Datsun 1200 used the tried and true leaf spring rear suspension, which was common among most cars - including american cars - in the early 1970s.
55020-H1000 Sedan, Coupe 55020-H1400 Van (heavy duty) 55020-G1000 Truck 4-leaf early 55020-G1001 Truck 4-leaf 7510- 55020-G1002 Truck 4-leaf 8504- 55020-G1060 Truck 5-leaf 7804-8503 55020-G1061 Truck 5-leaf 7804-8503 8504-
All 1200 springs are:
length: 1110 mm width: 50mm
Sedan, Coupe * 3 leaf: 1 x 6mm thick, 2 x 7mm thick Van standard * 4 leaf: 3 x 6mm thick, 1 x 13mm thick Van heavy duty * 4 leaf: 2 x 6mm thick, 1 x 17mm thick, 1 x 11mm thick
Truck standard * 4 leaf: 2 x 6mm thick, 1 x 7mm thick, 1 x 13mm thick Truck optional * 5 leaf: 2 x 6mm thick, 1 x 7mm thick, 2 x 10mm thick
Truck Free Camber: * 118.5 mm Truck Laden Camber: * Standard: 18.5 mm/kg * Optional: 15.1 mm/kg
Leaf Spring Mounting
Rear axle mounting and Shocks
Spring Seat Assembly
Sedan: 55262-H1001
Truck: 55262-G1000 (RH) 12mm shock Nut wide u-bolt
Van: 55262-H1401 (RH) 12mm shock Nut narrow u-bolt
55262-H1402 (RH) (from '73-6)
Coupe: 55262-H1801 (RH) 8mm shock Nut
55262-H1802 (RH) (from '73-5)
U-bolts 55247-H1002 CLIP-rear spring Sedan, Coupe.USA 55240-H1800 Coupe.JPM.early 55247-H1401 CLIP-rear spring Van, Coupe.JDM.late 55247-G1000 CLIP-REAR SPRING Truck 4-leaf 55247-G1060 CLIP-REAR SPRING Truck 5-leaf 7804-
Fasteners for U-bolts (Sedan,Coupe,Van,Truck) 08911-64010 NUT-HEX M10 x 1.25 8 08915-14010 WASHER-spring lock 8
Bumpers
Coupe & Van rear suspension bumper (above the Leaf Spring) 55240-H1400 ASSY-BUMPER REAR AXLE 08911-64010 NUT-HEX M10X1.25 08915-14010 WASHER-SPRING LOCK
Sedan rear suspension bumper (on the Shocks) 55240-H1001 BOUND BUMPER A 56124-H1001 BOUND-BUMPER B
Bushings
5 55044-H1001 front upper Sedan, Coupe
6 55045-H1000 front lower Sedan, Coupe [leaf eye]
17 55046-H1000 rear upper
18 55047-H1000 rear lower [leaf eye]
Wagon & Ute
V 55045-H1400 front Van, Truck
Make your own
Or, make your own performance bushings per Nissan Competition book:
Aftermarket
Or, get stiff aftermarket bushings:
Polyurethane bushings out of Mexico: Parbo
