You can add rear disc brakes to H145 with a Australia-built R31 Skyline/Pintara setup. Fits over 13" steel wheels.
H145
It will also fit H150 as H145/H150 housing ends are the same.
Click each photo to read the comments and find more detail.
Use a brake proportioning valve to set the balance. These are large rear brakes.
R31 Caliper bracket modified to fit H145
Holes re-drilled for H145 housing pattern
Remove the axles. Cut the backing plate to remove it, so that you don't have to remove the axle bearing.
Lay H145 drum brake backing plate over Adapter, mark the holes to drill
Finned R31 caliper bolts to the adapter
The factory adapter is thin, but adequately strong
click
Fitted to 1200 Coupe
click
Handbrake Considerations
Also see
Fit the calipers facing forward so you can run the cables back and loop around and utilise the existing hand brake bracket and cabling on the diff.
click
