Also see:
Part Numbers Index Main article for usage, photos, cross-reference H145 Differential H165
Contents[hide] |
H145 Composite
* 38300-H1000 ASSY-CARRIER WITH GEAR 39:10(3.900) B110 * 33800-H1010 ASSY-CARRIER WITH GEAR 39:10(3.900) 0374-0874 1 38310-G0400 COMP-CARRIER GEAR 2 08915-14010 WASHER-LOCK FIXING DIFF BEARING CAP 3 38315-G0400 BOLT FIXING DIFF BEARING CAP 4 38100-18000 SET-GEAR, hypoid with pinion (37 T:9 T) B10 Sedan & Coupe 4 38100-18100 SET-GEAR, hypoid with pinion (35 T:8 T) B10 Van 4 38100-H0700 SET-GEAR, hypoid with pinion (35 T:8 T) B10 Van 4 38100-15400 SET-GEAR, hypoid with pinion (37 T:8 T) B10 T 4 38100-G0400 SET-GEAR, hypoid with pinion (37 T:8 T) B10 T (from '67-Nov) 4 38100-H1000 SET-GEAR & PINION HYPOID B110 39:10T Sedan,Coupe 4 38100-H1100 SET-GEAR & PINION HYPOID B110 37:9T Van 5 38102-G0300 BOLT-DRIVE GEAR 6 38103-G0400 STRAP-LOCK BOLT 7 38421-G0500 CASE DIFFERENTIAL 8 38423-18000 GEAR-SIDE DIFF BEVEL 9 38424-18000 WASHER-THRUST SIDE GEAR T=0.76 MM 9 38424-18001 WASHER-THRUST SIDE GEAR T=0.81 MM 9 38424-18002 WASHER-THRUST SIDE GEAR T=0.86 MM 9 38424-18003 WASHER-THRUST SIDE GEAR FOR SERVICE T=0. 9 38424-18004 WASHER-THRUST SIDE GEAR FOR SERVICE T=0. 9 38424-18005 WASHER-THRUST SIDE GEAR FOR SERVICE T=1. 9 38424-18006 WASHER-THRUST SIDE GEAR FOR SERVICE T=1. 9 38424-18007 WASHER-THRUST SIDE GEAR FOR SERVICE T=1. 9 38424-18008 WASHER-THRUST SIDE GEAR FOR SERVICE T=1. 9 38424-18009 WASHER-THRUST SIDE GEAR FOR SERVICE T=1. 9 38424-18010 WASHER-THRUST SIDE GEAR FOR SERVICE T=1. 9 38424-18011 WASHER-THRUST SIDE GEAR FOR SERVICE T=1. 9 38424-18012 WASHER-THRUST SIDE GEAR FOR SERVICE T=1. 9 38424-18013 WASHER-THRUST SIDE GEAR FOR SERVICE T=1. 9 38424-18014 WASHER-THRUST SIDE GEAR FOR SERVICE T=1. 9 38424-18015 WASHER-THRUST SIDE GEAR FOR SERVICE T=1. 9 38424-18016 WASHER-THRUST SIDE GEAR FOR SERVICE T=1. 10 38425-18000 MATE-PINION DIFF BEVEL 11 38426-18000 WASHER-THRUST PINION MATE 12 38427-18000 SHAFT-PINION MATE 13 38428-G0400 PIN-LOCK DIFF PINION 14 38440-H1000 ASSY-BEARING DIFF SIDE * superseded 38440-18000 ASSY-BEARING DIFF SIDE 15 38453-H1000 SHIM-ADJUST SIDE BEARING T=0.05 15 38454-H1000 SHIM-ADJUST SIDE BEARING T=0.07 15 38455-H1000 SHIM-ADJUST SIDE BEARING T=0.10 15 38456-H1000 SHIM-ADJUST SIDE BEARING T=0.20 15 38457-H1000 SHIM-ADJUST SIDE BEARING T=0.50 16 38120-18000 ASSY-BEARING DRIVE PINION REAR 17 38140-18000 ASSY-BEARING DRIVE PINION FRONT 18 38165-H1000 SPACER-DRIVE PINION BEARING 18 38165-H1001 SPACER-DRIVE PINION BEARING 0374- 19 38154-G0400 WASHER-ADJUST DRIVE PINION T=2.74 19 38154-G0401 WASHER-ADJUST DRIVE PINION T=2.77 19 38154-G0402 WASHER-ADJUST DRIVE PINION T=2.80 19 38154-G0404 WASHER-ADJUST DRIVE PINION T=2.86 19 38154-G0406 WASHER-ADJUST DRIVE PINION T=2.92 19 38154-G0403 WASHER-ADJUST DRIVE PINION T=2.83 19 38154-G0405 WASHER-ADJUST DRIVE PINION T=2.89 19 38154-G0407 WASHER-ADJUST DRIVE PINION T=2.95 19 38154-G0408 WASHER-ADJUST DRIVE PINION T=2.98 19 38154-G0409 WASHER-ADJUST DRIVE PINION T=3.01 19 38154-G0410 WASHER-ADJUST DRIVE PINION T=3.04 19 38154-G0411 WASHER-ADJUST DRIVE PINION T=3.07 19 38154-G0412 WASHER-ADJUST DRIVE PINION T=3.10 19 38154-G0413 WASHER-ADJUST DRIVE PINION T=3.13 19 38154-G0414 WASHER-ADJUST DRIVE PINION T=3.16 19 38154-G0415 WASHER-ADJUST DRIVE PINION T=3.19 19 38154-G0416 WASHER-ADJUST DRIVE PINION T=3.22 19 38154-G0417 WASHER-ADJUST DRIVE PINION T=3.25 20 38189-18000 SEAL-OIL DRIVE PINION 21 38210-H1000 ASSY-FLANGE COMPANION WITH DAMPER 21 38210-18000 ASSY-FLANGE COMPANION 22 38215-01300 WASHER-PLAIN -0274 23 38216-H1000 NUT-DRIVE PINION 0374- 23 38216-18000 NUT-DRIVE PINION 24 38320-18010 GASKET-GEAR CARRIER 25 08915-13810 WASHER-LOCK 26 08911-20810 NUT
Sunny Truck
The H165 was used all years of the 1200 Truck.
1 38300-H1000 ASSY-CARRIER WITH GEAR 39:10(3.900) 2 38310-G0400 COMP-CARRIER GEAR 3 38315-G0400 BOLT FIXING DIFF BEARING CAP (4) 4 08915-14010 WASHER-LOCK FIXING DIFF BEARING CAP (4) 5 38100-H1000 SET-GEAR & PINION HYPOID 39:10 6 38102-G0300 BOLT-DRIVE GEAR (8) 7 38103-G0400 STRAP-LOCK BOLT (4) 8 38421-G0500 CASE DIFFERENTIAL 9 38423-18000 GEAR-SIDE DIFF BEVEL (2) 10 38424-18000 WASHER-THRUST SIDE GEAR (0) 10 38424-18001 WASHER-THRUST SIDE GEAR (0) 10 38424-18002 WASHER-THRUST SIDE GEAR (0) 11 38425-18000 MATE-PINION DIFF BEVEL (2) 12 38426-18000 WASHER-THRUST PINION MATE (2) 13 38427-18000 SHAFT-PINION MATE 14 38428-G0400 PIN-LOCK DIFF PINION 15 38440-H1000 ASSY-BEARING DIFF SIDE (2) 0772- 2 38440-18000 15 38440-18000 ASSY-BEARING DIFF SIDE (2) 16 38453-H1000 SHIM-ADJUST SIDE BEARING T=0.05 (0) 16 38454-H1000 SHIM-ADJUST SIDE BEARING T=0.07 (0) 16 38455-H1000 SHIM-ADJUST SIDE BEARING T=0.10 (0) 16 38456-H1000 SHIM-ADJUST SIDE BEARING T=0.20 (0) 16 38457-H1000 SHIM-ADJUST SIDE BEARING T=0.50 (0) 17 38120-18000 ASSY-BEARING DRIVE PINION REAR 18 38140-18000 ASSY-BEARING DRIVE PINION FRONT 19 38165-H1000 SPACER-DRIVE PINION BEARING 20 38154-G0406 WASHER-ADJUST DRIVE PINION T=2.92 (0) 20 38154-G0407 WASHER-ADJUST DRIVE PINION T=2.95 (0) 20 38154-G0414 WASHER-ADJUST DRIVE PINION T=3.16 (0) 20 38154-G0417 WASHER-ADJUST DRIVE PINION T=3.25 (0) 20 38154-G0404 WASHER-ADJUST DRIVE PINION T=2.86 (0) 20 38154-G0400 WASHER-ADJUST DRIVE PINION T=2.74 (0) 20 38154-G0401 WASHER-ADJUST DRIVE PINION T=2.77 (0) 20 38154-G0402 WASHER-ADJUST DRIVE PINION T=2.80 (0) 20 38154-G0415 WASHER-ADJUST DRIVE PINION T=3.19 (0) 20 38154-G0405 WASHER-ADJUST DRIVE PINION T=2.89 (0) 20 38154-G0416 WASHER-ADJUST DRIVE PINION T=3.22 (0) 20 38154-G0408 WASHER-ADJUST DRIVE PINION T=2.98 (0) 20 38154-G0409 WASHER-ADJUST DRIVE PINION T=3.01 (0) 20 38154-G0410 WASHER-ADJUST DRIVE PINION T=3.04 (0) 20 38154-G0411 WASHER-ADJUST DRIVE PINION T=3.07 (0) 20 38154-G0412 WASHER-ADJUST DRIVE PINION T=3.10 (0) 20 38154-G0413 WASHER-ADJUST DRIVE PINION T=3.13 (0) 20 38154-G0403 WASHER-ADJUST DRIVE PINION T=2.83 (0) 21 38189-18000 SEAL-OIL DRIVE PINION 22 38210-H1000 ASSY-FLANGE COMPANION WITH DAMPER FOR SERVICE 22 38210-18000 ASSY-FLANGE COMPANION 23 38215-01300 WASHER-PLASN 24 38216-18000 NUT-DRIVE PINION 25 38320-18010 GASKET-GEAR CARRIER 26 08915-13810 WASHER-LOCK (8) 27 08911-20810 NUT (8)
