Also see: Part Numbers Index Main articles for usage, photos, cross-reference: Wiring Wiring Harness Battery
1971
WIRING
1 to '71-Mar
24012-H1002 COMP.-CABLE, engine room harness STD,DX (exc. A)
24012-H1004 COMP.-CABLE, engine room harness (??地向) (op.) STD,DX (exc. A)
24012-H2000 COMP.-CABLE, engine room harness 2GT,4GT,CG
24012-H2004 COMP.-CABLE, engine room harness (??地向) GX (op.) 2GT,4GT,CG
24012-H2005 COMP.-CABLE, engine room harness 2GA,4GA,CGA
24012-H2009 COMP.-CABLE, engine room harness (??地向) (op.) 2GA,4GA,CGA
24012-H1122 COMP.-CABLE, engine room harness 2DA,4DA,CA
24012-H1124 COMP.-CABLE, engine room harness (?冷地向) (op.) 2DA,4DA,CA
from '71-Apr
24012-H1206 COMP.-CABLE, engine room harness STD,DX
24012-H2206 COMP.-CABLE, engine room harness GL,GX
24012-H2216 COMP.-CABLE, engine room harness A-all
2 24013-H1002 COMP.-CABLE, instrument harness 3 speed, VDT
24013-H1022 COMP.-CABLE, instrument harness (?冷地向) (op.) 3 speed, VDT
24013-H1105 COMP.-CABLE, instrument harness 2DA,4DA
24013-H1125 COMP.-CABLE, instrument harness (?冷地向) (op.) 2DA,4DA
24013-H1200 COMP.-CABLE, instrument harness 4 speed (exc. VDT,GL,GX)
24013-H1220 COMP.-CABLE, instrument harness (?冷地向) (op.) 4 speed (exc. VDT,GL,GX)
24013-H2000 COMP.-CABLE, instrument harness 2GT,4GT,CG
24013-H2020 COMP.-CABLE, instrument harness (op.) 2GT,4GT,CG
24013-H2020 COMP.-CABLE, instrument harness GX
24013-H2005 COMP.-CABLE, instrument harness 2GA,4GA,CGA
24013-H2025 COMP.-CABLE, instrument harness (?冷地向) (op.) 2GA,4GA,CGA
24013-H1305 COMP.-CABLE, instrument harness CA
24013-H1325 COMP.-CABLE, instrument harness (op.) CA
from '71-Apr
24013-H1206 COMP.-CABLE, instrument harness 3 speed, VDT
24013-H1126 COMP.-CABLE, instrument harness 2DA,4DA [Deluxe Automatic]
24013-H2206 COMP.-CABLE, instrument harness 2GL,4GL,GX [GL,GX manual]
24013-H2016 COMP.-CABLE, instrument harness 2GA,4GA,CGA [GL Automatic]
3 24014-H1001 COMP.-CABLE, body harness Sedan
24014-H1400 COMP.-CABLE, body harness Van
24014-H1801 COMP.-CABLE, body harness Coupe
4 25442-H1100 FUSIBLE LINK-type "C" 1 ALL (exc. GL,GX)
25442-H1100 FUSIBLE LINK-type "C" 3 GL,GX
25442-H2500 FUSIBLE LINK-type "C" 1 (from '71-Apr)
24150-H1020 ASS'Y-CABLE, indicator lamp A-all
5 24015-H1000 COMP.-CABLE, tail harness Sedan
24015-H1400 COMP.-CABLE, tail harness Van
24015-H1800 COMP.-CABLE, tail harness Coupe
6 24147-H1400 ASS'Y-CABLE, license lamp Van
7 24029-H1400 ASS'Y-CABLE, tank unit Coupe
24016-H1400 ASS'Y-CABLE, tank unit Van
8 24110-H1000 ASS'Y-CABLE, battery (+)
24110-H1005 ASS'Y-CABLE, battery (+) (from '71-Apr) <x> 24110-H1000
24110-H1900 ASS'Y-CABLE, battery (+) (?冷地向) (op.)
24110-H1605 ASS'Y-CABLE, battery (+) (?冷地向) (from '71-Apr) (op.) <x> 24110-H1900
9 24080-H1000 ASS'Y-CABLE, battery (-)
24080-H1900 ASS'Y-CABLE, battery (-) (?冷地向) (op.)
10 24160-H1000 ASS'Y-CABLE, room lamp STD
24160-H1100 ASS'Y-CABLE, room lamp Dx.,GL,GX
11 24149-H0110 ASS'Y-CABLE, inhibitor switch A-all
24100-H1000 ASS'Y-CABLE, fog lamp (op.)
24043-H2000 ASS'Y-CABLE, clock (for console box) GX
24043-H2025 ASS'Y-CABLE, clock (for console box) GX <> 24043-H2000
24161-H2200 ASS'Y-CABLE, heat glass "A" (op.) Coupe, Sedan
24162-H2200 ASS'Y-CABLE, heat glass "B" (op.) Coupe, Sedan
24163-H2000 ASS'Y-CABLE, heat glass "C (l=400 mm) " (op.) Sedan
24163-H2200 ASS'Y-CABLE, heat glass "C (l=350 mm) " (op.) Coupe
Truck
HARNESS ASSY-INSTRUMENT 24013 24013-H1002 CABLE-COMP.-instrument harness (up to '73-3) 24013-H1022 CABLE-COMP.-instrument harness (up to '71-3) (op.) 24013-H1206 CABLE-COMP.-instrument harness (up to '71-4) 24013-G1000 CABLE-COMP.-instrument harness 24013-G1602 -7803 24013-G1661 7804-8109 24013-G1900 8110-8608 24013-G1901 8608-8910 24013-95W00 8910-
1 24012-H7000 HARNESS-ENGINE ROOM MANUAL 0772- 0 24012-H2102 1 24012-H7005 HARNESS-ENGINE ROOM AUTOMATIC 0772- 0 24012-H2112 1 24012-H2112 HARNESS-ENGINE ROOM AUTOMATIC 0172- 0 24012-H2111 1 24012-H2111 HARNESS-ENGINE ROOM AUTOMATIC 0671- 0 24012-H2118 1 24012-H7001 HARNESS-ENGINE ROOM MANUAL 0372- 0 24012-H7000 1 24012-H2102 HARNESS-ENGINE ROOM MANUAL 0172- 0 24012-H2101 1 24012-H2101 HARNESS-ENGINE ROOM MANUAL 0671- 0 24012-H2108 1 24012-H2108 HARNESS-ENGINE ROOM MANUAL 0471-0571 10 24012-H1900 1 24012-H1900 HARNESS-ENGINE ROOM MANUAL 1 24012-H2118 HARNESS-ENGINE ROOM AUTOMATIC 2 24013-H1905 HARNESS-INSTRUMENT MANUAL 2 24013-H2118 HARNESS-INSTRUMENT 0471- 2 24013-H2112 HARNESS-INSTRUMENT AUTOMATIC 0771- 0 24013-H2118 2 24013-H7000 HARNESS-INSTRUMENT AUTOMATIC 0772- 0 24013-H2112 3 24014-H1011 HARNESS-BODY SEDAN 3 24014-H1811 HARNESS-BODY COUPE 4 24015-H1900 HARNESS-TAIL SEDAN 4 24015-H7000 HARNESS-TAIL SEDAN 1272- 0 24015-H1900 4 24015-H1910 HARNESS-TAIL COUPE 5 24272-H1000 PROTECTOR-WIRING SEDAN 6 24039-H1900 ASSY-CABLE HAND BRAKE SWITCH 7 24150-H1020 ASSY-CABLE INDICATOR LAMP AUTOMATIC -671 1 8 24250-89927 GROMMET SEDAN 9 24029-H1400 CABLE-TANK UNIT COUPE 10 24220-89937 CLIP FIXING TO BODY SIDE INNER COUPE 11 24220-89953 CLIP FIXING TO REAR COMB LAMP COUPE 12 25442-H1100 LINK-FUSIBLE,TYPE C 12 25442-H2500 LINK-FUSIBLE,TYPE C 0471- 0 25442-H1100 13 24110-H1600 CABLE-BATTERY(+) 13 24110-H1605 CABLE-BATTERY (+) 0 24110-H1600 13 24110-H1900 CABLE-BATTERY(+) COUPE 2 24110-H1605 14 24080-H1900 CABLE-BATTERY(-) 15 24160-H1100 CABLE-ROOM LAMP DX 16 24100-H1600 CABLE-FOG LAMP 17 24163-H1900 CABLE-HEAT GLASS D OP 1270- 18 24220-89931 CLIP-CABLE OP 1270- 19 24161-H2200 CABLE-HEAT GLASS A OP.COUPE 1270- 19 24161-H1900 CABLE-HEAT GLASS,A OP.SEDAN 20 24162-H2200 CABLE-HEAT GLASS B OP 1270- 21 24163-H2200 CABLE-HEAT GLASS C OP.COUPE 22 24163-H2000 CABLE-HEAT GLASS OP.SEDAN 23 24338-H4600 CABLE-SEAT BELT WARNING MANUAL 0772- 2 24110-H1600 23 24338-H7005 CABLE-SEAT BELT WARNING AUTOMATIC 0772- 23 24338-H4600 CABLE-SEAT BELT WARNING 0172-
