DISC
- SIZE ID: 13/16
- SIZE OD: 7 1/8
- TEETH: 18T
Clutch Release Bearing (release bearing, throwout bearing)
- Bore = 1.5748
- Outer Diameter = 2.8898
- Width = 0.752
Throwout Bearing
Mechanical Clutch (RHD)
- Withdrawal lever
- Return spring
- Release bearing
Hydraulic Clutch (LHD)
See Hydraulic clutch
Clutch Kit (PLATE KIT,CLU PRESS & DRVN(W/CVR))
- BECK/ARNLEY 0619114 $78.89 {180mm Diameter;7-1/8" Diameter;18 Splines}, ACDELCO 381622 $83.79
- BCA 01576 $21.89
{Ball Bearing}
Clutch Slave Cylinder
- RAYBESTOS SC37495 $12.44, ACDELCO 18F19 $14.56
Compare to B210:
B210 clutch cylinder 5/8 inch. Fits:Beck Arnley part number 072-6489
- 620 Pickup from 1972-3/76 <li>B210 (all models) from 1974-4/75 <li>SPL-311 (1600 or 2000) from 1966-70 <li>510 from 1968-73 (with Nabco master cylinder) <li>610 from 1973-75 (with Nabco master cylinder) <li>710 from 1973-75 </ul> Beck Arnley part 072-6521
<li>74-75 B210 <li>76 F10 <li>72-76 <li>620 pickup <li>66-70 SPL-311 1600 <li>68-70 SPL-311 2000 <li>75-78 280Z <li>69-73 510 <li>78-81 510 <li>73-76 610 <li>74-77 710 <li>77-81 810
</blockquote>
Pilot Bushing
Clutch Alignment Tool (wood, plastic or metal)
Suppliers
- Centerforce Clutches (USA)
- http://www.clutchnet.com (USA) lists B210 and 210 parts (which will fit the 1200)
