Main : Members : WhiteSedan Koni Shocks for 1200
[<   Previous  71  72  73  74  75  76  77  Next   >]
Koni Shocks for 1200Popular
SubmitterWhiteSedanMore Photos from WhiteSedan   Last Update2005/11/23 9:52    Tell a friendTell a friend
Hits6188  Comments11    0.00 (0 votes)0.00 (0 votes)
Just a pic of the Koni's i have for the circuit car, (will be finished one day!)
ssskiwi
Posted: 2010/8/8 3:04  Updated: 2010/8/8 3:04
 Re: Koni Shocks for 1200
These guys in the States have them listed, dunno what freight is like tho..
http://classicgarage.com/1200b110.html
The adjustment is just to keep the shock performance steady as they wear, not for handling adjustment.
A14Sedan
Posted: 2010/8/8 2:00  Updated: 2010/8/8 2:00
So will the coupe shocks work in the sedan? Whats the part number for the front shocks? I have some 910 bluebird struts.. im looking for a descent shock for my set up!
Heres a link to show you how to adjust the shocks
http://www.koni-na.com/adjustment.cfm
Posted: 2010/8/8 16:14  Updated: 2010/8/8 16:14
Coupe shocks will not work in a sedan, they are very different.
Front strut inserts are the same for all 1200s
estyre
Posted: 2010/8/7 15:35  Updated: 2010/8/7 15:35
levey i think you are suposed to push them all the way down and then turn the inside ram until you feel a click or a slight drop ,then turn clock wise to stiffen and anticlockwise to soften ,this is how a similar set i have seen work
i gave you the box with them, aswell didnt i ,there is instructions in there ,ill check for the box in the morning if i find it ill ring you
Posted: 2010/8/7 17:43  Updated: 2010/8/7 17:43
Coupe: KONI KO-80-1977
Wagon: KONI KO-80-1904
levey
Posted: 2010/8/7 13:15  Updated: 2010/8/7 13:15
I have a set of adjustable Koni front shocks sitting on my bench but no instructions on adjustment are yours the same?
My part number is: 8640 1108
A14Sedan
Posted: 2010/8/7 12:56  Updated: 2010/8/7 12:56
Whats the part numbers for these shocks mate??
coxsteve
Posted: 2015/1/13 10:54  Updated: 2015/1/13 10:54
Koni classic new release B110 and 120Y rear Wagon (Ute) shocks part number is 80-1904
These guys have Koni "Wet Kit" inserts for the front on special at $199.00 US at the moment for 1200's.
http://classicgarage.com/nid12bwetkit.html
Posted: 2015/1/14 2:34  Updated: 2015/1/14 2:34
Koni 80-1904 still seems really rare.
But can be found in Australia: http://www.fulcrumsuspensions.com.au/holden
coxsteve
Posted: 2015/1/14 11:26  Updated: 2015/1/14 11:42
These are being put back in production under the new "Koni Classic range" which is on their website under road suspension, They only just released brochures in Europe at some classic car meets so stocks can be ordered as they are new build product under the classic range which is growing over time.
At the moment they only do the Wagon and van which is the same as the Utility or Pickup as you guys call em in the USA.
http://www.koni.com/car-racing/products/performance/koni-classic/
Loaded a Photo into the Photo Album under suspension.
Posted: 2015/1/14 20:29  Updated: 2015/1/14 20:29
Thanks for the info!
coxsteve photo album
