- Stroke: 158mm (6.25 in)
- Bilstein part number W0133-1604944
Four different Rabbit Bilsteins available:
-  OE style "Touring
- F4PNE3033BE / 171412031J USA Made With Internal Threads
-  stiff "Sport"
- F4P300032M0 / 171412031J USA Made With Internal Threads
- softer "heavy duty"
- race: 270/100 for rebound/compression
Bilstein Race & Rallye (gas)
- Strut Part Number V36-0059 (but just buy the inserts)
- 270/100 damping
-  Fits:
- 1974-1984 Golf/Rabbit
- 1977-1981 Volkswagen Scirocco I 4 cyl 8v
- 1980-1984 Volkswagen Jetta I 4 cyl 8v
- 1982-1988 Volkswagen Scirocco II 1.8L 8v
- 1986-1988 Volkswagen Scirocco II 1.8L 16v
Monroe Sensa-Trac (gas) 72878 / P832
- Models w/ Internal Threads on Original Strut Housing (U. S. A.)
- Diameter: 1.5"
- Stroke: 152mm (6.000 in)
- Ext len: 511mm (20.125 in)
- Comp len: 359mm (14.125 in)
- Body len: 324mm (12.750 in)
Monroe Sensa-Trac (gas) 72826 / 17090011
- Models w/ External Threads on Original Strut Housing (German)
- Diameter: 1.5"
- Stroke: 6.250"
- Ext len: 20.125"
- Comp len: 13.875"
- Body len: 12.500"
- Piston diameter: 0.75"
Toyota
Get them from TRD
- Yotato Starlet (RWD)
- Toyota MR2 MK1 85/86 Rear Insert, 65mm shorter than (120y) B210, KONI 8641 1072sport.
Measurements
Strut Housing
- Outside Diameter: 45mm (1.77 in)
- Inside Diameter: about 1.5 inch
Nissan 56105-H5025 for Datsun B110
- Body length: 41.8mm (16-3/8 inch). The seal protrudes 1/8 past this.
- diameter: main housing - 37.6mm (1.48 in)
- diameter: upper collar at top of housing - 40.9mm (1.61 in)
- shaft dia. 17.8mm (1.7 in)
- thread height - 24mm
- thread diameter - M10 (10mm hole, 11 mm threads)
- Overall collapsed - 46.2mm (18-3/16 in.)
- Overall extended - 63.1mm (24-13/16 in.)
- Stroke: 16.9mm (6.7 in)
Original B110 Strut valving Damping Force @ 0.3m/sec:
- Expansion kg(lb): 48 (106)
- Compression kg(lb): 22 (48.5)
Stroke
- B310 strut valve: 164 mm (6.46 in)
- B310 cartridge: 161.5
- B310 cartridge: 160.5 A12A Canada (12" wheels)
Damping rates are same for B310 valve or insert, but stroke differs slightly.
Damping Force
| model | B110 1970-1973 disc | B210 1974-1977 A13/A14 | B210 1978 A14 | B310 1979 | B310 80-82 | B310 12" |
| expansion: kg | 48 | 32-48 | 28-42 | 30-40 | 28-42 | 38-58 |
| compression: kg | 22 | 20-30 | 16-24 | 17-23 | 16-24 | 15.5-24.5 |
