Also see:
Part Numbers Index Main article for usage, photos, cross-reference Steering Linkage
STEERING LINKAGE
1 48530-H1000 IDLER ASS'Y-steering
2 48551-H1000 ARM-idler-steering (ARM-PITMAN)
3 48544-H1000 BUSHING-idler, upper 2
4 48541-H1000 WASHER-idler, upper
5 08912-44210 NUT
fixing idler to frame
6 48362-H1000 BOLT 2
7 08915-53810 WASHER-plain 2
8 48366-H1000 NUT 2
9 48502-H1000 ARM-steering gear
fixing steering gear arm
10 08911-24610 NUT
11 08915-14610 WASHER-lock
12 48560-H1000 ROD ASS'Y-cross
13 48522-H1001 COVER-dust, cross rod 2 -8910
48522-G1500 8910- <> 48522-H1001
14 48526-18000 CLAMP-dust cover 2
15 40189-73000 PLUG-filler 2
16 48577-H1001 SEAL-dust, idler arm
17 08921-32010 PIN-cotter 2
18 01227-00011 NUT 2 -8503
01227-00091 NUT 2 8504-
19 48510-H1001 ROD ASS'Y-side (R.H.) (up to '72-9)
48510-H1002 ROD ASS'Y-side (R.H.) (from '72-10) <x*> 48510-H1001
* Replacement only as a set
20 48630-H1001 ROD ASS'Y-side (L.H.) (up to '72-9)
48630-H1002 ROD ASS'Y-side (L.H.) (from '72-10) <x*> 48630-H1001
Up to '72-9, each side rod assembly include separate parts:
21 48520-H1001 SOCKET ASS'Y-side rod, outer (R.H.)
22 48521-H1001 SOCKET ASS'Y-side rod, inner (R.H.)
23 48640-H1001 SOCKET ASS'Y-side rod, outer (L.H.)
24 48641-H1001 SOCKET ASS'Y-side rod, inner (L.H.)
25 48522-H1001 COVER-dust, side rod 2
26 48526-18000 CLAMP-dust cover 2
27 40189-73000 PLUG-filler 2
28 01227-00011 NUT 2
29 08921-32010 PIN-cotter 2
30 48512-H1001 BAR-side rod 2
31 01211-00011 NUT-lock, side rod (R.H.) 2
32 01211-00021 NUT-lock, side rod (L.H.) 2
33 48510-H1025 ROD KIT-side (R.H.) (from '72-10)
34 48630-H1025 ROD KIT-side (L.H.) (from '72-10)
35 01227-00011 NUT (from '72-10) 4
01227-00091 NUT 8504- 4
36 08921-32010 PIN-cotter (from '72-10) 4
1 48510-H1025 KIT-ROD SIDE RH 1072- 2 48510-H1002 1 48510-H1001 ASSY-ROD SIDE RH 1 48510-H1002 ASSY-ROD SIDE RH 1072- 6 48510-H1001 2 48520-H1001 ASSY-SOCKET SIDE ROD RH OUTER 3 48521-H1001 ASSY-SOCKET SIDE ROD RH INNER 4 48522-H1001 COVER-DUST SIDE ROD (2) 5 48526-18000 CLAMP-DUST COVER (2) 6 40189-73000 PLUG-FILLER (2) 7 01227-00011 NUT-HEX SLOTTED (3) 8 08921-32010 PIN-COTTER 3.2X20 (2) 9 48512-H1001 BAR-SIDE ROD 10 01211-00011 NUT-LOCK SIDE ROD RH 11 01211-00021 NUT-LOCK SIDE ROD LH 12 48630-H1002 ASSY-ROD SIDE LH 1072- 6 48630-H1001 12 48630-H1025 KIT-ROD SIDE LH 1072- 2 48630-H1002 12 48630-H1001 ASSY-ROD SIDE LH 13 48640-H1001 ASSY-SOCKET SIDE ROD LH OUTER 14 48641-H1001 ASSY-SOCKET SIDE ROD LH INNER 15 01211-00021 NUT-LOCK SIDE LH 16 48526-18000 CLAMP-DUST COVER (2) 17 40189-73000 PLUG-FILLER (2) 18 01227-00011 NUT-HEX SLOTTED (2) 19 08921-32010 PIN-COTTER 3.2X20 (2) 20 48512-H1001 BAR-SIDE ROD 21 01211-00011 NUT-LOCK SIDE RH 22 48530-H1600 ASSY-IDLER STEERING 23 48551-H1000 ARM-IDLER STEERING 24 48544-H1000 BUSH-IDLER (2) 25 48541-H1000 WASHER-IDLER UPPER 26 54324-21000 NUT-HEX SELF LOCK 26 54324-N0100 NUT-HEX SELF LOCK 2 54324-21000 27 48362-H1000 BOLT IDLER FIX TO FRAME (2) 28 08915-53810 WASHER-PLAIN M8 IDLER FIX TO FRAME (2) 29 48366-H1000 NUT IDLER FIX TO FRAME (2) 30 48560-H1600 ASSY-CROSS ROD STEERING 31 48522-H1001 COVER-DUST CROSS ROD 32 48526-18000 CLAMP-DUST COVER 33 40189-73000 PLUG-FILLER (2) 34 48577-H1001 SEAL-DUST IDLER ARM 35 01227-00011 NUT-HEX SLOTTED (2) 36 08921-32010 PIN-COTTER 3.2X20 (2) ARM-steering gear: see Steering Gear Part Numbers
